Signalling problems at Cannon Street
MrB
3 Jan 2016
Appears to be a recurring issue at Cannon Street, Southeastern have had a 'signalling problem' there happen almost every day for a week or so. Anyone have any insight as to what's going on?
E27007
25 May 2018
LB to Cannon Street "branch" used Solid Stare Interlocking system in contrast to the Relay interlocking system for the rest of LB area, if the SSI system was not replaced during LB Thameslink project then the Cannon Street SSI system is probably 30 years old now
rower40
1 Jan 2008
Look, I know we've all done typos from time to time, but I just love this one:
The sort of thing that Paddington might use?
Kaboom Tish and so on and so on.
Albeit that Paddington was upgraded from SSI to Smartlock a few years ago, though the data remained largely unchanged.
WizCastro197
12 May 2022
Reigate
It has occurred again today, this time outside London Bridge, doesn't indicate whether it is in the northbound or southbound location, so therefore could have nothing to do with CS.
Hide details
Due to a fault with the signalling system at London Bridge, trains running through this station may be cancelled, delayed or revised.
Disruption is expected until the end of the day.
What's happened?
A fault has occurred with the signalling system outside of London Bridge.
Response staff have been unable to carry out repairs because of the nature of the work involved. Repairs will be carried out at the end of service.
How does this affect my journey?
Trains via London Bridge will be delayed or cancelled with some trains being diverted to Victoria / Cannon Street.
What do I need to do?
Please allow extra time to complete your journey.
You may use your ticket at no extra cost on London Underground services between:
  • London Bridge
  • London Cannon Street
  • London Charing Cross
  • London Victoria
WizCastro197
12 May 2022
Reigate
I was on a Ch+ train that was diverted into CST this afternoon which perhaps suggests a different fault.
Yes, the incident page did suggest trains were being diverted into Cannon Street rather than away from it, which then again suggests something other than Cannon Street is directly affected.
E27007
25 May 2018
My excuse is is the "t" and the "r" keys on the keyboard are neighbours!
Cannon Street branch probably too risky to implement red-zone SSOW, S&T staff have to wait until end of servi9ce to get stuck in to the fault
Stephen42
6 Aug 2020
Trains leaving Charing Cross haven't used platform 7 at London Bridge since around 12:30 using only platform 6, 7 is being used for turnback only. Network Rail have said it's a switch issue that will be dealt with at end of service.
Nicholas Lewis
9 Aug 2019
Trains leaving Charing Cross haven't used platform 7 since around 12:30 using only platform 6, 7 is being used for turnback only. Network Rail have said it's a switch issue that will be dealt with at end of service.
Aint no P7 at Charing Cross presumably you mean Cannon St?
The Cannon St SSIs were replaced in 2017 as part of the London Bridge rebuild.
The problem has been an intermittent track circuit failure. Intermittent failures like this in complex trackwork are particularly difficult to diagnose and fix.
Nicholas Lewis
9 Aug 2019
never got why they didn't go down the axle counter route for Thameslink
at the time it was designed the evaluators / interlocking would not have been able to cope with the quantity of counts required. 12 car trains, every 2 mins (at times) in sections 2-300m long. Also the potential for miscounts is high due to the frequent stopping (and expected stopping just in rear of a station).
London Bridge pioneered the use of the EBI-400 jointless track circuit on plain sections, which has proven to be extremely reliable, and very few block joints, which rather simplifies Pway maintenance and bonding of course
Nicholas Lewis
9 Aug 2019
Oh axle counters aren't the total panacea after all!!
Guess they are the small yellow boxes in the 4ft?
E27007
25 May 2018
Those track circuit system arer good for plain line, but what of the S&C? What type of circuitry was used for S&C in Cannon Street?,
MrB
3 Jan 2016
Thanks for the colour on this.
