South Wales electrification
YorkshireBear
23 Jul 2010
I'd love to see how long it takes before this becomes a reality.
Remember that it took 15 years of campaigning before electrification of the Birmingham Cross City line became a reality.
My guess is that nothing will be done before 2020.
Yes but that was when railways weren't a massive priority. Electrification and indeed the rail network are much higher up the list at the moment which means campaigning can have more effect and require less time to be succesful. Especially as Valleys have a pretty good case.
Nym
2 Mar 2007
Somewhere, not in London
The thing is, with the electrification in the pipeline, with some clever timetable changes one can get away without ordering any new Diesel commuter stock for a while and still clear all Class 142 units off the rails. (Assuming no growth)
I'm working from:
GW Electrification
Lancs & Liverpool Triangle
TPE North to York and Hull (Not Middlesbrough) with associated tiny additional bits.
GW Electrification by internal cascade can clear all pacers outside of the North of England by cascade of turbos with "No Growth", growth can be catered for by adding in the Thames Valley Branch Lines.
Lancs & Liverpool clears a fair few Diesel diagrams when properly completed (from Northern, TPE have already internally cascaded theirs, my last count was 24 diagrams)
Hazel Grove - Preston: 4 Dia.
Victoria - Blackpool: 3 Dia.
Liverpool - Wigan: 4 Dia.
Liverpool - Blackpool: 4 Dia.
Airport - Liverpool (Path to TPE): 3 Dia.
Victoria - Liverpool: 3 Dia.
Liverpool - Warrington BQ: 3 Dia.
Then some clever timetabling and alternate service provision also clears...
2 Dia from Wigan - Victoria via Bolton (Split the route at Bolton, via Westhaughton is suitable for 'Exempt' Pacers for additonal savings on sprinters)
Southport - Airport is planned to move to via Atherton, units can be saved from this route by provision of better services via Eccles.
All in all, you're looking at (including maintenance capacity) about 30 - 35 units.
TPE North has two aspects to it, the TPE fleet re-assignment and Northern direct unit saves.
Direct Saves for Northern come in at (With sensible infill, some routes are split)
Leeds - York: (Nothing directly, as these all run from other places, and will proberbly continue to, such as York - Blackpool running onto Scarborough and a Calder Valley service running onto Middlesbrough)
York - Hull: 2 dia.
Selby - Leeds: 2 dia.
Leeds - Huddersfeild via Dewsbury: 2 dia.
Victoria - Huddersfeild: 2 dia.
Then Hull Trains can send it's 180s down to FGW to free more turbos and provide capacity down there, or use them within TPE for Middlesbrough services, whatever.
So thats 10 units directly replaced.
TPE has it's fleet of 51 + 9, with these needing to stay...
Cleethorpes - Manchester Airport (Divert to Liverpool Lime Street via CLC) 10 dia.
Chances are we will still have some direct Barrow services, but lets assume not for now, makes the numbers look better if we say it's a Turbostar running from Preston, esp. with the Scottish services going hourly, also assuming Electrification of the Windermere Branch.
The following services would then go to 185 operation (line quality improvments permitting, also trying to keep things close to existing depots.)
Scarbrough - York 1tph 1 dia.
Blackpool North - Scarbrough 1tph 9 dia.
Manchester Airport - Manchester Victoria - Calder Valley - Bradford - Leeds - York - ?Middlesbrough 1tph 8dia.
Chester - Manchester Victoria - Calder Valley - Bradford - Leeds 1tph 5 dia.
Buxton - Manchester Piccadilly 1/2tph OP/Pk journey times under an hour, express via Hazel Grove (Picc - Stockport - Hazel Grove - Stations to Buxton) 4 units.
Sheffeild or Doncaster - Manchester Airport via Hope Valley and Victoria 7/8 Dia. (Possibly the all stations service)
That leaves 6 maintenance spares, and has replaces about 40 of Northern's diagrams, some of these doubled up so one can assume about 50 units.
Totals then comes in at 95 units saved, not counting Turbostars.
So the Welsh Valleys coming in between 2020 and 2025 would be in time to replace the worst of the 150s and some of the remaining pacers, or a smaller order of say, 30 odd Class 172s would be plenty, provided the above projects are done by 2020.
