Signal areas controlled by NX panels
rmHawk765
8 Apr 2025
ECML South
Does anyone have a definitive list of areas currently controlled by NX panels? I haven't been able to find anything particularly useful.
Freightmaster
Verified Rep
7 Jul 2009
I'm afraid it's like when people ask for areas controlled by semaphore signalling and/or mechanical boxes;
you'll get loads of suggestions, some of which will be out of date, but there is not 'official' list available to
the public.
rmHawk765
8 Apr 2025
ECML South
Deleted
the public.
I understand there's no official list - a community list is fine so long as it's not terribly out of date (I can trace down recent closures easily). It's mostly for larger areas I ask, so I do think it's a bit easier than mechanical boxes where they often control small areas.
Geeves
6 Jan 2009
Rochdale
Warrington, Preston and Carlisle must be some of the larger ones remaining? Locally (to me) Rochdale West and Wigan Wallgate Station box are NX panels
pokemonsuper9
20 Dec 2022
Greater Manchester
Oh that's cool (just looked up what it is) I assumed there were levers in there since that's what I think of when I hear signal box, but that's cooler and makes more sense given the lack of semaphores to need levering.
Geeves
6 Jan 2009
Rochdale
I think Eccles might be too but could be wrong! Like you say quite a lot of these old on the outside boxes were changed over a good while ago, but obviously no clue from the outside I just remembered a really obvious one. Manchester Piccadilly!
MadMac
13 Jun 2008
Moorpark, CA
Working on the basis that the OP’s intent refers to physical panels, as opposed to VDU-based systems operating NX-based interlockings, here’s the position in Scotland:
Kilmarnock
Fort William Junction (part)
Perth
Dundee
Aberdeen
Stirling Middle (Alloa line)
I believe that Tweedmouth, Alnmouth and Morpeth are still actual panels. Others that come to mind:
Doncaster
Scunthorpe
Colchester?
Upminster?
Three Bridges
North Kent?
Eastleigh
Swindon?
Gloucester
Westbury
Exeter
Plymouth
Bristol
Salisbury
Port Talbot
Stoke?
Rugby?
Chester
Crewe?
There will be other smaller ones that don’t immediately spring to mind.
MarkyT
20 May 2012
Torbay
Use The British Power Signalling Register: https://bpsr.org.uk/
Open the spreadsheet.
Select 'Interfaces' tab.
Use Autofilter and select for all entries under heading 'Interface Type' containing the text NX, then select for all empty fields under 'Decommissioned'.
The data claims to be correct as at January 2026 so should produce an accurate list though might not catch some of the the very latest closures or control transfers.
Port Road
27 Sep 2025
Kilmarnock
Perth
Dundee
Aberdeen
Doncaster
Scunthorpe
Colchester?
Upminster?
Three Bridges
North Kent?
Eastleigh
Swindon?
Gloucester
Westbury
Exeter
Plymouth
Bristol
Salisbury
Port Talbot
Stoke?
Rugby?
Chester
Crewe?
Don't forget Dumfries.
Geeves
6 Jan 2009
Rochdale
MarkYT's link is an incredible treasure trove of information!
I pulled this out from the vast amount of data, every NX panel remaining in the country in A to Z order including date commissioned including various versions replaced or updated over the years.
