On a track circuit block Single Line what method of working would be introduced for signal failures if :
1. In the Sectional Appendix it states for the given Single Line that Working by pilot need not be introduced following a failure of signalling equipment on the single line, provided that the following conditions are met:
| A. | All track circuits are functioning correctly on the single line and associated connections. |
| B. | All points are detected or secured in accordance with the Rule Book, Module TS11, section 13 & Handbook 4 |
2. Modified Working is not permitted over the Single Line.
Thank you in advance for any help given.
