Duckmanton also appears to be down to an hourly service, unless you are close enough to walk down and get the 2 from the main road. Poolsbrook appears to lose daytime service, but retains an hourly evening service.
There seems to be little joined up thinking around some services though. When the 90 was extended to Markham Vale it passed a large new housing estate called Aspire Way. Only problem is no-one thought to add any stops for this estate! Similarly for the large Skylarks estate in Dunston, other than a handful of peak time 44s, nothing passes. In both cases you can walk to another service in 10-15 minutes, but anyone with an alternative won't be doing that.
I raised this with Stagecoach a few years back and was told they were 'assessing the situation'. Totally pointless. Large new estates like this need buses from the outset otherwise behaviours get set. If your only way out is by car, you only buy a house there if you drive. Adding buses years later won't work as everyone has already made their own arrangements. I quite understand such services won't be financially viable initially, but this is where a combination of long-term thinking and some support is needed.
I'm struggling to see how the 15 will work, unless they've also changed the route between Whittington Moor and Dronfield. They've cut 8 minutes off this run to try and balance the 10 minutes they've added by taking in the 5 route. I can't see there being that much slack in the current timetable, and a quick scan of journeys on bustimes shows some late running. The current timetable also rolls back 5-10 minutes each hour, while the new one is pretty much same times every other hour.