Rhydgaled
25 Nov 2010
ValleyLines electrification by 2020 would release 30 Pacers directly, I don't see how cascaded 165s and 166s from GW electrification could provide 30 DMUs that are suitable for the Valleys to release those Pacers if the Valleys aren't electrified. Depending on how much of the Valleys network is electrified (I think that's the question now, not will it be done at all), ATW might be able to shed 8 150s to release GW's Pacer allocation of 8 units. Some of the 165s/166s released could work some of the lines east of Newcastle/Darlington, and if cleared some could provide additional capacity on local services around Bristol or Exeter (depending on how much around Bristol is electrified).
PhilipW
6 Feb 2008
Fareham, Hants
It is interesting to note that in comments by the DfT and by ministers it is referred to as 'South Wales Electrification' rather than 'Valley Lines Electrification'. A neat touch as that will allow them to re-instate Swansea electrification without it appearing as a U-turn.
I'm happy with that
Nym
2 Mar 2007
It is interesting to nate that in comments by the DfT and by ministers it is referred to as 'South Wales Electrification' rather than 'Valley Lines Electrification'. A neat touch as that will allow them to include Swansea electrification without it appearing as a U-turn.
I'm happy with that
Fingers crossed it could mean just everywhere in South Wales, now all we need is to drag in engineers from Germany and get the whole damn lot done in the next 7 years...
Great Western, South Wales, Lancs Triangle, Transpennine...
Then we can scrap the idea of the Bi Mode IEP, use life extended HSTs for a little longer until the likes of Chester - Crewe, Midland Mainline and Edinbrugh - Aberdeen are completed, freeing enough 125mph DEMUs for the GW to replace HSTs.
sprinterguy
4 Mar 2010
Macclesfield
With reference to Nym's plan, I agree with this view. I can never see 165s or 166s being cleared to operate the branch lines in Devon and Cornwall, so it is unlikely or impossible that a cascade of 165s to the West Country, operating regional services, out of Bristol, will release a proportional number of 150s for use by ATW as FGW will still have a need for 150s on the branches.
Displaced 165s are, however, more likely to lead to the withdrawal FGWs' eight class 143 Pacers by releasing a few 150s within FGW than through ATW releasing 150s.
I've done a more detailed analysis of my take on Nym's proposals. Admittedly I do tend to err on the side of caution when it comes to calculating the number of units released by electrification projects. However, in assessing these figures I have taken a more aggressive line than in my own electrification driven Pacer replacement scheme, although I still come up with a number of units replaced less than that necessary to replace all the 142s. Which still of course leaves the, admittedly better quality, 143s and 144s to worry about.
I'm working from:
GW Electrification
There's still going to be a requirement for a small number of Network Turbos to operate the Thames Valley branches, as you correctly state: It has been previously calculated on this forum that this could equate to eleven or twelve diagrams; allowing for some services being formed of pairs of units, for the sake of argument I have left the 21 x 3-car class 166s allocated to Thames Valley services.
This leaves 36 class 165s to cascade to Bristol area regional services, 16 x 3-car units and 20 x 2-car units. As a nice tidy piece of maths I have assumed that this would be sufficient to allow FGW to lose its' 20 x class 150/2 units to ATW, while FGW retain the 18 x class 150/1s that they currently operate in order to operate the various branch lines where 165s are unlikely to be cleared: Bearing in mind here that particularly during the summer months a number of trains on the Devon and Cornish branches are formed of pairs of units.
20 x class 150s is certainly enough to rid ATW of it's 15 x class 142s, but not enough to rid it of its' entire 30 strong Pacer fleet. I will conservatively assume then that ATW will retain its' 15 x class 143 Pacers, as the additional 5 x 150s over that required to replace ATWs' 142s could surely be used for strengthening, although I have also provided that ATW could gain FGWs' two remaining 2-car 158s so that they don't have to resort to using 150s on long distance regional work.
I concur absolutely with your figures for the number of diagrams replaced by North West electrification. However, as an aside it is worth noting that Newton Heath maintain and operate 44 class 142 Pacers, so the numbers you have stated fall well short of the numbers needed to replace all of Newton Heaths' Pacers, and it has also been said that the North West electrification will not see any units withdrawn: They will be used for strengthening elsewhere.
York - Hull: 2 dia.