Aberdeen (1)NX(PP)[+]ML Engineering
21/06/1981​
Aberdeen (2)NX(PP)[+]LB Foster (TEW) SM48
29/04/2019​
Aberdeen (3)NX(PP)[+]LB Foster (TEW) SM48
11/08/2019​
Aberdeen (4)NX(PP)[+]LB Foster (TEW) SM48
06/01/2020​
Allington JcnNX(PP)[+]TEW SM48
03/10/2005​
Alnmouth (4)NX(PP)[+]GEC-Alsthom
11/12/1990​
Altofts Jcn LCPNX(TP)[+]NRS
20/09/1997​
ArundelNX(PP)[+]Westinghouse M5
22/11/1979​
Ascott Under Wychwood (2)NX(TP)[+]Henry Williams Integra Domino
06/06/2011​
Aspley Guise LCPNX(KS)[+]GETS VHLC
06/09/2004​
AstonNX(PP)[+]TEW SM48
12/10/1992​
Ayr LCPNX(PP)[+]GEC-GS
01/06/1986​
Barassie LCPNX(PP)[+]Swissinco
25/05/1986​
Barnham SCNX(PP)[+]TEW SM48
10/11/2008​
BarnsleyNX(TP)[+]NRS (BR(ER))
14/04/1998​
Barrow Hill LCPNX(KS)[-]na
12/11/1981​
Basingstoke ASC (Dorset Coast Panel)NX(PP)[+]TEW SM48
16/04/2007​
Basingstoke ASC (Poole Panel)NX(PP)[+]TEW SM48
19/05/2014​
Basingstoke ASC (West of England Line Panel)NX(PP)[+]TEW SM48
27/02/2012​
Beckingham (2)NX(PP)[+]LB Foster (TEW) SM48
02/05/2021​
Bedford Cauldwell Depot Shunters PanelNX(PP)[+]TEW SM48
08/08/2004​
Bedford St Johns LCPNX(KS)[+]GETS VHLC
06/09/2004​
Bickley LCPNX(KS)[-]na
20/06/1982​
Biggleswade LCPNX(PP)[+]GEC-GS
16/01/1977​
Bo'ness LCPNX(PP)[+]Henry Williams Integra Domino
12/03/1979​
Borough Green LCPNX(KS)[-]na
18/12/1983​
Bow Brickhill LCPNX(KS)[+]GETS VHLC
06/09/2004​
Brancliffe East Jcn LCPNX(TP)[+]NRS
29/11/1997​
Bridlington (3)NX(PP)[+]LB Foster (TEW) SM48
31/10/2021​
Brighton LCPNX(KS)[-]na
17/03/1985​
Brightside Jcn LCP (2)NX(PP)[+]TEW SM48
27/12/2006​
Bristol (1)NX(TP)[+]Henry Williams Integra Domino
08/03/1970​
Britannia Crossing (Dart Valley Railway) (5)NX(DB)[+]DVR
14/03/2010​
BrockenhurstNX(PP)[+]ML Engineering
19/10/1978​
Canterbury Wye ACCNX(PP)[+]NRS (BR(ER))
15/12/2003​
Carlisle (1)NX(PP)[+]Westinghouse M3
18/02/1973​
Carlisle (2)NX(PP)[+]LB Foster (TEW) SM40
07/01/2026​
Carlton (3)NX(PP)[+]NRS (BR(ER))
01/02/1998​
Castleford (2)NX(TP)[+]LB Foster (TEW) SM48
31/10/2022​
Charing Cross LCPNX(KS)[-]na
16/04/1976​
Charlestown Jcn LCPNX(PP)[+]Henry Williams Integra Domino
07/12/1980​
Chessington South LCPNX(KS)[-]na
30/01/1972​
Chester PSB (1)NX(PP)[+]Westinghouse M5
04/05/1984​
Chester PSB (Hooton Panel)NX(PP)[+]TEW SM48
11/11/2013​
Chichester (2)NX(PP)[+]EB Signal Ltd (ML Engineering)
09/12/1991​
Clapham Jcn LCPNX(PP)[+]EB Signal Ltd (ML Engineering)
28/05/1990​
Clapham Yard Shunters PanelNX(PP)[+]EB Signal Ltd (ML Engineering)
28/05/1990​
Claypole (2)NX(PP)[+]NRS (BR(ER))
