Islineclear3_1
My memory is very hazy on this, but my question relates to how a red and yellow lever in a signal box operates a semaphore outer home and distant signal mounted on the same post.
If the outer home is pulled off, how does the distant signal operate? I get that it does not operate/clear if the next home signal in advance is at danger.
Specifically, this relates to the approach to Horsted Keynes in the "UP" direction where there are 2 distants on the approach. The first is "linked" to the outer home signal up the line (as they share the same lever number in the box), whilst the second distant is mounted on the same post as the outer home and is operated by a different lever