Isn't that eight units? Or did I miss something? So that's two Newton Heath 142 or 150 diagrams, we'll say for the sake of argument that it's two 142s replaced, and about half of the Heaton 142 diagrams that operate in Yorkshire, assuming that as York to Hull is principally 158 operated these two units will be able to find a home replacing other units on other Northern services.
The problem with some of these routes, Blackpool North to Scarborough particularly, although only from York at present, is that they are presently 158 operated, and you can't just keep cascading 158s further down the chain to replace more commuter or rural specified stock on less and less suitable work. As for the proposed York to Scarborough shuttle, this is already operated by a 185 as part of a longer distance service, so releases nothing. Finally, irrelevant of what sort of frequency you might be proposing for a Hope Valley all stations service, in reality the present Hope Valley all stations Northern service only equates to a total of three or perhaps four all-day diagrams.
Valley Lines electrification is urgently needed then as one of the most effective ways of replacing Pacers: That would be 30 units gone, and FGWs' eight 143s finished off by GW electrification, in one go.
Nym
2 Mar 2007
Yes, I am VERY aggressive with DMU withdrawls, I tend to change routes and cut them in half quite a lot.
For example, Wigan - Bolton - Victoria would be chopped in half at Bolton, all through services going via Atherton, or possibly retaining a Southport or Kirby service via Bolton to keep Westhaughton connected direct to Manchester, either way, there would only be three DMUs per hour between Manchester and Wallgate, all going onwards to Southport or Kirkby.
This would be due to the majority of Wigan - Manchester traffic now being served by a twice hourly EMU from Wigan North Western to Manchester Victoria / Exchange (This does rely on more platforms on the Victoria campus at 'Exchange' and grade speration of Ordsall Lane Junction)
Yeah, I don't know if Turbos would continue on them lines or not, if we assume they are, then I would have the 36 165s replacing vast chunks of the Bistol fleet, displacing 150s to ATW to replace their 143s and 144s, and replacing FGW's 143/4 units. The maths fits all but one unit, line clearances I don't know that much on around that area, but one assumes they will fit down the entirety of the GWML and that several DMU services will be replaced by EMUs anyway. I've always treated the removal of pacers from the SW and Wales as isolated from the rest of the network's projects, as the numbers do fit nicely. If there isn't enough space within the loading gauge for 165 and 166 units on the other lines to displace them to, then we can send some of these to Chiltern and nick their 168 and 172 units in exchange.
It does fall short for Lancs Triangle of NH's allocation of pacers, but if the projects were up to me, I'd have included Lostock - Wigan Wallgate in the electrification plans, for diversionary route etc, removing more pacers (not many more, but every little helps) and I'd be looking at examining routes that run as diesel under wire for a long way, and looking to curtail these routes.
Eg.
Does Barrow really need a service to Manchester?
Buxton to Manchester running fast to Hazel Grove via Stockport, reducing the stock requirements from local passengers on the service, and therefore the stock requirements.
I'd also be looking at other operators who sin by running Diesel under wires (Yes, I'm looking at you ICWC) to free rolling stock from their operations for routes that need Diesel stock.
TPE wise, yeah, I forgot how to add there, but again, hacking routes to pieces can free up more units than one would expect otherwise.
And with regards to the cascade downwards of Class 158 units onto frequent stopping duties, one is assuming that exchanges can readily be made with operators of Class 156 units (Scotrail) that are more appropriate for frequently stopping services.
But the thing is, pretty soon there won't be any stock suitable for frequent stop diesel services, 156s aren't ideal, 153s are useless, and 150s need a major refurb now to last until 2035 otherwise they'll be dead by 2025.
The York - Scarborough Shuttle would be in addition to York - Blackpool to give Scarborough 2tph to York.
But anyway, Valley Lines is needed, of we added this to the list of projects I think we might be stored for this no more diesel thing, (Including Bi Mode IEP) provided we get the Midland Mainline done soon enough to cover the loss of HSTs from the GW (Only so many will be converted with power doors and life extended again)
PhilipW
6 Feb 2008
Fareham, Hants
I do hope you are not planning to visit Barrow soon. If you do I think the Barrowians will be giving you a very clear response.
Taking away through trains for purely operational reasons is not a view that goes down well with customers.
Nym
2 Mar 2007
The're doing it with Bolton and Chorley...
Bolton will loose it's direct service to Southport and one and a half of it's four trains per hour to Piccadilly soon due to Electrification.