17/08/1997​
Cleghorn LCPNX(PP)[+]Unipart Rail (BR(ER))
05/12/2006​
Cliffe LCPNX(DB)[+]NRS
09/11/1997​
Clipstone Jcn (2)NX(PP)[+]TEW SM48
20/12/1997​
Colchester (3)NX(PP)[+]Henry Williams Integra Domino
05/12/1983​
Conisbrough LCPNX(PP)[+]Westinghouse M3
31/08/1980​
Cove Crossing LCPNX(PP)[+]NRS (BR(ER))
04/01/2004​
Crewe (2)NX(PP)[+]LB Foster (TEW) SM40
23/08/2015​
Croes Newydd North Fork (2)NX(PP)[+]Unipart Rail (NRS)
19/10/2009​
Cromer LCPNX(KS)[+]GETS VHLC
26/06/2000​
Crowle LCPNX(PP)[+]Westinghouse M2
15/10/1972​
Crystal Palace LCP (2)NX(PP)[+]Henry Williams Integra Domino
28/12/2008​
Dalmeny LCPNX(PP)[+]Henry Williams Integra Domino
13/05/1979​
Daventry IRFC Control CabinNXnot known
20/04/1997​
Deansgate JcnNX(PP)[+]Westinghouse M5
22/07/1991​
Decoy LCPNX(PP)[+]Westinghouse M3
09/09/1979​
Dinnington LCPNX(TP)[+]NRS
29/11/1997​
Doncaster (1)NX(PP)[+]Westinghouse M3
07/07/1979​
Dorchester (2)NX(PP)[+]Henry Williams
11/02/2018​
Drem LCPNX(PP)[+]Henry Williams Integra Domino
21/11/1977​
Dunbar LCPNX(PP)[+]Henry Williams Integra Domino
11/12/1977​
Dundee SCNX(PP)[+]Westinghouse M4
17/03/1985​
Earlswood LCPNX(KS)[-]na
02/07/1983​
East Croydon LCPNX(KS)[-]na
07/04/1984​
Eastleigh (2)NX(PP)[+]Henry Williams Integra Domino
14/09/1981​
Eastleigh (4)NX(PP)[+]Henry Williams Integra Domino
27/11/1995​
EcclesNX(PP)[+]TEW SM48
21/06/1998​
Ecclesfield West LCPNX(TP)[+]NRS
14/04/1998​
Elmers End LCPNX(KS)[-]na
27/09/1975​
Epsom LCPNX(PP)[+]ML Engineering
29/07/1990​
Evesham (2)NX(TP)[+]Henry Williams Integra Domino
22/08/2011​
Exeter (2)NX(PP)[-]Unipart Rail (Westinghouse M5)??/12/2006 - 2007
Fareham LCPNX(KS)[+]ML Engineering
20/06/1982​
Fenny Stratford LCPNX(KS)[+]GETS VHLC
06/09/2004​
Ferrybridge (3)NX(PP)[+]TEW SM48
18/04/2006​
Ferrybridge (4)NX(PP)[+]TEW SM48
27/05/2014​
Ferrybridge (5)NX(PP)[+]TEW SM48
09/09/2024​
Folkestone East (2)NX(PP)[+]TEW SM48
13/04/1998​
Ford LCPNX(KS)[-]na
09/12/1979​
Forders Sidings LCPNX(KS)[+]GETS VHLC
06/09/2004​
Forest Hill LCPNX(KS)[-]na
20/07/1975​
Fort William Jcn (2)NX(PP)[+]LB Foster TEW SM48
25/03/2024​
Gascoigne Wood (3)NX(PP)[+]Westinghouse M5
27/06/1982​
Gloucester (1)NX(TP)[+]Henry Williams Integra Domino
25/05/1968​
GooleNX(PP)[+]BR(ER)
19/01/1975​
Goonbarrow Jcn (1)NX(PP)[+]Henry Williams
17/11/2025​
Gordon Hill LCPNX(PP)[+]GEC-GS [R]
04/07/1976​
Grangetown (Teesside) (7)NX(PP)[+]LB Foster (TEW) SM48
19/11/2023​
Greenbank (2)NX(PP)[+]BR(LMR)
27/01/1980​
Gresty Lane SCCNX(PP)[+]LB Foster (TEW) SM40
07/12/2015​
