Slight changes you would make to liveries to make them nicer
Domh245
6 Apr 2013
nowhere
Not my neatest attempt at livery tweaking, but one of the "what-if" scenarios that I was idly thinking about recently
physics34
1 Dec 2013
Can someone mock up a 377 in blue /grey (with prm-tsi compliant grey doors). Cheers
jfowkes
20 Jul 2017
Are we only allowed "styling" changes - i.e. nothing functional?
If not, I'd like to see the new Northern 195s/331s with decent wheelchair/bike space external signage as per the Sprinter fleet.
Doomotron
25 Jun 2018
Kent
I think lots of people don't like the Voyagers because they look too 'thin'. Can someone try to do a Voyager but with the yellow wrapping around the front a bit more, like the EMT HSTs?
PudseyBearHST
28 Sep 2015
South West
Hello. Can anyone do a HST in Transpennine Livery please? Appreciate this isn’t a ‘slight’ change but curious as to how it would look. Thanks
That is of course, assuming the yellow has to stay!
I don't think that anyone has retrofitted HSTs with headlights of sufficient intensity to eliminate the need for yellow fronts. That livery is death on wheels.
Domh245
6 Apr 2013
nowhere
Nobody has so far, but TPE have retrofitted their 185s with suitable lights operating in the correct fashion (although not ditching the yellow fronts) - it's not the most outlandish thing on here to suggest that TPE would similarly retrofit any HST to allow removal of the yellow front ;)
Royston Vasey
14 May 2008
Cambridge
And every FGW liveried power car had less yellow again as it didn't cover the headlight surrounds, so such an arrangement is obviously allowed.
Original Grand Central had the least of all, and less than is being proposed by painting the valence blue and purple as the headlight surrounds would remain yellow.
... it's not the most outlandish thing on here to suggest that TPE would similarly retrofit any HST...
Seeing as TPE has a fleet of brand new trains, many of which are sitting idle, it's getting pretty far into outlandish territory.
SteveyBee131
28 Oct 2017
Grimsby Town
Just to clear it up, any train not fitted with 'super dazzling' headlights has to have at least one third of the front surface area painted warning-yellow. That's why HSTs that have the windscreen width yellow panel have it carried down to the lower section. If they have it full width, just the upper section is sufficient.
Royston Vasey
14 May 2008
Cambridge
It's not measured as a fraction of the front surface and it's much less than you'd think.
I believe it's still 1 sq m with a minimum dimension of 0.6 m.
Domh245
6 Apr 2013
nowhere
The requirement is for a minimum of 1m^2 of yellow, with a minimum dimension of 0.6m - not just "a third"
Worth noting that GC ran two variations of minimal yellow - on the original livery a full-width section that extended from above the headlights to just below the windscreen, and on the second a window-width section down to the point of the nose so clearly either works!
gimmea50anyday
8 Jan 2013
Back Cab
Not as outlandish as you might think. Has BR acquired more HSTs than they were allowed at the time of introduction some would have ended up on TPE routes by the mid 1980s.
