Stagecoach East Midlands - Fleet and Engineering Updates
CN12 AWU
11 Nov 2024
I would assume then with those E400s potentially never running again, they would be driven to Scunthorpe today to swap them with the E400 EVs in storage there.
Would the 24xxxs be swapping with the 26xxxs at Grimsby then? (would be intrigued to see what else as that could be 17 buses being replaced by only 9)
24xxx are replacing 22xxx at Hull apparently
Also I believe all EVs at Scunthorpe are now in Hull ready for tommorow
I believe 10882-8 were meant to initially come but plans do change
I been informed
E400s 19045, 19146, 19175, 19211, 19230, 19233, 19234, 19240, 19243, 19307, 19308, 19377, 19379 and 19382 have ran there last services at Hull
Also the remaining MAN E300s 22639, 22757, 22759, 22774, 22776, 22778, 22796, 22797 and 22877 may also have ran there last services (24s that are being displaced by MMCs are due to come back to Hull apparently)
Also a comment by a depot staff member on a recent photo of 19377 on a Stagecoach Enthusiast facebook page says its done at Hull
But like anything plans change and with the new EVs from tommorow most or all of these could stay longer if any faults arise with EVs also cant see 19307/8 and 19377 going anywhere really as 2 should be needed for consortium anf 19377 id heritage liveried
I dont know for deffinate if they have gone or going just the information I have recieved
22797 is out today by looks of it I suspected some may stay longer couldnt see all going
K13R0N
26 Mar 2019
Grimsby
Ah fair enough, apologies if I misread that!
haydezfrfr
4 Oct 2025
grimsby
After 6pm Service 5 turns into 45. But from September its becoming 5B.
Zenneth101
21 Jul 2024
Kingston-upon-Hull
Newly entered EVs
3: 80297, 80301, 80302, 80303, 80304, 80305, 80312
5: 80310, 80357, 80358, 80359, 80360
12: 63151, 80298, 80307, 80309, 80311
Hullian111
18 Jan 2023
Kingston upon Hull
Today's the big day! A shame there's nothing due to be allocated wholetime on the 8 and 11/111, but I suppose I can understand concerns about range anxiety for the latter. Perhaps they'll get the longer Yutong single decks or even the reputed U11DDs when they come around?
CN12 AWU
11 Nov 2024
You may get E10s on them as there meant to appear anywhere now apparently
Newly entered EVs
3s are all electric bar 11199 which finishes on a ferry bus
5s have several diesels
11196 which ends on a 33
11690 (could be switched for a rlectric later?)
11764 which runs a 11 later
11769 (could be switched for a electric later?)
12s mostly electric bar
11768 (could be switched to electric later?)
11766 goes onto other routes
11192 (could be switched to electric later?)
Also of note curently only 3 of the 22 series MANs are out being 22757, 22797, 22877
Patsbuses160
16 Jan 2026
Grimsby
I think by the end of today 22757,22797 & 22877 could go but again not sure.
CN12 AWU
11 Nov 2024
I have heard that a lot of the 22 series are now parked up at Scunthorpe.
Only the ones not upgraded have gone apparently 19s be going this week and more Electric deckers coming from Scunthorpe (steel blue I believe)
Fox192
17 Oct 2023
Hull
What’s the full fleet numbers of electrics, is the E10s 63148-57 , and what’s the rest
CN12 AWU
11 Nov 2024
E10s - 63148-57
Enviro400EVs- 80294-312(Local livery) 80357-69 (We’ve got you livery)
Most e400s nit showing on bustimes yet from both sets
Not many E10s out I was told 9 were going to be out from today
jimbob185
9 Oct 2018
Thanks, is there any idea the e12 fleet numbers , notice a couple on bustimes if they are correct
E12s are 73231-46. Hull were also due Yutong U11DDs 83036-55 but I think Hull is only getting 6 or 7 from this batch now with the rest I think for Mansfield to replace the We’ve got you livery E400EVs that had been ordered for for them but are now at Hull.
Fox192
17 Oct 2023
Hull
Thanks for the info
RareApe
19 Aug 2025
Mansfield
In total there is 55 enviro400s that hasn't tracked since Saturday.
This is a list of all of them.
