Speculation: What the GWML could look like post Electrificaion and Crossrail
Rich McLean
6 Feb 2012
Ok, so I was a bit bored and I can imagine this would gain interest.
Nobody knows quite what the GWML will look like post IEP introduction. What we do know is Crossrail will have all the paths on the RL apart from the 2 Oxford Stoppers as far as Maidenhead. The HeX express paths cannot be altered. I think we could end up with something looking like the below on the Mains. Also we now know that all 80x will be Bi-mode. I was interested in what the final product would would like
xx00 - Weston S M (RA BPW) (125mph)
xx03 - Bristol TM via Bath (125mph)
xx06 - Plymouth/Penzance via Desert (125mph)
xx10 - Hex (100mph)
xx15 - Cardiff (Carmarthen in peaks) (125mph)
xx18 - Newbury (110mph)
xx22 - Oxford (125mph) - Stops at Slough
xx25 - HeX (100mph)
xx30 - Bristol TM (RA BPW) (125mph)
xx33 - Bristol TM via Bath (125mph)
xx36 - Wesbury/Exeter/Paignton (125mph)
xx40 - HeX (100mph)
xx45 - Swansea (125mph)
xx48 - Cheltenham (125mph)
xx52 - Worcester/Gt Malvern/Hereford (125mph - Stops at Slough)
xx55 - Hex
With Peak extra Queue buster paths
xx12 - Oxford (first stop Twyford) - 110mph
xx27 - Reading/Didcot (first stop Maidenhead) - 110mph
xx42 - Swindon (first stop Twyford) - 110mph
xx57 - Reading/Didcot (first stop Maidenhead) - 110mph
Those extras can be switched to the RL at Maidenhead East. This is where the xx00, xx15, xx30 and xx45 will overtake (and no doubt be checked down on approach). No other way of fitting them all in, but the capacity is needed. Most of these could be 12 cars to try and entice Reading commuters off the longer distance services.
Peak Variations
xx00 - 5 off peak, 10 car peak
xx30 to be 2x5 car in the peak, and split at BPW, with one portion off to Cardiff. Also these will run fast to Bristol Parkway non-stop
Plymouth/Penzance - Mostly 10 cars, with 5 cars between Plymouth and Cornwall off peak, 9 or 10 car through services in the peaks.
The idea of running the two Bristols one in front of the other is to manage loadings better, so all passengers going to Bristol and beyond directed to the Fast via PW service, and those for stations in between put onto the service 3 minutes later, which stops at all the usual places. Additionally, those services via Bath could be advertised as "Bath Spa" at Paddington to deter Bristol punters away. Gives passengers at stations in between more chance of a seat. Run them 15 mins apart, and one train will be overcrowded, while the flyers lightly loaded.
One thing I do know is that NR will want to avoid a major change the current pattern, to avoid a near nationwide timetable re-write (if you change the WoE pattern, you mess up XC, change the SW diagrams, you mess up ATW. Rewrite XC and AW, and that could mean re-writes further north).
Can anyone to better than that or have any other wacky idea's
Legend:
BPW = Bristol Parkway
Hex = Heathrow Exrpess
TM = Temple Meads
Desert = Berks & Hants line between Reading and Taunton avoiding Bristol.
Disclaimer: This is a Trivia thread, so nothing set in stone, none of the above has a bearing on what will actually happen in reality.
Just pointing out that what I put is not to be considered as Fact. It's not a negative
Sorry but you definitely have written a double negative, as I shall explain.
none of the above has no bearing.
This should be written as "none of the above has a bearing"; or "the above has no bearing".
NoMorePacers
18 Feb 2016
Humberside
It's a common thing in Hull, I myself avoid it where possible but I here many people say it without consideration.
David Goddard
8 Aug 2011
Ely
A good plan, along the lines of what I had thought up myself. Had been wondering about the spacing of the Bristols, and didn't think of this pattern, which would work well, and indeed is what I used when I did my fantasy East Coast pattern so should have got that too!
I can see this working throughout the day, with only a few extras for peaks as you identify so well done!
In addition, I would suggest that:
*All WoE operate through to Penzance, apart from the last couple which would terminate at Plymouth.
