Speed limiters on new build cars
dakta
18 Jun 2008
Depends what circles you're in
Really wish it was as specialised as it used to be - often it's just a value in flash memory that can be updated with clone kit off eBay
It's like having your playstation chipped these days
29 May 2008
Featherstone, West Yorkshire
my limiter is a pain (Thanks Peugeot). You have to click the thing 10 times to change 10mph. Why. Are there any 35mph speed limits? It is an old car tho. one click for each 10 mph would do it.
If you hold the button it should increase/decrease in intervals of either 5 or 10mph.
mmh
13 Aug 2016
Lots of 5mph "limits" on private land like car parks. Other countries might have speed limits in fives - the only place I know of though is the USA.
One click being 5mph would still be better than it being 1mph.
1mph jumps are good in cruise control mode if you don't have adaptive, but aren't needed in limiter mode because you can just lift off.
Ediswan
15 Nov 2012
Stevenage
Two uses for single digit increments to a speed limiter setting:
All* correctly working speedometers over-read to some extent. Setting a value slightly higher than the limit can be used to compensate.
Driving abroad, so you can set the equivalent of a kph speed limit using mph units, or vice versa.
* Under-reading is not allowed. Perfection is allowed, but very unlikely to exist.
paul1609
28 Jan 2006
K
No. First point is you can actually do 77mph. Second point is there are situations where going beyond such speeds is acceptable (taking someone in your vehicle to A&E in an emergency, for instance) if the road and conditions are suitable. Third point is where do where the line is drawn with who doesn't need a limiter. Fourth point is vehicles that produce co2 are going the way of the dodo anyways, so what's the point? Fifth point is criminals and people who aren't ones for following the rules of the road, will find ways around such limiters anyways, so again, what's the point?
Emergency services, the aforementioned reason, fleeing from a life endangering incident, overtaking a
Do you think that all new cars should be fitted with a speed limiter of 75mph from the build? The two main benefits are obviously improved road safety and also reducing pollution/saving fuel as a result of vehicles not being impacted so much by air resistance and lower revving of the engine.
I think 70mph would be a little too low as sometimes people need to speed up and go above the road limit to get out of the way and avoid a potential accident, so 75 or 80mph would help in this way. However, there is no reason anyone should be travelling above 80mph, so why not have speed limiters on all new cars for the reasons given?
You
I think 70mph would be a little too low as sometimes people need to speed up and go above the road limit to get out of the way and avoid a potential accident, so 75 or 80mph would help in this way. However, there is no reason anyone should be travelling above 80mph.
There are roads within 35 miles road miles of my home that have a legal speed limit of 81 mph 130 km/h, can those of us that live in Kent have our limiters set higher? (like our trains)
Any mandatory limiter would need to be 130km/h as that is the normal motorway limit on the mainland. I don't think there is anywhere in Europe where there is a higher limit (Autobahnen are advisory 130).
Ediswan
15 Nov 2012
Stevenage
Should a speed limiter also have rain/moisture sensors to recognise the reduced 110 km/h 'wet weather' limit in France? For that matter, has anybody ever found the applicable definition of 'wet weather' ?
In case its not obvious, I do have concerns that some drivers will misunderstand that the mandated systems are 'Intelligent Speed Assist' and expect these systems to do all the work.
Increasingly the likes of "smart motorways" will define that by showing a limit.
Trackman
28 Feb 2013
Lewisham
Another thing to think about is what about those of us who do track days etc.? Clearly a speed limiter would render them a bit pointless. Why should we be penalised because some people can't stick to the law and drive at the speed limit on the road?
Some performance cars in Europe do have a top speed limiter (some daft top speed) but the GPS can suss out when it's at a track and switches it off.
Is this still a thing? I knew there was a trial a while back.
philthetube
5 Jan 2016
Any decent software engineer with a laptop would be able to 'tweek' the limiter in seconds just like they remap cars (including mine) at the moment.
And anyone taking advantage of this could be subject to a ban.
I think they should be introduced though my reasons are different to any other mentions on here. They would cause reductions in crime as capturing criminals would be much easier.
87 027
1 Sep 2010
We discussed the pros and cons of this in your previous thread and I think we came to the view that the technology was nowhere near foolproof enough at the moment :)
gg1
2 Jun 2011
or the M40 in Oxfordshire / Warwickshire, or the M6 north of Lancaster!
Outside rush hours, add the M5 south of junction 3 to that list too.
IME drivers speeding at 90+mph is pretty common on any motorway or NSL grade separated dual carriageway where the traffic is free flowing enough to allow it, to the point I would regard driving more than half hour or so along such roads and NOT seeing it as unusual.
depends on the camera situ. Plenty of those on the M5 south of J3.
stuu
2 Sep 2011
I think it's a lot less common than it used to be, especially with petrol prices being the way they are. Anecdotal obviously, but last time I made a long motorway journey a few weeks ago I never went above an indicated ~75mph, and hardly anything overtook me, which I thought was unusual
gg1
2 Jun 2011
Fair point, IIRC there are variable speed cameras between J4a and 6 then again around Bristol.
It does vary admittedly but in my last long distance drive, to Swansea (M5>M50>A40>A449>M4) 6 weeks ago, there were definitely a few cars which zoomed passed me when I was cruising at 65-70mph. I make the short hop from J3 to J4 of the M5 2-3 times per week on average, not uncommon to see the same there too.
Deepgreen
12 Jun 2013
Gomshall, Surrey
None of this will change the fundamental thing - that most people don't care about the environment, fuel efficiency or the effect that their speeding has on others, etc. Limiters will be disabled by idiots who think it's clever to drive fast, etc. There will always be those who bleat about their human rights being curtailed because they cannot do exactly what they please, when they please, where they please. The behaviour of people in their cars is a sure-fire indicator of the sort of people they are, and it's usually very depressing.