Guildford ASCNX(PP)[-]TEW SM48
02/11/1998​
Gunhouse Jcn LCPNX(PP)[+]Westinghouse M2
01/04/1973​
Gunnersbury LCP (2)NX(PP)[+]TEW SM48
05/08/2007​
Hams Hall Control CabinNX(PP)[+]LB Foster (TEW) SM40ca 2025
Hatfield LCPNX(PP)[+]GEC-GS [R]
03/03/1974​
Hayes LCPNX(KS)[-]na
27/09/1975​
Haywards Heath LCPNX(KS)[-]na
25/06/1983​
Heighington (3)NX(PP)[+]TEW SM48
10/11/2014​
Herne Hill LCPNX(KS)[-]na
06/12/1981​
Hessle Road (3)NX(PP)[+]TEW SM40
12/01/2026​
Holme LCPNX(PP)[+]GEC-GS [R]
03/05/1998​
Hornsey DepotNX(PP)[+]LB Foster (TEW) SM40
31/05/2016​
Hove LCPNX(KS)[-]na
17/03/1985​
Howden LCPNX(PP)[+]NRS
09/11/1997​
Hull Paragon (3)NX(PP)[+]LB Foster (TEW) SM48
02/03/2025​
Hunterston LCPNX(PP)[+]BR(ScR)
09/11/1986​
Huntingdon LCPNX(PP)[+]GEC-GS
12/03/1977​
Hunts Cross (2)NX(PP)[+]NRS
22/05/2006​
Ilford Depot Control RoomNX(TP)[+]LB Foster (TEW) SM40
08/05/2017​
Immingham Reception Sidings (3)NX(PP)[+]BR(ER)
18/09/1977​
Inverkeithing LCPNX(PP)[+]Henry Williams Integra Domino
29/07/1979​
Kempston Hardwick LCPNX(KS)[+]GETS VHLC
06/09/2004​
Kemsley LCP (2)NX(KS)[+]GETS VHLC
29/03/2005​
KilmarnockNX(PP)[+]Henry Williams Integra Domino
12/04/1976​
Kilnhurst LCPNX(KS)[-]na
03/08/1980​
Kilwinning LCPNX(PP)[+]GEC-GS
05/04/1986​
Kirk Sandall LCPNX(PP)[+]Westinghouse M3
17/02/1980​
Kirkcaldy LCPNX(PP)[+]Henry Williams Integra Domino
08/06/1980​
Ladybank LCPNX(PP)[+]Henry Williams Integra Domino
12/10/1980​
Lancing (3)NX(PP)[+]Westinghouse M5
14/05/1988​
Leatherhead LCPNX(PP)[+]ML Engineering
05/08/1990​
Lenham LCPNX(KS)[-]na
28/04/1984​
Letchworth LCPNX(PP)[+]GEC-GS [R]
05/02/1977​
Lidlington LCPNX(KS)[+]GETS VHLC
06/09/2004​
Llandudno Jcn (2)NX(PP)[+]Elmside Engineering
10/02/1985​
Longsight LCPNX(PP)[+]TEW SM48
01/01/2004​
Low RowNX(PP)[+]TEW SM48
06/04/2009​
Maidstone East (1)NX(PP)[-]ML Engineering
18/12/1983​
Maidstone East (2)NX(PP)[+]TEW SM48
08/10/2001​
Manchester Piccadilly (2)NX(PP)[-]TEW SM40ca 2007
Manton Jcn (Manton Panel) (2)NX(PP)[+]TEW SM48
07/09/2013​
Marston LCPNX(KS)[+]GETS VHLC
06/09/2004​
Masborough LCPNX(KS)[-]na
29/07/1979​
Methley Jcn LCPNX(TP)[+]NRS
22/09/1997​
Midcalder LCPNX(PP)[+]Henry Williams Integra Domino
23/11/1981​
Milford (2)NX(PP)[+]LB Foster (TEW) SM48
08/09/2019​
Millbrook (Bedfordshire) LCPNX(KS)[+]GETS VHLC
06/09/2004​
Monktonhall LCPNX(PP)[+]Henry Williams Integra Domino
01/08/1977​
Moreton (Dorset) LCPNX(KS)[+]Westinghouse
01/06/1985​
Morpeth (2)NX(PP)[+]GEC-Alsthom
23/02/1991​
Motspur Park LCPNX(PP)[+]ML Engineering
