St Pancras to Brighton
prd101
15 Jun 2008
York
I'm planning to travel tomorrow from St Pancras to Brighton. Does anyone know if St Pancras and/or Brighton have ticket barriers? I'll be making a quick change from Kings Cross and ideally would like to buy the ticket on the train, is this possible with First Capital Connect?
dan_atki
1 Nov 2006
Both St Pancras and Brighton have barriers (albeit St Pancras only has barriers for FCC services). Tickets for travel with FCC must be bought before travel as per their penalty fares rules.
Judging from your post you are travelling into King's Cross by another train. If you haven't got a through ticket I'd suggest buying one from the station you start from (the one where you are travelling to King's Cross from).
prd101
15 Jun 2008
York
thanks, i thought as much. actually getting a Grand Central ticket from York to Kings Cross. Can't seem to find through fares for Grand Central unless it's changed
dan_atki
1 Nov 2006
Ah - the Any Permitted is available but is much more expensive! If you arrive at York in plenty of time you'll be able to buy a St Pancras to Brighton ticket there before travelling into London :).
Coxster
9 Jun 2005
...ideally would like to buy the ticket on the train, is this possible with First Capital Connect?
FCC Thameslink (and most if not all Great Northern?) services are driver only operated, so you won't be seeing a guard to buy a ticket from anyway. Might see some RPIs though... ;)
Waverley125
2 Sep 2008
Leeds, West Yorkshire
going from peterborough-Brighton on the 17th-is this ticket valid for the tube journey from LKX-Victoria? Website isn't bringing up any interchange for FCC-Brighton at LKX.
EM2
16 Nov 2008
The home of the concrete cow
There's no interchange on that date because of the Thameslink programme blockade. Not sure about Tube to Vic but it will be accepted on the Tube to London Bridge, which is where the FCC journeys start from
http://www.thameslinkprogramme.co.uk
hairyhandedfool
14 Apr 2008
The Peterborough to Brighton "walk up" tickets are routed "+Any Permitted", indicating that they are valid for cross London transfers using the London Underground.
class 313
10 Dec 2005
St Albans
All FCC services are DOO with RPI officers :)
FCC tickets are accepted on the tube and buses whilst the blockade is on.
True. But if it's an FCC only ticket, then it will only be accepted to LB, not Vic. If it's AP, then it's no problem.
There are no FCC only tickets for through journeys from the Great Northern route to the southern part of the Thameslink route. For cheaper FCC only tickets you'd need to split tickets in London. If doing a day return there are substantial savings to be made doing this.
yes you can use the tube from KGX to VIC (LKX doesn't exist).
MCR247
7 Nov 2008
All of STP has ticket barries as such, but the MML & Bedford services from 1-4 are manned ticket barriers
MCR247
7 Nov 2008
Well fine then but the EMT ones do. FCC use 4 normally I think. I'll check when I go down
EM2
16 Nov 2008
They're using p.1 during the blockade. And the barriers are manned, in the sense that there's someone there but they don't check tickets (being ultra pedantic ;) )
MCR247
7 Nov 2008
They check tickets on EMT services, and railcards
class 313
10 Dec 2005
St Albans
Lets step this up a notch, Most the time FCC use platform 4 but the last couple of weeks have seen platform 1 be used instead. ;)
Whenever I travel on EMT, they check on board heading south but heading north they just rely on the barrier check at St Pancras.
I have been checked both ways, though saying that more so when heading towards London.
16CSVT2700
4 Sep 2005
Gdansk
Platform veg.
I've been checked both ways multiple times, however several times using services that get into London about 10pm they don't usually check tickets.
EM2
16 Nov 2008
Mais non, mon ami :D
When the blockade was weekends only, they were using P.4 but since the full blockade, including evenings and more frequent weekend trains, has been in place they've decided to use P.1 as it offers more flexibilty (apparently).
So, unless there are unforeseen circumstances, FCC will use P.1 between 222:30 and 04:30 Mon-Fri and all weekend.
class 313
10 Dec 2005
St Albans
Oh cool, thanks for that mate.
paul1609
28 Jan 2006
K
To be honest as a regular traveller from South of London to Kings Cross I wouldn't recommend FCC unless the Victoria line is closed. The journey is now always quicker by tube.
When St Pancras International first opened I used FCC quite a bit but now the novelty of the new station has worn off the reality is that the tube and a Southern service from Victoria is always more convenient and comfortable.
I'm not sure if its the distance or the pedestrian flows but Kings Cross to St Pancras International Low level seems to take about 5 mins longer than Kings Cross to Kings Cross Thameslink used to take. There also seems to be a fairly lengthy pathing allowance at Blackfriars these days on Brighton services.
Of course once you get to Victoria you get a comfy 377 with air conditioning, 2 +2 seating and trolley buffet on many services compared with noisy and often pretty dirty 319s with uncomfortable 3+2 seating on FCC.