Fleet number, reg, last tracked, garage, age
Fleet 10039 – KX12 GXH – last tracked 14 Jul – Garage: Lincoln – Age: 14 years
Fleet 10054 – SN13 EEA – last tracked 25 Jul – Garage: Spalding – Age: 13 years
Fleet 10055 – SN13 EEB – last tracked 8 Aug – Garage: Spalding – Age: 13 years
Fleet 19007 – MX06 XAG – last tracked 28 Oct 2025 – Garage: Unknown – Age: 20 years
Fleet 19018 – MX06 XAT – last tracked 8 Aug – Garage: Gainsborough – Age: 20 years
Fleet 19045 – SN56 AWV – last tracked 8 Aug – Garage: Hull – Age: 20 years
Fleet 19067 – MX56 FSY – last tracked 7 Aug – Garage: Mansfield – Age: 20 years
Fleet 19072 – MX56 FTE – last tracked 6 Aug – Garage: Mansfield – Age: 20 years
Fleet 19125 – FX07 CMF – last tracked 8 Aug – Garage: Mansfield – Age: 19 years
Fleet 19126 – FX07 CMK – last tracked 23 Jun – Garage: Grimsby – Age: 19 years
Fleet 19142 – NK07 GZV – last tracked 15 Jul – Garage: Grimsby – Age: 19 years
Fleet 19146 – NK07 HBF – last tracked 8 Aug – Garage: Hull – Age: 19 years
Fleet 19175 – SV57 BGF – last tracked 8 Aug – Garage: Hull – Age: 19 years
Fleet 19184 – MX57 DZJ – last tracked 29 Jul – Garage: Lincoln – Age: 19 years
Fleet 19201 – NK57 DWF – last tracked 8 Aug – Garage: Lincoln – Age: 19 years
Fleet 19204 – NK57 DWL – last tracked 7 Aug – Garage: Scunthorpe – Age: 19 years
Fleet 19207 – NK57 DWO – last tracked 7 Aug – Garage: Grimsby – Age: 19 years
Fleet 19209 – NK57 DWV – last tracked 4 Aug – Garage: Mansfield – Age: 19 years
Fleet 19210 – NK57 DWW – last tracked 6 Aug – Garage: Grimsby – Age: 19 years
Fleet 19211 – NK57 DWX – last tracked 8 Aug – Garage: Hull – Age: 19 years
Fleet 19233 – MX08 GKP – last tracked 8 Aug – Garage: Hull – Age: 18 years
Fleet 19234 – MX08 GKU – last tracked 8 Aug – Garage: Hull – Age: 18 years
Fleet 19237 – MX08 GLF – last tracked 22 Jul – Garage: Scunthorpe – Age: 18 years
Fleet 19240 – MX08 GLV – last tracked 8 Aug – Garage: Hull – Age: 18 years
Fleet 19243 – MX08 GME – last tracked 8 Aug – Garage: Hull – Age: 18 years
Fleet 19295 – AE07 KYV – last tracked 8 Aug – Garage: Lincoln – Age: 19 years
Fleet 19298 – AE07 KYY – last tracked 10 Jul – Garage: Unknown – Age: 19 years
Fleet 19302 – AE07 KZC – last tracked 5 Aug – Garage: Lincoln – Age: 19 years
Fleet 19306 – AE07 KZH – last tracked 3 Aug – Garage: Lincoln – Age: 19 years
Fleet 19369 – SV58 BLN – last tracked 3 Aug – Garage: Gainsborough – Age: 18 years
Fleet 19377 – SV58 BNB – last tracked 8 Aug – Garage: Hull – Age: 18 years
Fleet 19379 – NK58 AET – last tracked 8 Aug – Garage: Hull – Age: 18 years
Fleet 19382 – NK58 AEW – last tracked 8 Aug – Garage: Hull – Age: 18 years
Fleet 19484 – MX09 AOZ – last tracked 30 Jul – Garage: Gainsborough – Age: 17 years
Fleet 19486 – MX09 APK – last tracked 7 Aug – Garage: Gainsborough – Age: 17 years
Fleet 19489 – MX09 APV – last tracked 8 Aug – Garage: Gainsborough – Age: 17 years
Fleet 19491 – MX09 APZ – last tracked 6 Aug – Garage: Lincoln – Age: 17 years
Fleet 19493 – MX09 ARO – last tracked 4 Aug – Garage: Gainsborough – Age: 17 years
Fleet 19495 – MX09 ARZ – last tracked 31 Jul – Garage: Gainsborough – Age: 17 years
Fleet 19496 – MX09 ASO – last tracked 7 Aug – Garage: Gainsborough – Age: 17 years
Fleet 19498 – MX09 ASV – last tracked 6 Aug – Garage: Gainsborough – Age: 17 years
Fleet 19499 – MX09 ASZ – last tracked 6 Aug – Garage: Gainsborough – Age: 17 years
Fleet 19503 – MX09 ATO – last tracked 8 Aug – Garage: Mansfield – Age: 17 years
Fleet 19504 – MX09 ATU – last tracked 1 Aug – Garage: Gainsborough – Age: 17 years
Fleet 19506 – MX09 AUF – last tracked 8 Aug – Garage: Mansfield – Age: 17 years
Fleet 19507 – MX09 AUH – last tracked 7 Aug – Garage: Mansfield – Age: 17 years
Fleet 19517 – MX09 KSV – last tracked 1 Aug – Garage: Lincoln – Age: 17 years
Fleet 19519 – MX09 KSZ – last tracked 7 Aug – Garage: Lincoln – Age: 17 years
Fleet 19521 – MX09 KTC – last tracked 8 Aug – Garage: Lincoln – Age: 17 years
Fleet 19526 – MX09 KTJ – last tracked 28 Jul – Garage: Worksop – Age: 17 years
Fleet 19527 – MX09 KTK – last tracked 8 Aug – Garage: Hull – Age: 17 years
Fleet 19542 – SP59 APX – last tracked 8 Aug – Garage: Scunthorpe – Age: 17 years
Fleet 19579 – AE10 BWM – last tracked 21 Jul – Garage: Scunthorpe – Age: 16 years
Fleet 19635 – MX59 KJN – last tracked 23 Jul – Garage: Hull – Age: 17 years
Fleet 19638 – MX59 KJY – last tracked 3 Aug – Garage: Hull – Age: 17 years
CN12 AWU
11 Nov 2024
19635/8 are off for repairs I believe 10039, 10054/5 might be moving to Hull but not 100% confirmed
All Hull E400s in 190**, 191**, 192** and 193** series are all withdrawn bar 19307/8 (for now)
All 22s are withdrawn bar the 3 currently in use believe only until some 24s move back
Thomas04
22 Feb 2025
Cleethorpes
19007 is getting a full interior change and going to a charity in boston as far as im aware. its been withdrawn for awhile now
