Llanigraham
You wouldn't necessarily know if just the blade was missing, leaving the spectacle plate and mechanical grubbing intact, until someone stopped to report it! I suppose you'd be able to work normally in darkness though, as the nighttime indications would remain. If the spectacle plate went missing too, you'd know about it, as that's what the arm detection is attached to. The latter serves to indicate the position of the arm where the signal's not visible from the box (and sometimes, for example if the block controls check that the home signal is at danger before allowing a 'line clear' to be given, even if it's clearly visible), so you know either by that or by direct observation if a signal failed to return to danger.
Arm detection? Really? Not fitted on any of the signals in my area!
If the driver saw the blade was missing but was expecting it to be clear from the distant signal, would they have to stop the train immediately at the signal and notify you or do it as soon as reasonably practicable?
Yes, immediately. Either using GSM-R, the SPT or their mobile.
