dotdash1979
- Joined
- 31 Jan 2014
- Messages
- 8
Hi, I'm looking at commuting to work in the near future and the season ticket is almost £2000. but I've worked out if I can save almost £200 by doing the following.
Journey is from New Pudsey to Rochdale
My plan is to get a West Yorkshire metro card for rail zones 2 -5 and use that to Walsden, then buy a national rail season ticket from Walsden to Rochdale.
The only issue is that only some services will stop at Walsden and the rest pass through. The train I want to get will pass through, can I still do a split ticket or dose the train have to stop in order for it to work?
I've been looking at the NRCOC, and I'm not sure.
19. Using a combination of tickets
You may use two or more tickets for one journey as long as together they cover the entire journey and one of the following applies:
(a) they are both Zonal Tickets unless special conditions prohibit their use in this way. The Ticket Seller will, if you ask, advise you whether you can use a Zonal Ticket in combination with another ticket.
(b) the train you are in calls at a station where you change from one ticket to another;
or
(c) one of the tickets is a Season Ticket (which for this purpose does not include Season Tickets or travel passes issued on behalf of a passenger transport executive or local authority) or a leisure travel pass, and the other ticket(s) is/ are not.
Another cheaper option is NR season tickets for New Pudey to Walsden then Walsden to Rochdale but I think the train has to stop there for this to work. However the Metro pass is a zonal pass so section c will work.
or