Airport - Southport to be diverted via Atherton
Airport - Scotland / Barrow services cut to 1tp2h or less only to Barrow via Bolton.
That will cause more people inconvenience in one morning rush hour than a whole week of people needing to change at Lancaster for Manchester from Barrow.
Rhydgaled
25 Nov 2010
12 diagrams, taking maintenance into account that'd be about 14/15 units wouldn't it? Could you redistribute centre cars to keep 14/15 longer units for the Thames Valley services, and cascade the rest as 2-car units?
The ValleysLines are looking like being electrified, so Wales doesn't need any more 150s, 31 is quite enough for the rest of Wales if the valleys are electrified. 150/2s are more useful than 150/1s (150/2s can do portion working and you don't need to double-staff 4-car trains).
Then why do 153s work the HOWL? I think it is probably too long (time wise) to be a 150 route though. 156s on HOWL maybe? LM's 172s are probably the best stock out there for frequent stop diesel services that are shorter than HOWL.
Wales has 150s working on services they shouldn't be used on quite often, and I expect GW does too. Both TOCs really need more 158s and perhaps some 156s. If everything in south Wales (except west of Swansea) is electrified, then 8 of the 31 150s can go (either to release GW's 8 Pacers or to Northern if internal cascades from the Thames Valley take care of the GW Pacers). From a quick guess, only about 7 of the 23 remaining Welsh 150s will be needed on current 150 routes, but improved frequencies in various places and/or Cardiff - Cheltenham if it isn't electrified would up that a bit. Anyway, if not all 23 150s are needed I'd suggest exchanging the surplus, plus the 8 153s for a fleet of 156s for HOWL and perhaps Pembroke Dock - Swansea (which accounts for 3 of 7 150s I mentioned as being needed for the remaining Welsh 150 routes, the other four are Wrexham - Bidston (2 units) Crewe - Chester and Conwy Valley - did I miss anything?). I'd say this swap should be 1 156 for each 150 or every 2 153s (so the 8 153s would give Wales 4 156s in return).
As for IEP, I think the biggest problem might the number (and hence cost) of the additional 11-car Pendos needed to release the current 9-car sets to take over the ICWC Voyager routes, plus the 172 vehicle pantograph car order needed to create a fleet of 22x bi-modes (that converts all the units, adding 1 pantograph car to each 4-car unit and 2 panto cars to the longer units, resulting in the following fleet):
  • 40x 7-car bi-mode class 221s (80 pantograph cars required)
  • 4x 5-car bi-mode class 221s (4 pantograph cars required)
  • 34x 5-car bi-mode class 220s (34 pantograph cars required)
  • 8x 8-car bi-mode 222s (16 pantograph cars required) and
  • 19x 7-car bi-mode 222s (38 pantograph cars required)
anthony263
19 Aug 2008
South Wales
The only problem is that I dont think the class 156's are cleared for the heart of wales and Pembroke dock branch as well as the Fishguard branch.
Ideally for those routes a 2 carriage class 155 or two class 153's will be suitable for those lines although I dont think ATW have that many class 153's and they are likely to be re-formed back into 2 carriage units once they are refurbished to meet DDA legislation.
You could send some class 150's to east anglia in exchange for their class 153's I suppose
tbtc
16 Dec 2008
Reston City Centre
I'm working from:
GW Electrification
As things stand, places like Hull and Henley aren't being wired.
Yes they *should* be, but we still need more electrification (than is currently committed to) to deal with Pacer replacement *and* growth.
Eg.
I agree with Nym here.
There's a difference between "want" and "need". Everyone wants a direct link to London from their local station, everyone wants a direct link to Manchester Airport from their local station etc. However you then end up with a messy and inefficient set of services.
We cannot cater for every flow (however small), and sometimes it's worth cutting a direct service (used by few people from end to end) to focus resources on busier routes (e.g. cutting the Barrow - Manchester through trains would allow the Preston - Bolton - Manchester services to be longer (i.e. run by EMUs).
Since we don't have the resources to link everywhere we need to focus them on the busiest passenger flows.
(but this is nothing to do with Wales, and quite off topic!)
Gareth Marston
26 Jun 2010
Newtown Montgomeryshire
With the Welsh Government not making any financial contribution to electrification I wouldn't get too worked up about possible cascades and Pacer replacements yet. Its not a done deal by a long shot.