21/07/1990​
New Beckenham LCPNX(KS)[-]na
27/09/1975​
New Malden LCPNX(PP)[+]ML Engineering
08/07/1990​
Newark LCPNX(PP)[+]Westinghouse M3
02/02/1980​
Newbridge LCPNX(PP)[+]Henry Williams Integra Domino
01/05/1978​
North Walsham LCPNX(KS)[+]GETS VHLC
26/06/2000​
Norton (South Yorkshire)NX(PP)[+]Westinghouse M3
26/10/1980​
Norwich LCPNX(PP)[+]GEC-GS
15/03/1987​
Norwood Jcn LCPNX(KS)[-]na
27/04/1984​
Oxted (2)NX(PP)[+]Westinghouse M4
11/07/1987​
Oxwellmains LCPNX(PP)[+]Henry Williams Integra Domino
11/12/1977​
ParkestonNX(PP)[+]Henry Williams Integra Domino
02/12/1985​
Parks Bridge LCPNX(KS)[-]na
06/02/1976​
Penistone LCPNX(TP)[+]NRS
14/04/1998​
Perth (2)NX(TP)[+]Unipart Rail
02/06/2013​
Plymouth (1)NX(TP)[+]Henry Williams Integra Domino
28/11/1960​
Plymouth (2)NX(TP)[+]Henry Williams Integra Domino
12/11/1973​
Plymouth (3)NX(TP)[+]Henry Williams Integra Domino
26/04/1998​
Polmont LCPNX(PP)[+]Henry Williams Integra Domino
25/11/2012​
Potters Bar LCP (2)NX(PP)[+]NRS (BR(ER))
02/06/2001​
Preston Park LCPNX(KS)[-]na
17/03/1985​
Preston (1)NX(PP)[+]Westinghouse M3
05/11/1972​
Prestonpans LCPNX(PP)[+]Henry Williams Integra Domino
11/09/1977​
Purley LCPNX(KS)[-]Westinghouse
14/01/1984​
Queenborough LCP (2)NX(KS)[+]GETS VHLC
29/03/2005​
Ranskill (3)NX(PP)[+]NRS (BR(ER))
07/09/1997​
Raynes Park LCPNX(PP)[+]EB Signal Ltd (ML Engineering)
06/05/1990​
Redford LCPNX(PP)[+]Henry Williams Integra Domino
11/05/1981​
Redhill LCPNX(KS)[-]na
10/05/1985​
Retford LCPNX(PP)[+]Westinghouse M3
13/01/1980​
RichmondNX(PP)[+]GEC-GS
24/02/1980​
Ridgmont LCPNX(KS)[+]GETS VHLC
06/09/2004​
Ridham Sidings LCPNX(KS)[+]GETS VHLC
29/03/2005​
Rochdale WestNX(PP)[+]TEW SM48
29/08/2011​
Romsey LCPNX(KS)[+]ML Engineering
17/10/1982​
Royston LCPNX(PP)[+]GEC-GS
05/02/1977​
Ryde St Johns Road (2)NX(PP)[+]OSL Global
08/07/2021​
St Andrews Jcn (Freight Panel)NX(PP)[+]TEW SM48
28/06/1994​
St Neots LCP (2)NX(PP)[+]TEW SM48
15/10/2001​
SalisburyNX(PP)[+]ML Engineering
17/08/1981​
Sandy LCPNX(PP)[+]GEC-GS
10/12/1977​
ScunthorpeNX(PP)[+]Westinghouse M3
01/04/1973​
SeamerNX(DB)[+]TEW SM48
10/04/2000​
Selby (2)NX(PP)[+]BR(ER) [R]
29/04/1973​
Selby (3)NX(DB)[+]NRS
09/11/1997​
Selby (4)NX(PP)[+]TEW SM40
07/10/2013​
Selhurst LCPNX(KS)[-]na
17/04/1984​
Shaftholme LCP (2)NX(PP)[+]TEW SM40
18/05/2014​
Sheerness LCPNX(KS)[+]GETS VHLC
29/03/2005​
Shireoaks East Jcn LCPNX(TP)[+]NRS
06/12/1997​
Shortlands Jcn LCP (2)NX(KS)[-]na
13/02/1983​
Shortlands Jcn LCP (3)NX(PP)[+]TEW SM48
07/04/2003​
