Signaller vacancy interview and reassingment help
samlf
1 Sep 2015
I applied for a vacancy that was a grade 6, 18 month fixed term contract in August.
Had the assessments on 8th September, told on 9th I'd passed all in the top 5 so was put forward for interview.
Application showed as 'under consideration for assessment 2' until beginning of November, where it then was closed and reassigned to another vacancy 'Medway resignalling vacancies'. Where it has then stayed, again showing as 'under consideration for assessment 2'.
However, there are now two vacancies advertised for Maidstone (which is where the one I have been reassigned to is based), but they say "Please note, if you have applied for this vacancy previously and your application is still live, you do not need to apply again". Well, technically I haven't applied for that role, but it seems I have been reassigned to that area. I called HR to ask them if that means I don't need to apply - they couldn't tell me, just said if I wasn't sure then I should apply.
I will probably apply for the grade 5 one (the other is grade 3), but I don't want to annoy HR/LOM if I shouldn't be applying as per the message on the advert.
Also the original role I applied for was grade 6, does anyone know if it will stay at grade 6 now it has been reassigned? Obviously a drop to grade 5 wouldn't be a massive problem, but a drop to grade 3 would be!
Apparently I could be waiting a while for an interview as recruitment has been frozen recently.
TomBoyd
2 Sep 2013
Apply for them all, there's no real harm in it.
Network Operations is not affected by the recruitment freeze.
samlf
1 Sep 2015
Ok I'll apply for the others then, thanks.
HR told me that it was affected by the freeze, but then they don't seem to know much about the vacancy!
Do you know anything about how the grade of the vacancy might be affected, or is it a case of I'll have to wait and see.
TomBoyd
2 Sep 2013
HR didn't know where my interview even was on Monday. I'm not sure HR can tie their own shoelaces.
I have no idea either though
samlf
1 Sep 2015
Looks like I'll wait and see then! Although at this rate I'm not expecting to hear from them before 2016...
Looks like their website is down now too so cant apply for the other jobs yet
