St Pancras Thameslink lift refurbs
flitwickbeds
19 Apr 2017
Just received an email from Thameslink about the St Pancras lift refurbs booked in from 15 June until mid-September 2026.
In the email, it states:
While the work is taking place, if you need lift access to or from the Thameslink platforms and cannot use escalators or stairs, you will still be able to access St Pancras International station but will need to use an alternative nearby station with step-free access as part of your journey.
(Their bold)
What on Earth do they mean?
Russel
30 Jun 2022
Lichfield
(Their bold)
World class communication from a world class railway...
Dr Hoo
10 Nov 2015
Hope Valley
(Their bold)
King’s Cross, Farringdon, Finsbury Park, West Hampstead… perhaps?
Dr Hoo
10 Nov 2015
Hope Valley
None of which allow you access to St Pancras lnternational without going via the Thameslink platforms - which are without a lift...
I think you’re making un-necessarily heavy weather of this. All trains at St P Thameslink also call at Farringdon. Step free interchange with LUL Circle/ Hammersmith/ Met back to King’s Cross St Pancras. Step free interchange back up to all parts of St Pancras (and vice versa).
OneOfThe48
6 Mar 2023
Yep, if you need to go specifically to St Pancras (e.g. need to connect between EMR and Thameslink), you should use TfL services another station, like Farringdon, to do that step-free
fandroid
9 Nov 2014
Hampshire
Which immediately poses the question - why on earth doesn't the email list those step free alternatives? It's not as if the alternative is too complex to describe in words.
I think that lazy email is appalling. Dumping the problem onto the passenger who has already been severely inconvenienced by the up escalators being dead for months.
Taunton
1 Aug 2013
This is "Artificial Intelligence" writing it. Which has an initial go but some are then too lazy to edit it and just pump it out as is.
OneOfThe48
6 Mar 2023
I'd expect the quoted section is immediately followed by a direction to check their website for all the alternative routes they have listed, which vary depending on the journey being made
https://www.thameslinkrailway.com/s...s/st-pancras-international-lift-refurbishment
Alternative step-free routes to or from St Pancras International​
If travelling to St Pancras International from short-to-medium distance stations on the Bedford route (from stations between Harpenden and West Hampstead Thameslink)
Use Thameslink services to Farringdon, changing there for London Underground to King’s Cross St Pancras
  • Use your regular Thameslink service, but travel to Farringdon
  • Change at Farringdon for westbound Circle, Hammersmith & City or Metropolitan line services to King’s Cross St Pancras
If travelling to St Pancras International from longer-distance stations on the Bedford route (from stations between Bedford and Luton Airport Parkway)
Use alternative EMR services to St Pancras International
  • Use an EMR service from Bedford, Luton or Luton Airport Parkway, which use platforms 1 to 4 at St Pancras International
  • If travelling from stations in between Bedford and Luton, you will need to use a Thameslink service and change for an EMR service to St Pancras International
If travelling to St Pancras International from stations on the Peterborough or Cambridge routes
Use alternative Thameslink or Great Northern services to London King’s Cross
Alternatively, you can change at Finsbury Park for London Underground services to St Pancras International
  • Use your regular Thameslink service but alight at Finsbury Park
  • Change at Finsbury Park for westbound Piccadilly line or southbound Victoria line services from Finsbury Park to King’s Cross St Pancras
If travelling to St Pancras International from stations in Central London or south of London
Use Thameslink services to travel to Farringdon, then change for London Underground
  • Take a Thameslink service to Farringdon
  • Change at Farringdon for westbound Circle, Hammersmith & City or Metropolitan lines to King’s Cross St Pancras
If travelling from St Pancras International to short-to-medium distance stations on the Bedford route (to stations between West Hampstead Thameslink and Harpenden)
Use London Underground to Farringdon and change there for onward Thameslink services
  • Use eastbound Circle, Hammersmith & City or Metropolitan lines from King’s Cross St Pancras to Farringdon
  • Then change at Farringdon for a northbound Thameslink service
If travelling from St Pancras International to longer-distance stations on the Bedford route (to stations between Luton Airport Parkway and Bedford)
Use alternative EMR services from St Pancras International
  • Take an EMR service from platforms 1 to 4 at St Pancras International
  • These services call at Luton Airport Parkway, Luton and Bedford, so you will need to change for an onward Thameslink service if you require stations in between
If travelling from St Pancras International to stations on the Peterborough or Cambridge routes
Use alternative Thameslink and Great Northern services from London King’s Cross
  • Exit St Pancras station and follow signs to London King’s Cross
  • Use Thameslink or Great Northern services (you may be required to change trains at a station en-route to reach your destination)
Alternatively, you can travel to Finsbury Park via London Underground and pick up onward Thameslink or Great Northern services from there
  • Use eastbound Piccadilly line or northbound Victoria line services from King’s Cross St Pancras to Finsbury Park
  • Change at Finsbury Park for onward Thameslink or Great Northern services
If travelling from St Pancras International to stations in Central London or south of London
Use London Underground to Farringdon and change there for Thameslink services
  • Change at Farringdon for southbound Thameslink services
Please note, there may be times when these alternative routes are not available, so always check your route before travelling.