Without a contribution from WG I can't see the Valley Lines (i.e services through Queen St) GWML to Swansea plus Masteg/Ebbw Vale all being done in CP5/6.
DynamicSpirit
12 Apr 2012
SE London
Barrow is quite a sizeable town which is very badly served by rail as it is given the population. I think you could also make quite a strong argument for the economy in the local area having suffered quite badly because of its remoteness and relatively poor transport links.
The line to barrow also passes through quite a several individually smallish but cumulatively significant centres of population (Carnforth, Grange, Ulverston), and serves as one route to get to Whitehaven and Workington from the South. The line also has quite a rare selling point in competitiveness re the car: Thanks to the bridge over the Kent (there's no corresponding road bridge until you get quite a bit further inland), it could potentially offer much shorter journeys between several towns than is possible by road.
So for all those reasons, I'd say that line ought to be a priority for seeing how we can improve the service - not start taking away what little service it has.
Eagle
20 Feb 2011
Leamingrad / Blanfrancisco
Network Rail seem to think that Hull is getting wired. Page 202 of this document, published about six weeks ago.
CP4 Delivery Plan 2012 said:
Project definition: North Trans-Pennine Electrification
Network Rail’s obligation
Our obligation, to be confirmed by DfT, is to develop the scope of works described below to completion of GRIP Stage 2.
Scope of works
A client remit has been produced detailing the scope required for this project. This includes AC overhead electrification and associated power supplies / distribution for the following routes, including all running lines and crossovers (except where indicated):
  • Manchester Victoria to Stalybridge Junction;
  • Guide Bridge West Junction to Copley Hill East Junction via Huddersfield;
  • Neville Hill West Junction to Colton Junction;
  • Micklefield Junction to Selby Station;
  • Ashburys West Junction to Philips Park Junction/Baguley Fold Junction;
  • Guide Bridge Station Junction to Heaton Norris Junction;
  • Selby Station to Hull; and
  • a number of further add-on options will be examined/costed up in addition to those noted above.
Other works will include signalling immunisation, track lowering and bridge reconstructions on the above routes.
Nym
2 Mar 2007
None of this tells me why it needs a service to Manchester?
Also; why it wouldn't be better served by an hourly shuttle from Preston or Lancaster rather than a two hourly service to Manchester....
There are at least five other towns I can think of that suffer from economic hardship that don't have a service to Manchester, that are closer to Manchester than Barrow, so what's so special about Barrow, other than the BAE Systems site?
Batman
27 Jun 2011
North Birmingham
Wasn't a closure notice served on the Barrow line as recently as the mid 1990's?
Batman
27 Jun 2011
North Birmingham
Looking at this in the wider scheme of things, is it realistically possible that the WG will assist with funding for valley line electrification?
After all, the WG doesn't exactly have a 1st class reputation for allocating funds to transport projects and I thought the WG biggest priorities for transport in South Wales is to get the GWML electrification extended through to Swansea and for the long-overdue completion of the upgrading of the A465 Heads of the Valleys Road?
anthony263
19 Aug 2008
South Wales
They have already started work on upgrading the A465 and the WG could possibly request assistance from the EU or if given new powers borrow money taking advantage of the uk's low interest rates.
Batman
27 Jun 2011
North Birmingham
The history of the A465 upgrade scheme goes back to per-devolution days. The decision to proceed with the scheme was made by the Welsh Office back in 1995 and the scheme has been enacted in fits and starts since then. It's not due to be completed until 2020, and even then, as things stand at the moment the section between Merthyr and Aberdare will still be single carriageway because funding has not yet been allocated for dueling.
I think all in Wales will be able to breath a sign of relief when it's finally finished.
But because of the recession of the special social and economic circumstances in the Valleys, and the cancellation of the M4 Newport by-pass, this should be seen as the most urgent transport project in Wales.
DynamicSpirit
12 Apr 2012
SE London
Fair points. I guess the real answer depends on how many passengers would want to be travelling through from Manchester (or near Manchester) to stations on the Barrow line - and I'm also guessing that information isn't publically available. It seems to me though that Manchester has become the effective commuter hub for much of NorthWest England, sufficient that trying to ensure that every sizeable town in the northwest has some kind of direct link there, in much the same way that there are very few towns in the SouthEast that are on the railway but don't have some kind of direct service to London. I'm not sure which 5 towns you were thinking of, but I'm guessing they include
Barrow's is current timetable quite messy - weekdays it appears to have a two-hourly service from Manchester but not to Manchester.
