Signal Passed at Danger
yardman
6 Dec 2008
We're speculating when the OP has been very clear on what happened. Personally I can't see the need for it.
You generally can't sneak past a signal at danger without getting a TPWS activation. The TPWS receiver may indeed be a little way back from the very front of the train, but then the track loops are set a little in rear of the signal to compensate.
The timeout duration is dependent on the stock and how the emergency brake is set. Irrespective of that you'd be there a while having a pleasant chat with the signaller and filling in the appropriate paperwork.
O L Leigh
Thats fair point, i only mentioned it as a thought. Maybe the driver had activated the override and had returned to normal operation, but as both you and GB quite rightly said, if that was the case then the driver would be held for quite awhile with the signallers. and the the various paperwork. :)
dan_156
5 May 2009
United Kingdom
It has happened to me a few times before normally after the line splits in two directions, the signal is at red, stays at red for a good 5+ minutes, driver gets out of the cab goes on the phone at the signal, gets back in the cab and proceeds normally.
