Slightly puzzled.
plastictaffy
18 Nov 2012
Unfortunately, Maps has stopped.
Folks,
I had the pleasure of riding on the tram system in Nottingham yesterday into the city. We went from Wilkinson Street to Old Market Square, which is quite a hilly route. I found myself rather puzzled about the trams. How on earth do they go up and down the hills without slipping??
ac6000cw
10 May 2014
Cambridge, UK
These threads might be of interest:
http://www.railforums.co.uk/showthread.php?t=79650
https://en.wikipedia.org/wiki/List_of_steepest_gradients_on_adhesion_railways
(Note the 14.5% gradient on the Lisbon tram system tops the list, but the metre-gauge 'heavy rail' line up to Chamonix in France is 9.1% - when I travelled on it I was amazed how steep it was for an adhesion-worked line!).
I guess it's basically that tramcars are lighter than 'heavy rail' vehicles, so the line can be steeper before force due to gravity exceeds tractive effort (when the vehicle would stall).
tramdan
4 Aug 2015
Folks,
There are a couple of things that prevent the tram from slipping. The main thing is that the tram vehicles are very lightweight for rail vehicles (approximately 40 tonnes unloaded and up to 60 loaded) and have 8 out of the 12 wheels driven.
The other thing that is used to prevent slipping and sliding (they are two different things, the former is while taking power and the latter is while braking) is sand. Sanding is used extensively on tramways to increase adhesion and is applied in a number of scenarios. It is applied if the onboard computer detects sliding under braking or slippage when accelerating. It can also be applied manually by the driver using a button on the dashboard. In Nottingham you can hear this going on if you are sitting over the end most bogies on the older Incentro trams.
Even with these things there are still occasions when drivers will experience exceptionally low adhesion and it is these occasions where your skills and deft application of the driving-brake controller, sand and magnetic track brake is required.
Finally, glad you liked the tram system! We are very proud of it! :D