*xx22 Oxford, as a bi-mode, extended to Banbury, Leamington, Solihull and Birmingham Moor Street
*At least three services to and from Carmarthen each day. (0530,0730 & 0930 in and 1515,1715 & 1915 back)
jimm
6 Apr 2012
You seem to forgetting the rather minor detail that in the peaks there are basically 2tph to/from the Cotswold Line via Oxford - and there will likely be one or two more trains in that category post-December 2018.
Never mind that about the last thing that is needed on the railways right now are yet more trains between London and Birmingham - nor is it GWR's job to bail out XC between Reading and Birmingham.
David Goddard
8 Aug 2011
Ely
Not really expecting GW to bail out XC, more like additional connectivity and greater benefits for the customer. If anything with two TOCS this could help drive fares the right way too. With trans of 2x5 car a split at Oxford could still happen and send half to Birmingham and half to Worcester.
In any case:
cactustwirly
10 Apr 2013
You're missing 2tph to Oxford (semi fast to Reading, then local stopping service)
Rich McLean
6 Feb 2012
In any case:
It would be a waste of stock, which will be needed to provide as many 2x5 car sets as possible in the peaks.
With Plymouth to Cornwall going 2tph, it may look like the below
London - Plymouth/Penzance
0706 - Penzance (2x5 Car - Splits at Plymouth) Ply a 1010 d 1015
0806 - Plymouth (5 Car) arr 1123
0906 - Penzance (2x5 Car - Splits at Plymouth) Ply a 1206 d 1212
1006 - Plymouth (9 Car) arr 1323
1106 - Penzance (2x5 Car - Splits at Plymouth) Ply a 1406 d 1412
1206 - Plymouth (9 Car) arr 1523
1306 - Penzance (2x5 Car - Splits at Plymouth) Ply a 1610 d 1615
1406 - Plymouth (2 x 5 Car) arr 1723
1506 - Penzance (2 x 5 Car - Splits at Plymouth) Ply a 1810 d 1815
1606 - Penzance (9 Car) Ply a 1923 d 1930
1706 - Penzance (2 x 5 Car) Ply a 2010 d 1615
1806 - Penzance (9 Car) Ply a 2123 d 2130
1906 - Penzance (2 x 5 Car - Splits at Plymouth) Ply a 2220 d 2225
2006 - Plymouth (5 Car) arr 2325
London - Westbury/Exeter/Paignton/Plymouth
0733 - Paignton (5 Car)
0833 - Westbury (5 Car)
0933 - Exeter St D (9 Car)
1033 - Westbury (5 Car)
1133 - Exeter St D (5 Car)
1233 - Westbury (5 Car)
1333 - Paignton (9 Car)
1433 - Westbury (5 Car)
1533 - Exeter St D (5 Car)
1633 - Westbury (2x5 Car)
1733 - Paignton (2x5 Car - 5 Car Exeter - Paignton)
1833 - Plymouth (9 Car)
1933 - Plymouth (2x5 Car - 5 Car Exeter - Plymouth)
2033 - Plymouth (5 Car)
2133 - Exeter St Davids (5 Car)
Cardiff - Paignton/Plymouth/Penzance
0555 (Bristol) Paignton
0655 (Bristol) Penzance (PLY a 0935 d 0937)
0755 (Bristol) Exeter St D
0800 Penzance (PLY a 1135 d 1137)
0900 Paignton
1000 Penzance (PLY a 1335 d 1337)
1100 Exeter St D
1200 Penzance (PLY a 1535 d 1537)
1300 Paignton
1400 Penzance (PLY a 1735 d 1737)
1500 Exeter St D
1600 Plymouth arr 1935
1700 Paignton
1800 Plymouth arr 2135
1900 Exeter St D
2000 Taunton
2100 Bristol TM
2200 Bristol TM
Plymouth - Penzance
0543 - Sleeper
0602 - GW 80x
0628 - XC
0650 - GW Local
0737 - GW Semi-Fast (Ex Exeter)
0750 - GW Local
0815 - GW 80x
0850 - GW Local
0937 - GW Semi-Fast (ex Bristol)
0950 - GW Local
1015 - GW 80x (ex London)
1050 - GW Local
1137 - GW Semi-Fast (ex Cardiff)
1145 - GW Local
1212 - GW 80x (Ex London)
1250 - GW Local
1337 - GW Semi-Fast (ex Cardiff)
1345 - GW Local
1412 - GW 80x (Ex London)
1450 - GW Local
1537 - GW Semi-Fast (ex Cardiff)
1550 - GW Local
1615 - GWR 80x (Ex London)
1650 - GW Local
1737 - GW Semi Fast
1750 - GW Local
1815 - GW 80x (Ex London
1840 - GW Local
1900 - XC
1930 - GW 80x (Ex London)
1949 - XC
2015 - GW 80x (Ex London)
2050 - XC
2130 - GW 80x (Ex London)
2150 - GW Local
2225 - GW 80x (Ex London)
jimm
6 Apr 2012
What additional connectivity? There are already plenty of services available to passengers wanting to travel between Oxford, Banbury, Leamington and Birmingham - so unless such a service would be there to bail out XC, what passenger benefit would there be?
