Sounding the horn……??
dangie
4 May 2011
Rugeley Staffordshire
Some time ago I asked if drivers could implement their own speed restrictions if they deemed conditions warranted it. I now have another question.
Are there any laid down rules as to when drivers can or can’t sound the horn? Obviously I don’t mean as a warning, but maybe as an acknowledgment to a wave etc from a member of the public or perhaps if you saw someone recording your passing train.
I’m guessing sounding the horn for reasons other than safety could be frowned on for example when passing through built up areas early in the morning or late at night. Are there any rules on this?
DJP78
26 Nov 2019
Bristol
Use of the horn is covered in module TW1, section 47 of the rule book
Use of horn at crossings is allowed between 0600 - 2359
'You must only use the horn as much as is necessary to give an effective warning or to make sure safe working takes place'
Martinwithanx
1 Jan 2024
Rule Book Section 46.3
(e) Train movements
You must sound the horn at any other time you consider necessary
I use it to say “hi” to kids waving, people over the yellow line on platforms, signal to track workers that I’ve seen them acknowledge my sounding of the horn on approach by raising their arms, etc.
LCC106
16 Nov 2011
Although I’m sure there are drivers out there who think they’ve seen a p-way person near a bridge some children just happen to be waving from. Happened to me before, I know! Even with my Manager was with me ;)
dk1
2 Oct 2009
East Anglia
We can sound the horn whenever we deem it needed 24hrs a day.
At whistle boards however as stated above it’s only between the hours of 06:00-23:59 when it should be sounded for 3 seconds (1 second before 2 seconds after) as per the rule book.
At my TOC the only added restriction is that it cannot be used in the shed area at maintenance depots.
LCC106
16 Nov 2011
Can’t use ours anywhere on the depot or it’s classed as a near miss! Seems ridiculous to me. Surely you can warn someone you’re heading towards them. In a previous TOC we used ours to enter the fuel shed or as required.
Krokodil
23 Jan 2023
Wales
Probably because of the sheer volume of modern horns, it'll deafen the staff. Some newer units have depot horns which are quieter
PyrahnaRanger
16 Aug 2022
Lancashire
Are there any units that have a recording of a horn, rather than an actual horn? If you frequent Blackpool’s trams, you’ll spot that they can toot or ding, but both sounds seem to be recordings - you can hear the speaker switch on and hiss for a second or two before the sound is played through it!
357
12 Nov 2018
Many modern units have a whistle to use within depots.
12LDA28C
14 Oct 2022
Indeed, although the rules are different on the London Underground network where the horn should only be sounded at whistle boards between 0700 and 1900, no doubt due to noise concerns in residential areas.
172007
2 Jan 2021
West Mids
Wow. At our depot the horn has to be sounded prior to commencing every movement including coupling within the depot area. The point is to prevent near misses before they happen in a busy environment where people and trains work in close proximity.
43066
24 Nov 2019
In practice it’s entirely down to drivers’ discretion to sound the horn whenever they feel necessary. Any questioning could be met with “I thought I saw p way on the track”, “I thought someone on the platform was too close to the edge and unaware of my approach”, or similar.
You are required to sound the horn at whistle boards within those hours, but that doesn’t mean you can’t sound it at those locations at other times, if someone is on or near the line, or if you feel it necessary.
vikingdriver
11 Mar 2010
Where does it state in the rule book to sound it for 3 seconds like that?
TreacleMiller
22 Feb 2020
It doesn't.
TOCs PDA agreements maybe, but unless that's updated in the last update, it's not in the rule book.
I think the Op has their answer now.
We can do it whenever we can justify it, not when we fancy.
That being said, the likelihood of you being pulled over the coals for giving the horn a blast on a special service, retirement run etc. Is relatively low.
CarrotPie
18 Mar 2021
:D We can do it whenever we can justify it, not when we fancy.
Tea, biscuits and an airhorn?
AJD
20 Jan 2013
Yep, this!
We've had many damaged pantographs when birds have struck them, resulting in auto drop activations (ADD) and the resulting delay can be considerable.
Had a manager conducting one of their regular assessments last week and a large flock of birds lift off and make their way over towards the railway. Good sharp blast of the horn soon disperses them away from the vicinity of the train and overhead wires.
Told the manager I'm not risking a potential ADD event. They agreed and no more was said.
dk1
2 Oct 2009
East Anglia
I think @dk1 has previously mentioned his driving policy is very prescriptive regarding whistle boards.
Most certainly is. I am picked up on downloads for only doing it for 2.7secs for example as has most of the establishment at my depot at one time or other.
357
12 Nov 2018
There was some discussion about this in another thread some time ago when I said I'd been picked up for only pressing the couple button for 4.9 seconds instead of 5 seconds. Some interesting information was posted about the accuracy of the recordings not being reliable down to such a small margin.
dk1
2 Oct 2009
East Anglia
From what I gather the downloads on the 745/755 are pretty accurate. Same as we get pulled up for not pausing for doors. Just have to smile & agree.
Recessio
4 Aug 2019
If they want it precise to the millisecond could they not add a button that plays it for an exact period of time? Sounds ridiculous to get picked up over 0.1 seconds.
CarrotPie
18 Mar 2021
The problem with that comes on the fifth Tuesday of the month (unless it's the 30th, in which case it's the day after), where you have to sound the horn for π seconds! :lol:
12LDA28C
14 Oct 2022
Whistle for LU trains, horn for mainline trains running over the LU. :lol:
There can't be much going on at your depot if all the DMs have to worry about is you being 0.3 seconds short on the warning horn.
dk1
2 Oct 2009
East Anglia
Six DMs at my depot alone & just how it is nowadays. They’re all lovely really though :wub:
driverd
29 Mar 2021
Goodness, I'm glad I don't work for GA. Do they put people on plans for such things?
Class 170101
1 Mar 2014
Really? The next thing drivers will be asking for is a stop watch!