I think an hourly shuttle to Lancaster or Preston would certainly be worse than the current situation because you'd be making at least some people change trains who don't currently have to, but without providing any improvement for anyone else. If you could have a half-hourly service to Lancaster, with alternate trains continuing to Preston, then that would definitely be a net improvement.
Greenback
Emeritus Moderator
9 Aug 2009
Llanelli
Many people prefer through trains because it is disruptive to have to change, even if it is a relatively simple cross platform one. The fact is that anyone who is working on the train, or even just reading, listening to music etc has got to uproot themselves from the train they are on, and settle themselves on to another train.
Add in the extra time for the journey, plus the fact that a person may struggle to find a seat on the train they are getting on, and it's easy to se why so many travellers who currently enjoy a through service are rather loathe to give it up!
IanXC
Emeritus Moderator
18 Dec 2009
I'm not sure about junction names, but does that seem to imply that the old ECML into Selby will not be electrified?
Hopefully this covers it!
CP4 Delivery Plan said:
 a number of further add-on options will be examined/costed up in addition to those noted above.
Rational Plan
3 Aug 2011
Changing is not a big deal on a metro system because the trains are every few minutes.
I'm an anxious traveler, I was always worry about connections. The more connections, the greater the likelihood of you missing a train due to one being late.
If your connections are every half hour there is a good chance of all these transfers adding to the journey. This gets worse if the connections are infrequent.
Then add the stress of long distance travel on a super saver only valid on one train, then you realise why people turn up an hour early at King Cross, just in case something went wrong.
If the train is not frequent, you need to plan your journey around the timetable anyway. It's less stressful if you can get one train and read a book not worrying that the train was ten minutes late. For longer journeys all that matters to me is the total time spent travelling. Standing around on platforms is a waste of time.
That's why everyone wants a direct train to London. A lot of smaller towns would be happy with four or five trains a day, if only there was the space.
Gareth Marston
26 Jun 2010
The road will do nothing more than provide temporary construction work - access to employment is down the valleys in Cardiff where the railways go. An electrified railway line will still be as relevant if not more so in 30 years time - roads have had their day.
If anyone's in any doubt about the magical economic benefits of dual carriageway construction just look at Angelsey - the A55 Expressway was completed across the island 10 years ago and if anything the islands economy has nose dived even quicker since.
Greenback
Emeritus Moderator
9 Aug 2009
Llanelli
Very true.
I am also a bit of a worrier. It's not so much the thought of being stranded, or having to buy another ticket, but the thought of having to hang aroudn for the next train, especially if there is an infrequent service!
Yes, I agree. The more changes of train there are, the less competitive rial is against road.
It is wise to allow plenty of time to get to your origin station if you are on an Advance ticket. Although we ar eonly 6-7 mins walk from our local station, we usually make sure we get there at least 10 minutes before the train is due - if nothing else it alows time to nip back if you realise on the way you have forgotten the tickets! :lol:
Quite right. I hate hanging around on platforms. It's usually too cold, too hot or wet, as well as tedious!
It's not just to London, but also to the main economic centre for the region. As with Barrow and Manchester. Travel to Cardiff is far easier from here because of the number of through trains.
I couldn't agree more!
Markdvdman
14 Aug 2011
Merthyr Tydfil / Gorslas
The Valleys Lines NEED the wires as they are too flaming slow due to many factors such as the number of stops, the inclines, the curvatures, and the pathetic rolling stock.
What they need truly is proper dual line support along the whole region but the cost of course is incredible. Also line straightening would vastly improve times but due to the cost again the only answer is electrification! A few minutes is always an improvement and to rid the lines of the pacers is wonderful!
I noticed an earlier post mentioning a chord to speed up Merthyr to Cardiff due to the better road conditions from Merthyr to Cardiff as opposed to say Treherbet and Aberdare, they get less passenger usage.
Merthyr also gets its first train at 6:38am and Treherbet gets 2 before then!
If they had any sense they would bring in a 6:08am Merthyr service! I would use it for certain!!! I reckon others would too ESPECIALLY if the quicker service is put in somewhere. I have to travel to Cadoxton though so I suspect I will not gain, but as long as it eases congestion on the roads I am all for it :D
