Class 231 - ultimately a fleet of 11 destined for Cheltenham Spa / Ebbw Vale to Cardiff / Maesteg replacing 170s to EMR (but possibly initially to be used on the Rhymney line to release 769s for scrap until the 756s arrive).What routes is it destined for?
Your picture shows the unit to be 231011.Can someone identify this Stadler that I saw at Bristol Parkway on test recently?
Basic point is that they aren't intended to run to Bristol, just a convenient place to run proving runs to.
The runs are to both Gloucester (via Chepstow) and Swindon (via Severn Tunnel) at the moment - my assumption would be that the Swindon runs allow for faster mileage accumulation whereas the Gloucester ones are used to test the units on their future route.Presumably, if the paths are available to use, TFW (and whoever is conducting the testing for TFW) have decided to continue conducting the milage runs to Swindon instead of Gloucester.
The TPE mk5s (and possibly 397s) went all the way down to Rugby on the WCML during testing.Within reason, trains are tested where ever they can be pathed most easily. If the intention is simply to cover a set mileage quickly then they can end up well outside their future operating area. I think a couple of years ago it was reported here that some dual voltage LO stock was seen south of Gatwick, and also well up the WCML.
