Signalling Quiz 3
strange6
9 Jan 2011
Wigan, Greater manchester
Will make more difficult starting with this!
1.How far does an overlap extend beyond its associated signal?
2.If a position light shunt signal was displaying a yellow and white light what
would this mean to the driver?
3: Write down the three items of standard AWS track equipment in the order in which a train passes over them.
4: If the points were set in their "normal" position for the straight route with a
diverging junction to the left, which one of the following would be the correct method of reporting back the position of the points?
a) Points standing normal
b) Points not standing reverse.
c) Left hand switch rail closed.
d) Right hand switch rail not closed
5: Rail point clamp locks are operated by which one of the following methods?
a) Mechanical
b) Electro mechanical
c) Electro-pneumatic
d) Electro Hydraulic
Would be great if a qualified signaller could have a go at this!
Answers posted on Sunday evening!
Hydro
5 Mar 2007
a) Mechanical
1. 200 yards normally I think. That's just from remembering the COSS course, no work may take place within 200 yards in rear of a protecting signal, as this is within the overlap and NOT under the signals protection. You have to use the preceding signal as protection. Overlaps can be shorter (to the extent of not having any overlap at all), and am I correct in thinking some signals on the Southern can have even longer overlaps? I seem to remember 440 yards from somewhere. Could be bollocks, just something heard in passing.
5. D. Electro-Hydraulic. The yellow boxes contain the micro switches, the points are moved and locked hydraulically.
Tomnick
10 Jun 2005
1. Varies, depending upon (not sure how many of) approach speed, gradient (??), whether it's an overlap from a main route, shunt route or warner route and whether it's a goods line.
(440yds is the standard "overlap" (clearing point) on an Absolute Block line with a semaphore distant)
2. Position light signal may be passed when displaying the 'normal' indication, for the route(s) to which it does not apply - typically into a headshunt or similar.
3. Ramp, permanent magnet, electromagnet.
4. Not sure, to be honest. (b) and (d) both include the word 'not' that is liable to be lost in an inopportune moment of crackle on the telephone, so I'd rule those out. Presumably (c) removes the opportunity that (a) provides for normal/reverse positions to be confused, so my money's on (c) (with (a) a close second!)
5. No reason to doubt Hydro's answer!
Tomnick
10 Jun 2005
I'll see if I can come up with some questions of my own too.
ralphchadkirk
20 Oct 2008
Essex
regarding 4, a would be my answer as the person by the points can tell normal or reverse position by the position of to point number of the sleeper.
strange6
9 Jan 2011
Fair do's but remember that you are reporting back to somebody ( probably an engineer) and that you must follow railway convention! :)
Excellent logic applied to question 4. What do you do for a living?
Hydro
5 Mar 2007
I'd say C. There is no 100% way of determining what is normal and what is reverse merely by looking at the points as these are primarily panel indications. Positioning of points numbers can't always be relied on. Saying "Left hand switch rail closed" leaves no doubt as to what route is set from what you see on the ground.
strange6
9 Jan 2011
excellent logic being applied yet again. You'll have to wait until Sunday to find out! meanwhile, i will work on a quiz no 4 and make it more difficult. Questions about relays would be a little too advanced maybe?
Tomnick
10 Jun 2005
They tell me that I'm an engineer (civils by training, but a bit of everything in practice), but not on the railway (any offers??). Away from the paid job, I'm a Signalman on the (heritage) GCR, and now also the Signalling Instructor and doing various bits on various committees - I've learnt what I know from the vast experience (who are sufficiently interested to spend time passing on what they know!) there.
Relays are largely a whole new world to me, but a few questions chucked in wouldn't do any harm!
Finally, Ralphchadkirk is right in that the normal position of points would, by convention, be identified by the position on the sleeper of the plate identifying the points (located nearest to the switch rail normally closed??). Not sure how reliable that'd be nowadays though.
ralphchadkirk
20 Oct 2008
Essex
Using the Id plate on the sleepers is how I've been trained to report back to a signalman whether the points are normal or reverse. Like tomnick though, I'm not mainline.
Hydro
5 Mar 2007
Sometimes points numbers get moved arbitrarily for maintenance reasons, they break, fall off, get stuck back on any which way. You know what the railways like, you can be taught something as gospel then after 6 months of working on the ground come back with a million exceptions.
strange6
9 Jan 2011
ANSWERS as promised!
How far does an overlap extend beyond its associated signal? 200 metres
would this mean to the driver? Permission is granted to pass this signal for
shunting purposes.
Ramp - Permanent Magnet - Electro-Magnet
If the points were set in their "normal" position for the straight route with a diverging junction to the left, which one of the following would be the correct method of reporting back the position of the points?
c) Left hand switch rail closed. (CORRECT!)
a) Mechanical
d) Electro Hydraulic (CORRECT!)
Thanks to those taking part!
Railsigns
15 Feb 2010
Wrong: The standard overlap length is 180 metres (197 yards).
shunting purposes.
Wrong again: That's what two white lights at 45 degrees mean. Tomnick gave the correct answer.
strange6
9 Jan 2011
Mmmmmmm, things must have changed recently then! :)
Two white lights at 45 degreees is the standard proceed indication but a yellow ligt and white light at 45 degrees is also used but less so :)
I think we're both wrong on the overlap
http://www.railway-technical.com/sigtxt1.shtml#TheOverlap
It was 200meters at one time though
Railsigns
15 Feb 2010
A yellow and white light at 45 degrees? Hmm, no I think you may have dreamt that one up. It certainly doesn't exist in any official capacity.
I could be persuaded to post my own signalling quiz...
