South Eastern train tracking system not correctly working
Hedgehog1977
14 Aug 2018
Open Train Maps & Traksy both showing SE lines in London Victoria are shut and showing out of date info all the way from Factory Junction to Bickley. Real train times affected too.
Was causing some very anxious faces at stations down the Bromley South line this morning, with trains suddenly going from on-time to delayed and then rolling into the station as per normal.
Apparently caused by the train tracking system not correctly working according to SE on X.
Hi Gavin, there are issues with the train tracking system, which is showing incorrect delays. Trains are running a good service from Shortlands. Apologies for the confusion. ^HS
Is this a direct result of the resignalling near Victoria over the weekend ? Often use open train times & RTT and am lost without them today!
16 Aug 2017
We noticed that Darwin has been missing real-time info for - at least - stops between Denmark Hill and Farningham Road today, causing trains to go "delayed" until they reappear. Feels like the same problem, to do with Network Rail's feeds that supply all these systems or a change in the info sent that has caught everyone by surprise.
Horizon22
Jobs & Careers
8 Sep 2019
Probably a data feed and/or tracking issue with the berths or TD data. It’s uncommon but not unheard of.
Hedgehog1977
14 Aug 2018
Data Feeds still down.
As a member of Joe Public is there any other ways of tracking trains like Real Train times at all / open street maps at all?
(National rail live departure screen shot)
800Travel
3 Nov 2023
I had a similar issue, elsewhere in England, yesterday. While signal maps uk wasn’t working, Traksy did, as did railboard. Maybe different data sources, but you could try railboard. Odd Traksy worked for me but maybe it was a slightly different issue
SYorksKent
20 May 2021
Still faulty data this morning. This is proving very frustrating for both my wife and me trying to get to work. She was panicking this morning thinking she would need to find alternative transport to get to Orpington. It turned out her train ran normally but the only way of knowing this was to climb up to the platform at Shortlands to see if the train actually turned up