Harratt4
12 Nov 2024
I suspect not as AI would have done a better job.
Humans have a tendency to start writing a sentence assuming the reader has the same context and knowledge that they do and that everyone is reading it having started in mentally the same place as them - and so they end up writing things like this that don't make sense to those who do not. AI doesn't tend to.
Though as OneOfThe48 says, if it is accompanied by "click here to find out more" then it probably works fine. It is hardly gold standard communication either way, though.
RGM654
19 Jul 2022
Harrow
The availability of step-free access at other stations on Thameslink is one thing. The perplexing thing about the quoted email is "you will still be able to access St Pancras International station". What does that mean?
Bishops
16 Feb 2026
Bishop Auckland
it means you can still use the station for your journey
Russel
30 Jun 2022
Lichfield
Agreed, the information isn't passenger friendly, especially if you're not a frequent user of St Pancras Thameslink.
But poor communication from the railway isn't new and seems to be getting worse...
whoosh
3 Sep 2008
"London St Pancras International (STP) is a striking blend of Victorian engineering and international high-speed travel. Known as the "Cathedral of the Railways", this architectural masterpiece is the UK gateway to Europe, bustling with over 50 million passengers annually.
Some of these 50 million passengers will not be able to use the lifts from the Thameslink platforms, which are being overhauled - making them unavailable to all, not just those with disabilities.
Passengers can still board and alight at the Thameslink platforms, but will be unable to access the other parts of the station.
To access other parts of the station from the Thameslink route, passengers will need to change onto other services, such as London Underground, at other stations on the Thameslink route.
After not riding the lift, but using the stairs or escalators instead - or diverting via another step free accessible route - to the upper reaches of the station, be sure to look out for the John Betjeman statue - In a clever architectural nod, the billowing tails of his trench coat were intentionally sculpted to mimic the exact curve of the station's arched roof."
Only took me a minute. Bit of AI fluff, some actual carefully considered information, and more coherent than the official messaging.
Boom.
Mike drop.
OneOfThe48
6 Mar 2023
Yes, coherent is exactly what comes to mind when reading this
I can get off the train but cannot access other parts of the station? So just stuck on the platform until the lifts come back?
whoosh
3 Sep 2008
Well, you can still change trains there, as the train to platforms are step free.
Although... must those trains be in the same direction? As there are lifts to the intermediate landings. And a lift from there to the surface.
So maybe it wasn't coherent.
It isn't coherent. I... I... Malfunction!!!!
OneOfThe48
6 Mar 2023
Maybe the lesson is partial quoting and semi-obtuse reading can make anything seem confusing
Russel
30 Jun 2022
Lichfield
2 Minutes using Copilot produced a more customer friendly statement...
Service Update – St Pancras Thameslink
The lifts serving the St Pancras Thameslink platforms are currently out of service. Passengers who require step‑free access are advised to use Farringdon station as an alternative.
We apologise for any inconvenience caused and appreciate your patience while we work to restore full accessibility.
vuzzeho
11 Apr 2022
The lifts serving the Thameslink platforms at St Pancras International are currently out of service while we refurbish them. This will be going on until XX/XX/2026.
While this is taking place, St Pancras International will have no step free access from Thameslink. The rest of the station will be operating as usual.
If you require step free access to/from Thameslink services at St Pancras International, we recommend changing trains at Farringdon, where there is step free interchange between Thameslink and the London Underground, and taking the Metropolitan/Circle/Hammersmith and City line one stop to Kings Cross St Pancras, which has step free access from the train to the street, the Piccadilly, Northern, and Victoria lines, and other National and International Rail services.
For further details and alternative options, please check our website or contact us.
Just came up with that off the top of my head. But I'm no copywriter.
7 Jan 2010
I'm interested in whether they will remember to turn off those naggy AI vision screens moaning at you for taking large luggage on the escalators during the work (which I guess will magically become safe to do for three months before becoming unsafe again)
Mikey C
11 Feb 2013
As an aside, it's a shame that the Thameslink platforms are so cut off from the rest of the station, with just one entrance and no connection to the Underground, unlike the old Kings Cross Thameslink station.
Considering an underground passageway connects the Underground northern ticket office directly to STP, it's a shame that it wasn't possible to continue this to the Thameslink platforms.
Haywain
3 Feb 2013
There really should be more than one entrance/exit to the platforms. It gets really difficult when any of the escalators or lifts are out of action.
Dr Hoo
10 Nov 2015
Hope Valley
“Wasn’t possible” being the key words. The interchange subway runs in a trench constructed from outside the King’s Cross train shed to outside the St Pancras approach viaduct, i.e. not interfering with critical historic structures.
PZ 08895
12 Apr 2022
Horsham
Re there should be more than entrance/exit to the platforms, there are actually fire escape routes by staircases towards both ends of both platforms, which access the street. However, not used for public use, except in an emergency.
