Small Terminuses
Bittern
8 Apr 2009
Lets take the likes of Larkhall and Lanark for example.
Both small terminuses on the Argyle Line, each with two platforms and both served with regular services to Glasgow and beyond.
But trains only seem to use one of the platforms.
Why is this? Why have two platforms if one is just there for show and tell?
Jordy
9 Jun 2005
WCML South
I'm sure the second would be used if there were delays (ie the trains were closer together than normal) or if the service is more frequent at any point!
MCR247
7 Nov 2008
In Moorgate (GN) I think they only use Platform 9 off peak
jopsuk
13 May 2008
If the frequency is low enough, and tunraround time short enough, that each train leaves before the next arrives, surely it makes it easier for everyone to just use the one platform and (as said) have the other in reserve in case things start to go wrong.
SWT Driver
29 Aug 2009
The Twiglet Zone.
Hampton Court has 2 platforms, which during special events can juggle a 10-15' interval service.
Shepperton a single platform terminus, famous for the train that ended up in the High St some years ago, handles a 15' service in the peak hours.
Chessington South a single platform pseudo terminus (the line continues beyond it towards the theme park via a forest, the line was originally going to link in at either Leatherhead or Bookham) it can take a 20' service at a push.
Pumbaa
19 Feb 2008
West Kirby uses P1 usually, a 15' frequency. 6-car set stabled in P2 through the day, until peaks.
furryfeet
17 Apr 2008
Larkhall has been designed for such an occurrence - platform 1 is used normally, with platform 2 used for one train a day, or for use in case an incoming train is late.
NSEFAN
17 Jun 2007
Southampton
Stratford-upon-Avon is not very busy, but still has 3 platforms. I've only ever seen 2 occupied at once.
SWT driver said:
Chessington South a single platform pseudo terminus... can take a 20' service at a push
A couple of weeks ago, there was a 15 min service on this line for replacement bus connections at Tolworth to Surbiton. As far as I know, the trains ran all the way to Chessington South. How did they cope then?
SWT Driver
29 Aug 2009
The Twiglet Zone.
It didn't you ended up with trains waiting at Chessy North for the platform to become available, it's pointless waiting on the signal outside South as all you'll get is idiots pulling the doors open & jumping out, so it's safer to wait in the platform at North then they can't get up to any mischief.
MCR247
7 Nov 2008
Are the doors on 455 that easy to open? :shock:
Aictos
28 Apr 2009
I would say Gordon Hill is a small terminus as well as services only terminate there from Monday to Friday and only in the peak, Hertford North cannot be put into the same grouping of stations as it have terminating trains around the clock except in the early hours of the morning.
I'm tempted to say Huntingdon falls into the the same grouping as Gordon Hill as not many trains terminate there, I know there's one or two in the evening peak from London Monday to Friday.
SouthEastern-465
24 May 2009
Greater London
Bromley North is a very small terminus and is just a island platform with only really one in use you rarely see a train on Platform 2?
8 Dec 2006
Costa Del Sheppey
Sheerness-on-Sea has 2 platforms, numbered 1 and ... errr ... 2. :P
Platform 1 is the main one, Platform 2 is used occasionally when there are freight trains blocking P1 or a broken down train etc.
Until a few years ago, there was track between P1 and P2 that the freight trains used, but that was taken up due to lack of freight workings IIRC.
Castleford operates as a single platform terminus as trains reverse there towards Leeds, Wakefield or Pontefract. With around four trains an hour we often end up having to wait for the platform.
philjo
9 Jun 2009
Ilkley has 2 platforms.
One is usually used for Leeds departures, the other for Bradford trains.
there are usually half-hourly services to both Leeds & Bradford, so an approx 15-minute service as far as Guiseley.
me123
9 Jul 2007
Various possibilities come to mind, seem to have been mentioned already:
  • Provides a stabling point for trains, without needing an ECS service (for example, a morning peak train can arrive and terminate, and work out that evening in the evening peak)
  • Extra platforming space if required in an emergency
  • Allowance for future enhancement of services
At Lanark, both platforms are used in the peaks. (For example, there's a train in 07:07-07:23, and another in 07:13-07:45). This doesn't happen at Larkhall, but the potential is there for future service enhancements if desired/required (for example, 4tph in the peaks). Alternatively, they could stable a train there between peaks, as Pumbaa says happens at West Kirby.
tbtc
16 Dec 2008
Reston City Centre
Castleford is a strange one - it's a single track (single platform) terminus on a double track linem with freight and other workings running "beyond" (to/from York etc)
Must be a nightmare to schedule, especially as it wasn't a clockface fifteen minute service last time I was there... (but interesting to model!)
thefab444
27 Oct 2006
The New Forest
Both Ryde Pier Head & Shanklin stations on the Isle of Wight are very small termini since only one platform is ever used.!
Indeed, Shanklin's platform 2 was taken out of use many years ago (track is no longer in existance), but Ryde Pier Head platform 2 was taken OOU more recently. I think it can still be used, but it is extremely rare?
Dave R
13 Apr 2009
Aberystwyth has 1 platform (excluding devils bridge trains) and sees a train every 2 hours, I think it has a track next to it so locos can run around back to the front. Only really used by 158s on Aberystwyth-Birmingham International
Toots
24 Oct 2009
A couple of oddities on this theme are those at Omskirk and Kirkby.Trains come in at each end of a single platform and then return back along the single line.The reason for this is that both stations are the termini for the Merseyrail electric network,but also serve as termini for local trains from Preston and Wigan respectively.
