Hopefully a fairly straight forward set of questions:
If I get a travelcard with a "Southern only" restriction on it, would the restriction only apply to the journey outside of the travelcard zones?
ie:
Havant to Victoria would be correct and valid.
Havant to Waterloo via Guildford would be invalid.
Would Havant to Clapham Junction via Horsham, then Clapham to Waterloo be valid?
Assuming that it is valid as a normal travelcard once you get into London: If the Clapham to Waterloo section was done on a service that had called at Havant, would this open you up to potential allegations of using a ticket outside of its validity if the guard did a check near the end of the journey? Would the onus be on them to prove that you were travelling "incorrectly" or on you to prove that you had boarded from within London?
ie:
