Split tickets Liverpool Street to Ipswich
dave75
29 Apr 2016
For the 16.30 departure from Liv St to Ipswich i want to check the below combination of tickets will be valid.
Liverpool St - Chelmsford (weekly season ticket). Chelmsford - Manningtree (super off peak return). Manningtree - Ipswich (off peak return).
Train does not stop @ CHM.
Yes that would be fine. Non-stop splits are permitted when one (or both) of the tickets is a season ticket, zonal ticket, ranger or rover. Then you are performing a second split at a station stop.
Mcr Warrior
8 Jan 2009
Take it that this is essentially a same day return journey as what the OP describes as a "Super Off Peak Return" (from Chelmsford to/from Manningtree) and an "Off Peak Return" (from Manningtree to/from Ipswich) will both be day return tickets?
P.S. Wouldn't an Off Peak Day Return from Chelmsford to/from Ipswich at £27.20 not be slightly cheaper (unless the OP is perhaps hoping to use Network Railcard discount on the Chelmsford to Manningtree leg)?
P.P.S. The 16:30 midweek Greater Anglia departure from London Liverpool Street (for Norwich) is first stop Colchester, then Manningtree, Ipswich, Stowmarket, Diss and Norwich. Doesn't normally ever call at Chelmsford and so runs fast through there.
