Sleeper service for the ECML.
Trainbike46
18 Sep 2021
belfast
An ECML sleeper service likely wouldn't need a 16 carriage train.
Glasgow would stay as its quicker. I would move the WCML Edinburgh sleeper to the ECML as there likely isn't the demand for both to exist.
You're not answering the key question though. In what way would things improve if you move the Edinburgh portion to the ECML?
True, unless you run a KGX-Aberdeen sleeper and then run Inverness and Fort William sleepers via Glasgow only.
So what service pattern are you actually proposing? and in what way is your new service pattern an improvement over the old one?
Peter Mugridge
8 Apr 2010
Epsom
Couple of points here:
Firstly, the Sleeper doesn't need a quicker journey time. If anything the timings when the Glasgow is diverted via the ECML are actually better as you get a full night's sleep in.
Secondly, the Edinburgh portion on the existing Sleeper tends to sell out sooner than the Glasgow portion for the same night - which shows the demand already is there. Much of the time it's fully booked.
YorkRailFan
6 Sep 2023
York
It would provide Newcastle, York, Doncaster and possibly Leeds (if you send it via Leeds) with earlier arrival times into London and Edinburgh.
One could send the sleeper via Leeds, which could open quite a bit of demand.
Trainbike46
18 Sep 2021
belfast
Doncaster to London is way too short a distance for a sleeper train. London-Central belt is very much at the lower end of distance/time where a sleeper makes sense
The same is true for Leeds, York and even Newcastle
YorkRailFan
6 Sep 2023
York
Then the Sleeper could go to Glasgow via the ECML.
YorkshireBear
23 Jul 2010
Only remotely possible way a sleeper would work on the ECML (sensible timings wise) is if it went to the south west. Anywhere else the timings don't work at all, let alone commercial viability.
Trainbike46
18 Sep 2021
belfast
Please, just write a clear list of what exactly you're proposing to do. Where would it start and end, what stops would it make for passengers, what portions would there be?
because I've lost track of what you're actually proposing (or is it actually changing every post)
YorkRailFan
6 Sep 2023
York
A sleeper service from either Glasgow or Aberdeen, stopping at Edinburgh, Newcastle, York, Leeds and London King's Cross.
Train Maniac
28 Sep 2018
Bear with me on this....
When reading the main Caledonian Sleeper thread, one of the main reasons why the Caledonian Sleeper makes such a loss is due to the amount of staff required to do the various shunting manouvres along the route. Another common problem mentioned is that the Cally Sleeper is somewhat incompatible with the rest of the network due to how freaking long it is.
If a dedicated ECML sleeper service was created, trains could be shorter as well as removing the need to faff about Waverley in the early hours. In terms of traction, Im fairly certain CS is double headed?
Lastly, if the central belt stations are equally as popular, why not send the Lowlander into Queen Street via Waverley, thereby getting the best of both worlds?
deltic08
26 Aug 2013
North
Not when electrically hauled. The Highland portions are on occasions.
43096
23 Nov 2015
York to Leeds isn’t electrified. So how are you hauling it?
Gwr12345
28 Jun 2020
Delayed
Not an the ECML as such but would run on it partially, would a sleeper from Newcastle to Plymouth/Penzance work?
The day train is 7 hours from Newcastle to Plymouth and that could probably be slowed down enough, add on to this maybe extensions to Edinburgh and Penzance and it becomes over 10 and a half hours, and let's say slowed down by and hour and 15 by not going at 125 on the ECML, and also giving us the nice round number of 12 hours to work with.
Leaving Edinburgh at 1900, which allows time to finish work and have a meal etc, going to Newcastle at 2030 and then heading via some more stops, arriving into Plymouth at 7 ish and then continuing to Penzance.
Or would such a service be completely unviable in the modern world?
mangyiscute
6 Mar 2021
Reading
If something like this is funded I think we can assume that the various obvious stretches of electrification including this one have been filled in.
I just don't think there would be sufficient demand for such a service, I highly doubt more than 5% of passengers on the usual NE-SW cross country service are doing more than 2 hours on the train, and I think the journey needs to be at least 5/6 hours for someone to consider getting a sleeper.
Back to the original point, it sounds like op more wants earlier trains from stations along the ECML to London, but not necessarily as sleepers. As mentioned before, most places have roughly 5am trains to London, which im sure most would agree is early enough - I'm sure these services don't get busy until they're nearer London
I suspect the original poster probably may just want the novelty of sleeper trains passing through their station. They haven't indicated that they are actually intending to make the journeys they suggest are needed.
