Sleeper Formation
Caleb2010
25 Nov 2015
Dufftown
Hi, can anyone tell me if the Caledonian Sleeper is always formed in the same order, I.e with the BUO of the INV portion closest to the buffers at EUS, and when departing INV is the BUO again at Buffer end. Plus, has anyone else noticed how rough the electric section is compared to the desiel section. Thanks in advance.
That's because it's faster on the main WCML I guess?
Zoidberg
27 Aug 2010
West Midlands
INV for Inverness, I got.
EUS for Euston, I got.
But BUO confuses me since I don't think you mean Burlesdon. In this context, for what is BUO an abbreviation?
47271
28 Apr 2015
Brake Unclassified Open, the mk2 seated coach.
To answer the OP, yes the Inverness seated coach and lounge SHOULD always run at the rear on departure in both directions since the portion reverses at Edinburgh. Rolling stock has been a bit confused recently however as the main Caledonian Sleeper thread will tell you!
As Neil says, I think it's just a difference in speed that you're experiencing.
Caleb2010
25 Nov 2015
Dufftown
Thanks guys, I guessed that the formation would be in some sort of order but not knowing which bit normally leaves EDB first I wasn't sure if I'd encountered a happy accident but not having to walk too far from the barriers at both ends or not, plus the FTW bit didn't run on the Sunday coming back so didn't know if there would normally be a difference in how it was formed normally. Looking forward to travelling again on it.
