jrayfield21
Does anyone know the speed limits for the different lines at the station in Rugby? Thanks.
See the Sectional Appendix, https://sacuksprodnrdigital0001.blob.core.windows.net/sectional-appendix/Sectional Appendix full PDFs September 25/London North Western (South) Sectional Appendix September 2025.pdfDoes anyone know the speed limits for the different lines at the station in Rugby? Thanks.
I thought voyager EPS speeds had disappeared and been replaced with MU speeds or is it that MU is also limited to 100 on the down fast?Alternative version of the same document here: https://vaildata.uk/sa?lor=MD101&seq=029&name=RUGBY&alt=MD101-029&alt=MD101-030&alt=LNW(S)2&alt=MD105-007
Down Coventry (Platform 1) 60mph
Down Fast (through line) 100/EPS (Tilting trains) 115/125
Down Slow (P.2) 75
Platform 3 line 25.
Up Fast (P.4) 100/EPS125
Up Northampton (P.5) 75
Up Slow (P.6) 60
Speeds shown in mph for primary direction of travel through the platforms themselves. Down = Northbound, Up = Southbound, wrong-direction moves are possible at 40mph for all lines except Down Fast.
Slightly out of date however!Alternative version of the same document here:
No MU speed through the station.I thought voyager EPS speeds had disappeared and been replaced with MU speeds or is it that MU is also limited to 100 on the down fast?
No, however its still out of date, not for the specific question by the OP but they may then want to look elsewhere and so I think its important to mention.Not through the platform area itself, unless I'm reading the document wrong?
Sectional Appendix is the bible. Nothing else counts when it comes to baseline infrastructure.No, however its still out of date, not for the specific question by the OP but they may then want to look elsewhere and so I think its important to mention.
Fair enough.No, however its still out of date, not for the specific question by the OP but they may then want to look elsewhere and so I think its important to mention.
I think @louis97 was meaning that the OP may want to check other areas of the network, and that the VailData's sectional appendix is the December 2024 version so now may be out of date where other areas have been amended.Sectional Appendix is the bible. Nothing else counts when it comes to baseline infrastructure.
Quite!I think @louis97 was meaning that the OP may want to check other areas of the network, and that the VailData's sectional appendix is the December 2024 version so now may be out of date where other areas have been amended.
Pendos are 125mph through both UFL and DFLThanks for the responses, I feel like most trains going past platform 4 (UFL) are going fairly slow compared to the DFL, even the pendolinos which i would assume would be going 125mph.
It's possible there is a Temporary/Emergency Speed Restriction (TSR/ESR) or that they were being signalled through under restrictive aspects (e.g. double yellow).I understand that, but even today I saw pendolinos consistently go past platform 4 much slower than on the DFL
If they have come from Coventry, it’s 75 through the crossover onto the up fast.I understand that, but even today I saw pendolinos consistently go past platform 4 much slower than on the DFL
I hope it is more evidence-based than the bible.Sectional Appendix is the bible. Nothing else counts when it comes to baseline infrastructure.
100 TSR at Trent Valley Junction for route towards Coventry. Has been there quite a while now.Nice, I was there from 1pm to 25 past. Saw some fast ones on the DFL but not P4
Compare the layout as well. 1 big island platform with mid-platform 'scissor' crossovers on the through platforms and bays in the middle, IIRC. Somewhere at home I've got an old Quail showing it.Compare this to the pre-remodel days of BR in the 80s. 60mph max I think on the through lines.
Having just done a quick google search it appears the Scissors are an even older layout!Attached says May 1973, revised 1976. From my collection.
The scissors were part of the original design of the new station in the 1880s.Having just done a quick google search it appears the Scissors are an even older layout!
