Chiltern006
- Joined
- 3 Oct 2018
- Messages
- 809
I think that TfL should take over the SE metro services that dont run out of the Zones e.g VIC-ORP, CST-CRY, CST/CHX-HYS and so on
You make some good points. Oyster to Sevenoaks is long over due.Sevenoaks <> Cross is an important link. There are plans to extend Oyster to Sevenoaks which may keep the service within the zones.
Gravesend/Rainham is also something to think about. You also have a fair amount of 'Metro' services run by SE up from Gravesend. Population density and passenger flows almost requires Gravesend to be considered 'Metro' How do you break up SE Metro from Gravesend?
Gravesend certainly is a Metro station but could be broken up by having metro services start closer to London and have the mainline services call instead. Orpington is similar and does have a few mainline services stopping there at times. The HS service in a way already does this.
Gravesend and the Medway towns may lose their HS services...
Really???
How come? I though HS services were set to stay along Medway and Gravesend?
Well this is something totally dependent on whether or not capacity exists in St Pancras and along the High Speed Route for both the Medway and the Ashford / East Kent stuff. Realistically, with stock at a premium and capacity pretty much maxed out you may have to decide to just do the Ashford bit (Folkestone, Dover, Canterbury etc) and then run a few extra classic trains to Victoria, Blackfriars, Cannon Street (wherever) from Medway.
The extra fast classic trains suggested would mitigate HS service removal from the Medway towns and beyond, but the likes of Gravesend, Strood (and possibly Maidstone) would be harder hit as the said classic services won't serve them. Of course if proposals to link Northfleet and Ebbsfleet in the Garden City development are completed eventually then maybe that won't be so bad. However from what I can tell that's a long way off (The HS1 connection to Gravesend might also need a Parlimentary service if nothing else uses it).Well this is something totally dependent on whether or not capacity exists in St Pancras and along the High Speed Route for both the Medway and the Ashford / East Kent stuff. Realistically, with stock at a premium and capacity pretty much maxed out you may have to decide to just do the Ashford bit (Folkestone, Dover, Canterbury etc) and then run a few extra classic trains to Victoria, Blackfriars, Cannon Street (wherever) from Medway.
It's also worth pointing out that a sizeable portion of HS usage is people driving halfway across Kent to Ebbsfleet to go into London; I know people in my office who do it occasionally and have seen it more widely when using the station. If classic line services can be improved in speed and capacity you could reduce the demand on HS services![]()
