Spraying of lines white.
Paul’s
8 Mar 2019
Woodsmoor, Stockport
Hi, just a quick question, while walking near Woodsmoor level crossing, on the Manchester to Buxton line. I noticed the rails have been sprayed white. And was just wondering why...thanks ...
hexagon789
2 Sep 2016
Reflects heat, reducing the temperature of the rails. You see it in lots of places, most of the lines into Glasgow Central are sprayed white for instance.
matabiau
16 Jun 2012
Toulouse, France
You may have noticed that (in the UK) it is normally the southern face of the rail thats is painted white! That's how I deduced what it is for. Appears to be a very cheap and effective solution to avoid a potentially dangerous and expensive problem.
hexagon789
2 Sep 2016
I'm fairly certain the ones I've seen are painted both sides I think.
matabiau
16 Jun 2012
Toulouse, France
Points and crossovers are mechanically more rigid than sections of uninterrupted rail which have expansion gaps to aleiviate this problem anyway. Points will be less tolerant to extremes of temperature.
themiller
4 Dec 2011
Cumbria, UK
At Limestone Hall crossing on the Cumbrian coast line, the rails were sprayed white on both sides and when I asked why, I was told that it was to try to reduce corrosion from salt applied to the road in winter.
themiller
4 Dec 2011
Cumbria, UK
Are you suggesting the sun never shines in Cumbria? :D
White paint could be an economic solution to many ills.
We've just had our meals in the garden today whilst my brother-in-law in France said that it's been wet all day in Charente today. But to get back to the white paint, most of the rail which was painted is hidden away from the sun by the rubber road sections with only a few feet sticking out either side. Since the rail was only sprayed on the roadside before being installed, I don't know how long it'll last. I'd have thought that it'd be longer lasting if the painting had followed blasting in a controlled environment.
Boodiggy
8 Nov 2012
You are talking about two different things here.
Rails - normally S&C - are painted to help combat CRT issues in the hot months. This is just white paint.
The rails installed through level crossings etc have a special coating applied to resist corrosion. As well as level crossings these will be installed in other wet areas such as tunnel.
themiller
4 Dec 2011
Cumbria, UK
The original post asked in relation to level crossings. I'm only talking about rails through level crossings so I believe that I'm still on topic!
Deepgreen
12 Jun 2013
Gomshall, Surrey
Level crossings are not particularly wet, so is the anti-corrosion treatment a response to winter road gritting/salting?
Boodiggy
8 Nov 2012
Yes, although the level crossing systems will mean a bit of water can build up around the rails to.
furnessvale
14 Jul 2015
Points and crossings in lengths of CWR are strengthened so the stresses are controlled.
There are no intermediate expansion joints in CWR, which can be many miles long. Breather switches are fitted at the extreme ends as the last 100 yards needs to be able to move. However, it can be useful to fit such breather switches in the plain line approaching a major terminal so that all the subsequent switches and crossings can be unstrengthened, making them cheaper and easier to fit and maintain.
Usually, the rails aren’t painted as such, but pre-coated with a resin. This handy guide form British Stel has a little more detail. https://britishsteel.co.uk/media/40827/rail-product-guide.pdf
It is to prevent corrosion. Whilst local authorities are encouraged not to spread salt when crossing an LX, there is of course plenty of salty water on the approaches which is dragged onto the crossing by passing traffic. I’ve seen some quite significant rail corrosion at level crossings.
Deepgreen
12 Jun 2013
Gomshall, Surrey
Have you seen any rails with holes in them from corrosion?! Oh no, not that again!
I have. Running rails. Line blocked immediately!
Fortunately, conductor rail doesn’t suffer from corrosion at level crossings ;)
Shimbleshanks
2 Jan 2012
Purley
Does painting switching and crossing rails white also have a secondary benefit in making them easier for per-way staff to see them in the dark? I'd always imagined that was the reason until I came on this forum, to be honest.
boing_uk
18 May 2009
Blackburn
Would it not be easier and cheaper to just have the rail sprayed white at manufacturing?
Painting by hand seems an inefficient use of resources.
furnessvale
14 Jul 2015
Thanks to brake dust, oil etc, the white paint barely lasts one summer. Therefore new rail would have to be repainted each spring. Most of the new rail would be laid in areas not requiring paint and it would be wasted.
Better that paint is applied each spring where required but I would have thought spraying from a Windhoff platform would be more efficient.