Just in case you haven't noticed, there already is a choice of TOC available to passengers between Banbury, Leamington and Birmingham.
There might be additional connectivity and passenger benefit if the odd GWR service extended between Oxford and Stratford-upon-Avon, as that would be something different, rather than more of the same.
So the thread says trivia in the heading? So what? Doesn't mean things posted here somehow get a free pass from being commented on.
Says who? You could move them around the clockface to your hearts content if you wanted and everyone agreed.
xx10 - Hex (100mph)
xx25 - HeX (100mph)
xx40 - HeX (100mph)
xx55 - Hex
Taking into account this is a trivia thread, even with ERTMS following at 2 minutes to Heathrow Airport Jn it's going to be tight with the peak extras. The following trains will get hammered as will the xx.18, xx.33, xx.36, xx.48, xx.03 and xx.06.
The other slight flaw with the crossing at Maidenhead is where are the trains in the other direction? And to be fair, getting 18 trains out in an hour just requires a minor burp to collapse.
It is the TOCs that will reject it, not necessarily us.
Rich McLean
6 Feb 2012
I understand that, and as put on Fridays, with the xx12 Friday peak extras.
The only issue I can see running proposed extras such as the planned 12 car 387s to Swindon, is finding somewhere to put them. There won't be any room on the Relief's until past Airpot Jn, and if running non stop on the fasts right the way though, surely you would need 125 mph capable stock, unless you jiggled it around completely during the peaks and start Bedwyns back from Reading and use that path for the Swindon peak queue busters (fast to Reading)
Change of peak then
xx09 - Swindon (peak extra)
xx11 - Hex (100mph)
xx25 - HeX (100mph)
xx29 - Bristol TM (RA BPW) (125mph)
xx32 - Bristol TM via Bath (125mph)
xx35 - Wesbury/Exeter/Paignton (125mph)
xx38 - Oxford (Peak Extra)
xx41 - HeX (100mph)
xx55 - Hex
Yes moving a few of the HeX forward by 1 minute will allow an 110mph path ML only to leave 2 minutes before. However, that only gives the xx15 4 minutes behind the HeX
Plus 2tph Oxford on the RL, but the RL timetable will change so much with crossrail that it is hardly worth predicting at this stage.
If there is a cough in the peak, then you cancel the xx18, xx09, xx38 to create breathing space. Or if still not enough room, have no peak extra's and change the x18 to run to Swindon in the Peak, and run Reading - Newbury in its place, connecting from the Swindon Train.
Ianno87
3 May 2015
I believe the *exact* 15 minute depature interval of HEx from Paddington is a contractual right, as is the 15 minute Down direction journey time to CTA. A 14/16 interval would not be accepted.
Rich McLean
6 Feb 2012
If that is the case, peak then
xx10 - Hex (100mph)
xx18 - Swindon (110mph) - Connects with a Newbury train at Reading. Calls at Twyford
xx25 - HeX (100mph)
xx38 - Oxford (Peak Extra) Calls at Maidenhead
xx40 - HeX (100mph)
xx55 - Hex
You will struggle to fit anything else in
