Should South Eastern ticket machines be fairer to customers. For example at Sittingbourne on the "home screen" the first ticket offered is an "Off Peak Day Return" to St Pancras (including High Speed) at a cost of £32.60. However this fare is only necessary for two off peak services every weekday and not at all on weekends or Bank Holidays. After these two trains have departed the following services (after 10:00am) to St Pancras only require the "Super Off Peak Day Return" at a cost of £29.70. There are no return restrictions on either ticket. The casual turn-up and go passenger is very likely to chose this ticket as it is right in his face when he gets to the ticket machine even if its after 10:00am. Even if you know about the existence of the cheaper ticket its not straightforward to find it on the machine. If you search for St Pancras as a destination you are not offered anything at all. Its only if you use a destination of London or London Terminals that you are offered the "Super Off Peak Ticket" among others. Would it not be possible to programme the machines to display the cheaper ticket instead of the other one once it was not possible to catch one of the earlier trains.
