Smooth departures
Huntergreed
Events Co-ordinator
16 Jan 2016
Dumfries
I have noticed that when riding on VTWC trains, the smoothness of departure from each station always varies. Does anyone know why this is? I would simply assume the driver of the 390 would put the traction brake control in power mode 1 and that it would always feel the same?
fowler9
29 Oct 2013
I would have thought it would depend on the speed limit (And changes of) plus the track conditions leaving a station.
BestWestern
6 Feb 2011
Poor rail adhesion will cause the train to deliver a jolty, bumpy start. This problem is far more prevalent when moving off from a standing start. There is little that a Driver can do to cause a poor ride, other than excessive speed or braking, neither of which would apply when starting from a station of course.
Phil.
10 Oct 2015
Penzance
You want a jerky ride? Try a London - Norwich - London loco operated push-pull set. I've never known such a jerky ride all the times at all times of the year that I used to use them. It does seem to be worse with the loco pushing.
scott118
24 Feb 2015
East Anglia
That might be that DK1 fella, spilling everyone's coffee..he is such a scamp.
Always been the way with the loco pushing, as us former WCML commuters can testify heading southbound. The driver doesn't have the individual traction motor ammeters in the DVT, which usually provide the first indication of wheelslip, so he (or she) can adjust power accordingly.
BestWestern
6 Feb 2011
An HST is always good for a lively ride when the road is greasy; it's like riding an accordian!
Bromley boy
18 Jun 2015
For the ultimate in smooth departures, my "personal best" is definitely a Eurostar (373). The start is so smooth that it's imperceptible and I don't realise the train is moving until I look out the window.
I assume this is to do with the length of the train being pushed/pulled by the power cars at either end.
AM9
13 May 2014
St Albans
Surely that is because the push from the back progressively compresses the couplings between each coach. If you are at the front of 9 or 10 coaches, when the compression 'wave' reaches you the loco has increased speed a little which means that the bump is larger. Your coach then bouces forward stretching the coupling springs and then stops when they reach their limit. If the driver accelerates hard enough and the couplings have plenty of undamped compliance, it can set a peristaltic ripple up that may go through several cycles. This often happens when track adhesion is good.
I remember that the 4-REP + 2x4TC trains on the SWML could do this when pulling away on down trains when there was a 3200hp 4-car unit pushing 8 trailer cars.
Ash Bridge
17 Mar 2014
Stockport
Must agree with you there, and if memory serves correct, the class 90s always seemed worst than the 86/87s in this respect.
AM9
13 May 2014
St Albans
All other things being equal, the trains with the fewest trailers (i.e. those comprising all power cars) will be the smoothest pulling away.
Bromley boy
18 Jun 2015
Makes sense.
Anyone else noticed the class 373 smoothness? I'd love to know what causes it...
craigybagel
25 Oct 2012
Try ATW's 158834, fitted with a 4 speed transmission. It's a lot quicker off the mark,but it keeps around something terrible, especially when coupled to another unit....
Phil.
10 Oct 2015
Penzance
Just spotted your enquiry. It's a combination of power at each end and the Scharfenberg couplings being very tight with very little fore and aft movement.
coppercapped
13 Sep 2015
Reading
Pedant mode ON!
The only Scharfenberg couplers in the 373 are at the outer end of the power cars. The coupling/articulation between the coaches can best be described as a steel ring to which the ends of the coaches are pinned. The pin allows rotation along the longitudinal and lateral horizontal axes and the vertical axis but no relative up-and-down movement. There are 'ears' on each side of the ring which sit on top of the bogie's secondary suspension air springs.
As the whole train is linked - a bit like a bicycle chain on its side - all the coaches move up and down together which means there is no need for dampers across the primary suspension. This removes a vibration path and makes the ride smoother. The conventional bogies under the power cars and the first coach on the other hand do have the primary dampers.
Pendant mode OFF!
Together with careful control of the 3-phase motors to avoid any slip on starting, the result is a silky smooth ride.
Smitham
1 Dec 2013
I remember when new the HSTs were so gentle pulling away you wouldn't know unless you were looking out the window.
theageofthetra
27 May 2012
Beckenham
Any Networker combination with a 466 in it driven from that end in light rain or over a conductor rail gap.
