Stagecoach East Midlands - Fleet and Engineering Updates
RareApe
19 Aug 2025
Mansfield
Is there a date when hull is going completely electric?
I'm guessing the 6th to 8th of August since electrical work has been flagged between 27 Jul 10:25 and 5 Aug 23:59 BST at Stoneferry Road, which mentions a footpath being closed. This matches up with the photos from Hullian111, which prove its Stagecoach's EV connection.
CN12 AWU
11 Nov 2024
Believe it was just the same as 773/5. When they’ve had their inspection they’ve found something that goes beyond what a drivers defect check would and it’s not economically viable to repair with the impeding electrics.
Last few times I have driven 22756 the suspension has been shot. Dropping itself, smashing into everything.
22776 and 22639 do/did that
Hullian111
18 Jan 2023
Kingston upon Hull
According to Robin Chambers (who is normally reliable on MAN related matters) Hull are to receive the rest of the MAN Enviro 400s (19621-632) from Scotland.
Oh for God's sake, just when I thought we were done with this merry-go-round of E400 transfers...
Anyway, rubbish photo, but 80297's been on the matchday 246 to and from Craven Park:
Zenneth101
21 Jul 2024
Kingston-upon-Hull
What surprises me is that we get rid of MANs in the form of the Enviro 300s, yet happy to get more of the Enviro 400s which if you look at 19638 and 19639, aren't exactly reliable either. Plus most MAN Enviro 400s I hear sound atrocious or do the same squealing found on 22759
jamestaylor94
31 Jan 2018
Like I say I think the plan is for most of them to do the st Mary’s contract
CN12 AWU
11 Nov 2024
Apparently only the best 5 from the scotland 19s are coming or so I was informed yesterday these will be getting seat belted and only used on St Marys routes as per contract requirements
I was also informed yesterday although power getting turned on this monday that all 40+ electric buses will enter full all day service on the 8th
However I seen no proof to confirm this
jimbob185
9 Oct 2018
Presume 10061 might get allocated as well as it already had seat belts fitted.
haydezfrfr
4 Oct 2025
grimsby
so if SC Hull is going fully EV allegedly on august 8th, wonder what Lincoln or Grimsby depots would get then if their fading out their old busses. I just pray its not more E300's. But then if our Volvos are going whenever that is , again what will replace them.
Ferrylift3
18 May 2025
The proposed interchange stand modifications were only shared to the council a few weeks ago so I don't think the 400EV's will be in use for a while, unless they don't need to use the interchange.
CN12 AWU
11 Nov 2024
They are all out on the 8th apparently
They fit on stands but just have to be careful until modification work
They had a few E400EVs in service recently and had no issues on stands
Well womt be full electric there only 40 something electrics and hull aint due to loose much bar a few old 19s and 22s which i guess would get scrapped
James taylor be best person to ask.as he works there
haydezfrfr
4 Oct 2025
grimsby
New arrival into EM Worksop is 10819 in Pride Livery. Another arrival is 10539 from Midlands > Lincoln for Worksop 1785599647927.png
K13R0N
26 Mar 2019
Grimsby
10819 has arrived at Worksop from Merseyside. More MMCs from Merseyside expected
My webpage didn't show the post above! Apologies for duplicate
K13R0N
26 Mar 2019
Grimsby
I don't know exactly but i've heard 10820-829 but don't know exactly! Their to replace the older SN16's If im correct, i wonder if we will get them
I don't think they would be replacing the three E400 MMCs they have considering they are the same year - more probable any early Trident 2 Enviro 400s they have
Ferrylift3
18 May 2025
Is worksop going majority double deckers?
Supposed to be at least replacing all 08 and older deckers. MANs were also supposed to be going however they may be staying a bit longer as they have had NSA kit fitted and 24202 has gone for paint at Hull.
Busesfan
27 Nov 2025
Grimsby
Didn’t you say that SM66 plates from Merseyside were to replace the 19xxx in Hull?
Ferrylift3
18 May 2025
There's not many left on Merseyside which don't have a home now, just 10817/20-29 from what I see.....unless any of the Birkenhead ones are leaving???
I don't know exactly which ones are due but 10817/20-32/34 are surplus. In total there are 37 MMC's due from Merseyside and Midlands to be split mainly between Worksop and Lincoln. Some other depots will get cascaded MMC's from Hull when the electric decker's go in.
Goblinlion
11 Dec 2025
Do you know which MMCs are due to leave Hull? As the Enviro400EVs can't replace all the MMCs and Enviro400s
CN12 AWU
11 Nov 2024
The E400 electrics are mostly replacing 10*** E400MMCs and the early E400s
The E10s are replacing 22s until the E12s are ready or that was the plan recently
Goblinlion
11 Dec 2025
Presume that means the pride bus (10741) will go. But I guess in time one of the Enviro400EVs will become a pride bus like 80061 at Midlands. Are the E400s the that are being replaced the 58 and older?
Ferrylift3
18 May 2025
Basically anything that hasn't been fitted with NSA kit is due to go before October. So that's anything 58 plate or older.
RareApe
19 Aug 2025
Mansfield
From what I'm seeing, Hull will most likely lose all of their MMCs due to the number of buses that need replacing. There are currently 35 400MMCs and 5 200MMCs at Hull, and with 58 plates or older being removed, that is 96 buses that need replacing across the region. Hull is getting 46 EV buses, and there are 37 new MMCs coming to replace older buses, so that's 83 buses being replaced so far (46 + 37), but that still leaves 13 old buses to be removed (96 - 83 = 13). And this doesn't even count the buses that are usable but are either already out of service or planned to be soon, like 37001 at Mansfield, which had a thermal burn in the engine and needs to be replaced. So either there will be more movements or more EVs than anyone was told about.
