I think the taking out of services from Clapham Junction to Brighton was due in part to the fact of possibly not having the paths, but also of having enough stock for such a service with the class 455 units being taken out and the class 313 units soon to be leaving, it leaves Southern with the few class 171 units, plus class 377 units and the spare class 387/2 Gatwick Express units not being use don either Gatwick Express or Great Northern Services.
Should Clapham Junction & Redhill get a direct service to Brighton?
If stock and paths where available, yes in an ideal world. Otherwise, you would have to lessen the services to Eastbourne, Hastings and Ore. But people are more likely to be commuting from Brighton, Eastbourne, Hastings and Ore to Central London, than somewhere like Clapham Junction. You may ask well why are they going to East Croydon then, well there is quite a few businesses based in East Croydon that people certainly pre - covid commuted too.
Should Three Bridges get more services (i.e maybe removing Wivelsfield from one of the Ore / Eastbourne services and adding Three Bridges) thus improving connections for Crawley & Horsham to the coast
Wivelsfield has a Thameslink service Monday to Saturday that stops there every 30 minutes in each direction. Plus has a Southern service in each direction every 30 minutes to/from either Eastbourne or Ore.
Three Bridges gets Southern services from Southampton Central, Portsmouth, Bognor Regis. It also get Thameslink services from Brighton or Horsham all of which are travelling too or from Bedford, Cambridge or Peterborough.
So you want to worsen the services for Wivelsfield to say one Thameslink and Southern service an hour? If not, then as I have stated above paths would be required if possible and more stock than the DFT are currently allowing Southern to use now and in the future.
Should the Southampton Service be altered due to poor performance (i.e the common pining of the service at Fareham)
Which Southamptom service are you referring too? The service to London Victoria, which previously started in Bournemouth originally years ago or the service to Brighton? I believe that there is a Southern service that operates Southampton to Horsham as well?
I would alter the services from Littlehampton, rather than the services from Southampton. I know that the services from Littlehampton quite often join services that have come from Eastbourne or Ore at Haywards Heath. However, if capacity allows I would have both trains go through Haywards Heath and do the coupling of the trains at Three Bridges. Haywards Heath is pretty well served by Thameslink services and I don't believe there is as many people commuting to work in Haywards Heath nowadays as there once was previously. I would say that there is more people needing to get to Three Bridges/Crawley areas than Haywards Heath. I say this as someone that many years ago use to have to commute from Newhaven to Haywards Heath for work.
Should Gatwick be removed from more peak services to improve capacity for commuters (probably unlikely unless more services are introduced?)
Okay, not sure of what the flight pattern of arrivals of planes are at Gatwick nowadays. But if there is quite a few flights in the peak hours, it is possible that not all those passengers are going to be want to be travelling to London or Brighton and would want to pay the fares that is charged by using Gatwick Express. Yes, Thameslink does serve Gatwick as well as Southern. Is there anywhere that the Southern services maybe calling too, that Thameslink services do not call at and vice/versa for that matter? For those peak time services where only Southern or Thameslink services only call at those places but also call at Gatwick Airport, how long would someone have to wait between services? What are the numbers of people travelling from/to those places during peak hours?
For instance as an example, if someone that lived in say Plumpton works in Gatwick doing a 9am - 5pm job. If you cut out Gatwick during peak hours, how would that person living in Plumpton get to/from work, if you cut out services travelling say between 7am - 9am and 4pm - 6pm stopping at Gatwick?
Yes, maybe cut out some services to/from Brighton at peak times from stopping at Gatwick, but not services that have come from more rural areas.