A S Leib
9 Sep 2018
And conversely, Leeds and York have last departures from King's Cross at 23:00 or later; there's probably extremely little demand for anything later which couldn't be filled by one extra 'daytime' service. (The last Newcastle service is at 22:00; the last Carlisle / Glasgow's 19:30, the last to Preston is 21:10 and there's nothing past Wolverhampton after the 22:00 to Liverpool and the 22:03 Manchester.)
I would like to see more NE England / Yorkshire – non-Edinburgh Scotland services – I'd like to have a direct Newcastle – Thurso / Wick sleeper, although I know that it would likely have very low usage numbers and might not necessarily use it myself – but I think the best way to do that would be to get CrossCountry back to 1 tp2h between Edinburgh and Glasgow and maybe introduce more LNER Stirling (or even Perth? but this is off topic) services.
cinders&ashes
29 Oct 2023
Havant
Just wanted to start this thread to discuss the possibility for a sleeper service on the ECML. I personally would love it, but I do see several issues, such as demand, as the Caledonian Sleeper already serves Edinburgh, Glasgow, Inverness and Aberdeen, that leaves very few destinations for an ECML sleeper service. A possibility for it to work is if the Caledonian Sleeper stops serving Edinburgh. Another complexity would be if LNER operated the stock, meaning that LNER would have to have specific rolling stock to operate the service and staff trained. The other alternative would be for Caledonian Sleeper to operate it, as they already have rolling stock for a service like that, but even then, they would need to have staff trained specifically for this one service.
Just seems an unnecessary duplication, what about other cross country routes like from south coast to Scotland or Devon/Cornwall to North Wales or Northern England?
43096
23 Nov 2015
Use a 93 (when it gets certified) all the way but use something like a 68 between York and Leeds.
So yet more cost. Another loco and another crew required for a service that is already a financial basket case.
syorksdeano
7 Jan 2011
Divert via Sheffield for around 3am. Station is already staffed for the transpennine Manchester service leaving either at 3:20 or 3:40am
Shunting is a mere scratch in the cost.
The cost drivers are:
1) a very low capacity fleet, of very expensive rolling stock (£3m per coach), that makes one trip a day
2) High staffing requirement for each train, all working nights.
3) high cost of servicing the rolling stock
Not remotely viable. There just isnt the market. As an example, Bristol to Glasgow rail traffic is in the region of a handful of people a day each way.
A S Leib
9 Sep 2018
In summer 2021 (so admittedly not necessarily representative) Bristol–Edinburgh was the 13th busiest domestic flight route in the UK and sixth excluding Northern Ireland, although I suspect the solution to that is building HS2 in full and from Curzon Street towards Cheltenham rather than (just) sleeper trains. Around 68,000 passengers across three months gives ~750 a day, which doesn't seem enough to fill a (probably more expensive) sleeper from flight passengers alone even if you added in Bristol–Glasgow and Exeter / Newquay–Scotland flight passengers.
gabrielhj07
5 May 2022
Herts
Where would the Highlander split if not Edinburgh?
2 completely different markets. Air passengers are going to have limited interest in a sleeper train.
Falcon1200
14 Jun 2021
Neilston, East Renfrewshire
Who would be subsidising it to the level of the Caledonian Sleeper?
If it were part of Caledonian Sleeper, then the Scottish Government.
Which actually means, of course, the Scottish taxpayer; As one such myself, and despite being very much pro-rail, I would be very much against spending a single penny on such a service.
These points may well have been made already, but to summarise;
Departure and arrival times at Newcastle, York, Leeds (and any other intermediate calls in England) would be in the middle of the night and therefore extremely unattractive.
Kings Cross could not possibly accommodate a train with anywhere near enough capacity to even begin to justify such a service.
Where would the stock be stabled and service at the London end?
YorkRailFan
6 Sep 2023
York
Bounds Green?
Glasgow.
Not a bad idea, would also mean that Sheffield gets a KGX service.
What other alternative is there for a service like this?
Capacity would be an issue on the line, especially in the Birmingham area.
Falcon1200
14 Jun 2021
Bounds Green?
Which means yet another increase in costs, through having two sleeper depots in London rather than one.
Where in Glasgow? The only station in Scotland suitable for dividing, and joining, multiple trains from and into one extremely long service is Edinburgh Waverley.
The alternative is no service like this, because it is neither remotely viable nor practical.
YorkRailFan
6 Sep 2023
York
Glasgow Queen Street most likely.
Regarding the depot, the train could be shuttled to the same depot WCML services use.
Peterthegreat
22 Feb 2021
South Yorkshire
Bounds Green?
Glasgow.
Why would Sheffield need a King's Cross service when St. Pancras is next door?
