Staff toilets
DavyCrocket
27 Oct 2006
Yes they do.
Though sometimes if they are not the regular known ones, a local staff member may have to show the route to and from
blue87
21 Mar 2008
I imagine the drivers have some kind of list as to where the staff toilets are located each station just in case they get urgently caught short too.
Sort of. They certainly know where facilities are at locations where they regularly have business - generally crew relief points, termini, and perhaps a few other stations which get used by drivers during engineering works or whatever. But otherwise no it’s a case of asking staff, and in these cases staff would have to let them in anyway.
Dstock7080
17 Feb 2010
West London
There are platform based facilities at certain station headwalls, accessible to drivers and these widely known.
A courtesy call to the Line Controller is advised if these facilities are to be used.
Mawkie
17 Feb 2016
Unless it was some kind of emergency, it would be extremely unlikely that a train op would take a Physical Needs Relief (PNR) on a running line at a random station where they would have to be escorted to the toilet - that has the potential to be extremely detrimental to the service. I certainly know where all my PNR points are on my line - at termini, occasional head walls, and other secret doors
IIRC, Rule Book 6 states "must" tell the controller, but agree that it seems to have fallen by the wayside a little these days.
31 Dec 2019
uk
I'd imagine it would be likely if there was a long suspension, e.g. a fatality ahead.
Mawkie
17 Feb 2016
So every single station has a toilet?
Are there any that are... uh... horrors?
Every station I've ever worked at has had a toilet and mostly kept in "good to very good" condition.
One surprise at Seven Sisters was this full size porcelain urinal, which was very clean, but surely they weren't installing these in 1967? Could it have come from somewhere else?
Tube driver
7 Jan 2018
Company has minimum standards on toilet facilities and a cleaner will be called fairly quickly should they *ahem* fall below standard.
For Drivers they’ll be located at various points that are convenient and quickly accessed so at terminus’s where you have a bit more time plus a couple dotted along the line. At the end of the day though, if you have to go (and I mean really have to go) then you can call a PNR anywhere as needing to go can prove a serious distraction so give the controller as much notice as possible so a member of staff can be dispatched to effectively ‘mind the train’ and trains held ahead and behind you to regulate the service and avoid having trains stuck in section. That is a very rare occurrence though as your body quickly adjusts to take a comfort break at terminus’s and at break times.
TheTallOne
2 Jan 2024
Instead of minding the train, couldn’t they send a spare driver to drive the train and then when they’re back from the loo, they swap with the next driver, who can go to the loo too, then swap with the next driver and so on…
Dstock7080
17 Feb 2010
West London
Spare driver from where?
If an urgent PNR is required a few minutes notice would be needed and train staff depots could be many stations away, eg. PNR required at Covent Garden, train crew depot at Acton Town or Arnos Grove.
MaidaVale
18 Jun 2021
Reading / SW London
I'd say the majority of the time drivers tend to call up when taking one at the usual stations that might be likely to cause blocking back, such as Cockfosters or Wood Green Westbound, but in my experience most T/Ops don't tend to call in the quieter ones like South Harrow Eastbound or T4, which never really causes any issues.
TheTallOne
2 Jan 2024
I probably should have added a :lol: to the end, as it was kind of a joke.
In fact I thought I had, but it seems normal emojis are removed on saving.
Mldaureol
5 Mar 2023
Humberstone
I remember an emergency PNR on the failures and delays sheet which occurred at Moorgate about 20 years ago that brought the Bank branch of the northern line to a halt for about 10 minutes during the morning peak.
At the time I wondered if the person involved had a curry the night before.
Egg Centric
6 Oct 2018
Land of the Prince Bishops
Any "creative bottle usage" as an alternative a la "trucker's tizer"? I'm fairly sure they do in mainline trains. Harder to see that working on the tube though, but maybe? Could use a funnel to make it easier while using the deadman's device...
Lockwood
4 Apr 2013
I saw something years ago, possibly on this forum, saying how some drivers prefer to drink Oasis over other bottled drinks as they have a larger aperture to aid with reuse.
9 Dec 2012
Would any of the central London Yerkes stations like Covent Garden /Russell Sq have toilets at platform level for drivers?
Howardh
17 May 2011
You could alsways invest in one of these
Good for ladies and gents apparently.
That is exactly what I have - just in case! But when out in public there's having it, and using it! Wouldn't like to be a tube driver caught short with see-through cab windows* and trying to relieve in one of those - but law of averages suggests that some of the older drivers will have postrate issues and need to use emergency equipment on occasion?
*Admits, where the cab is on a tube train there's a low chance of a passenger being in that area, unless it's a station with access point there.
sprunt
22 Jul 2017
Is it not a legal requirement for all workplaces to have toilets?
Daniel
5 Oct 2005
Yes, though if a drivers’ workplace were determined to be their cab and therefore a toilet needed, the same would apply to every bus and taxi I imagine, plus on a bike for a Deliveroo driver!
chuff chuff
25 Sep 2018
Indeed lucozade have a similar wide opening.
