signal design engineer
Nz19
16 Nov 2019
Hi there, is there anyone on this forum that is a signal design engineer in the rail industry in this forum? I am interested in this career path. I really would like to be involved in the technical side of things in the industry. I have not worked in rail before, I was thinking that I would have to start as a signal technician and possibly work my way up from there. I do have a degree in Maths and I am currently working as a bus driver. Does anyone have there expertise to share in how I could at least start out on the ladder?
TSG
10 Aug 2020
Somewhere in the South of England
I've never been a signal design engineer but I am in what you might call 'allied trades'. It's possible that I have no clue what I'm talking about though.
IMHO there may be an easier way for someone with a maths degree to get a job as a signal design engineer than becoming a signal technician. That's not a bad job in itself, but of all the jobs in signals engineering I suspect designer is one of the ones where having been a signal technician is the least use. It could be a slow route too.
For general advice you could do worse than look here - https://signet-solutions.com/jobseekers (note the value placed on some electrical knowledge)
If you get in, you'll have to pass the exams to get on in the business so you may as well start reading up - https://www.irse.org/Qualifications-Careers/IRSE-Exam
You can do Module A without being a member and the reading list is all freely available. If you hadn't got a job in that line by October, I'd guess passing that would show readers of your CV you're properly serious.
Good luck
