Class 466
The revised BFR service from may is now showing: https://www.realtimetrains.co.uk/se...-0159?stp=WVS&show=pax-calls&order=wtt&toc=SE
No but of course they will say we put on this service and it wasn't well used so its being withdrawn then they can forget about the Maidstone East line again for another decade. As Talking Heads sayIs there really any point in a 3-hourly service?
From looking at that timetable it seems that trains are going to be sitting around in the platforms at London Blackfriars for long periods of time. For example a train that arrives at 13:35 and leaves at 14:40 meaning that it spends over an hour in the platform. It just seems like a waste of resources to me. Maybe if the trains were not having such long turnarounds then the service could be more frequent.The revised BFR service from may is now showing: https://www.realtimetrains.co.uk/se...-0159?stp=WVS&show=pax-calls&order=wtt&toc=SE
That’s probably to allow the PNB for the crew.From looking at that timetable it seems that trains are going to be sitting around in the platforms at London Blackfriars for long periods of time. For example a train that arrives at 13:35 and leaves at 14:40 meaning that it spends over an hour in the platform. It just seems like a waste of resources to me. Maybe if the trains were not having such long turnarounds then the service could be more frequent.
You couldn't fit in a 4th round trip with the one unit.Maybe if the trains were not having such long turnarounds then the service could be more frequent.
I think it goes empties to Herne Hill turnback in the meantimeFrom looking at that timetable it seems that trains are going to be sitting around in the platforms at London Blackfriars for long periods of time. For example a train that arrives at 13:35 and leaves at 14:40 meaning that it spends over an hour in the platform. It just seems like a waste of resources to me. Maybe if the trains were not having such long turnarounds then the service could be more frequent.
The platform allocations are slightly misleading, the Herne Hill turnbacks are separate diagrams and look like route retention for metro drivers.I think it goes empties to Herne Hill turnback in the meantime
Technically it uses 4, the 1139 Blackfriars - Maidstone arrives at 1244 after the 1232 Maidstone - Blackfriars so uses two sets of 2 class 377s. The current pattern looks to be for efficient crew diagrams as there's enough stock in sidings between peaks.Can this service ever aspire to being run by more than a single unit? Is that in the conditions?!
...and (ignoring the platform numbers on RTT) both run ECS from/to Ashford.Technically it uses 4, the 1139 Blackfriars - Maidstone arrives at 1244 after the 1232 Maidstone - Blackfriars so uses two sets of 2 class 377s.
That is the same as service running now.The revised BFR service from may is now showing: https://www.realtimetrains.co.uk/se...-0159?stp=WVS&show=pax-calls&order=wtt&toc=SE
Indeed it is. It’s revised back from the originally uploaded 1tph.That is the same as service running now.
Interestingly, if you look at the terminste and start times at MDE, they appear to be using two pairs of 377s when they could cover the present service with one.Indeed it is. It’s revised back from the originally uploaded 1tph.
See #369 and 370 upthread.Interestingly, if you look at the terminste and start times at MDE, they appear to be using two pairs of 377s when they could cover the present service with one.
Be gone by September as they will need to release the 377's back to SouthernSo the Southeastern time table confirms it, the 2 tph service to Blackfriars has gone the same way as the Thameslink Cambridge service leaving nothing more than the pointless 3 hourly off-peak service.
They won't be, just the stock that works them will probably change.Be gone by September as they will need to release the 377's back to Southern
back to a scruffy Networker no doubtThey won't be, just the stock that works them will probably change.
Seen a networker recently in Ashford depot which was unusual so potentially.back to a scruffy Networker no doubt
Yes this hourly frequency mid week between peaks is annoying, especially as they seem to be able to have a 2tph service on Saturdays at the moment.Does anyone have any idea when the off peak Victoria to Maidstone service is going back to half hourly - if it is.
We now have this ludicrous 3 hourly off peak Blackfriars service and hour gaps in the afternoon at Victoria.
If that's the plan, I'm surprised they're not doing this 3 hourly Blackfriars' service at the moment, as this would provide traction knowledge recall, as Networkers have not had a presence on the MDE line since 2020 for their peak extras.back to a scruffy Networker no doubt
I had heard from somebody at Southeastern that the hourly off peak service was now permanent and the 3-hourly Blackfriars service was offered as a kind of compensation. Which of course it isn't, and it is very likely to be withdrawn for lack of use.Yes this hourly frequency mid week between peaks is annoying, especially as they seem to be able to have a 2tph service on Saturdays at the moment.
I think the plan is to go back to 2tph from December 2022 through to Victoria along with 1tph from Maidstone East to an as yet to be announced location.I had heard from somebody at Southeastern that the hourly off peak service was now permanent and the 3-hourly Blackfriars service was offered as a kind of compensation. Which of course it isn't, and it is very likely to be withdrawn for lack of use.
I thought the reduction was COVID related, but the 2tph service on Saturdays and these extra Blackfriars trains seem to prove that wrong.
I can't find anything anywhere that suggests the half-hourly off peak will return or when it will.
Anyone know anything else? Are they allowed to permanently reduce frequency - doesn't the specification call for 2tph ?
Pretty much as the pre 2009 service then and a chance to get a 50 minute service into Cannon Street or Charing Cross again.I think the plan is to go back to 2tph from December 2022 through to Victoria along with 1tph from Maidstone East to an as yet to be announced location.
It won't be going that way.id hope it goes via bromley south and the mid kent line. will give bromley commuters a much simpler journey to theatreland without needing the tube
There are 2 Thameslink tph between Otford and St Mary Cray. You can defintley fit in another 1tph including all the freight too.Will there be capacity between the TL stoppers between Otford and St Mary Cray? If so, guessing the new service would then take the spur up to Chislehurst?
back to the routing the Cannon St service had 30 years ago then. needs to be half hourly really to be of use for onward Tlk connections.There are 2 Thameslink tph between Otford and St Mary Cray. You can defintley fit in another 1tph including all the freight too.
Yes, you are correct regarding the second point.