Slade Green Depot Control Room (2)NX(PP)[+]LB Foster (TEW) SM40ca April 2015
Slade Lane Jcn LCP (2)NX(PP)[+]TEW SM48
25/12/2004​
Slateford LCPNX(PP)[+]Henry Williams Integra Domino
17/08/1981​
South Croydon LCPNX(KS)[-]na
01/04/1984​
South Tottenham Station Jcn (2)NX(PP)[+]Contelec Engravings SACO
02/11/2009​
Stainforth Jcn LCPNX(PP)[+]Westinghouse M3
29/06/1980​
Stewartby Brickworks LCPNX(KS)[+]GETS VHLC
06/09/2004​
Stewartby Green Lane LCPNX(KS)[+]GETS VHLC
06/09/2004​
Stewarts Lane LCPNX(KS)[-]na
17/05/1980​
Stirling Middle (1)NX(PP)[+]TEW SM48
25/03/2008​
Stoats Nest Jcn LCPNX(KS)[-]Westinghouse
14/01/1984​
Stoke LCPNX(PP)[+]GEC-GS
06/07/1975​
Stourton LCPNX(PP)[+]Westinghouse M5
28/07/2002​
Swale LCP (2)NX(KS)[+]GETS VHLC
29/03/2005​
Swanley LCPNX(KS)[-]na
19/06/1983​
Swinton Jcn LCPNX(KS)[-]na
23/11/1980​
Tallington LCP (2)NX(PP)[+]TEW SM48
27/08/2001​
Tees YardNX(PP)[-]Westinghouse MCD [R]
12/08/1962​
Thorne Jcn LCPNX(PP)[+]Westinghouse M2 [R]
29/06/1980​
Thornton LCPNX(PP)[+]Henry Williams Integra Domino
16/06/1980​
Three Bridges DepotNX(PP)[+]LB Foster (TEW) SM40
13/07/2015​
Three Bridges SC (1)NX(PP)[-]Westinghouse M3
25/06/1983​
Three Bridges SC (2)NX(PP)[+]TEW SM48
30/08/2005​
Three Bridges SC (4)NX(PP)[-]TEW SM40
12/12/2009​
Three Bridges SC (5)NX(PP)[+]TEW SM48
17/03/2014​
Tisbury LCPNX(KS)[+]BR(SR)
23/03/1986​
TonbridgeNX(PP)[+]TEW SM40
25/10/2009​
Townhill LCPNX(PP)[+]Henry Williams Integra Domino
30/03/1981​
Treeton Jcn LCPNX(KS)[-]na
03/10/1982​
Tweedmouth (4)NX(PP)[+]Unipart Rail (GEC-Alsthom)
22/10/2007​
Upper HollowayNX(PP)[+]ML Engineering
10/11/1985​
Victoria SC (South Eastern Panel)NX(PP)[-]Henry Williams Integra Domino
17/05/1980​
Wakefield Kirkgate (3)NX(PP)[+]TEW SM48
27/12/2007​
Walpole LCPNX(KS)[+]GETS VHLC
26/06/2000​
WarringtonNX(PP)[+]Westinghouse M3
02/09/1972​
Waterloo LCPNX(PP)[+]EB Signal Ltd (ML Engineering)
02/04/1991​
Welbeck LCPNX(PP)[+]NRS
20/12/1997​
Wembley Main Line SCC (1)NX(PP)[-]TEW SM48
10/07/2000​
Westbury (3)NX(PP)[-]Westinghouse M5 / Unipart Rail (Westinghouse) M5ca ??/12/2007
Whitlingham Jcn LCPNX(KS)[+]GETS VHLC
26/06/2000​
Whitwood Jcn LCPNX(TP)[+]NRS
15/09/1997​
Wigan Wallgate (3)NX(PP)[+]TEW SM48
11/10/2004​
Wimbledon SC (1)NX(PP)[-]EB Signal Ltd (ML Engineering)
12/04/1990​
Wimbledon SC (Barnes Panel)NX(PP)[+]Adtranz (ML Engineering)
30/12/1996​
Wimbledon SC LCPNX(PP)[+]EB Signal Ltd (ML Engineering)
12/04/1990​
Winsford (3)NX(PP)[+]TEW SM48
14/09/1997​
Woburn Sands LCPNX(KS)[+]GETS VHLC
06/09/2004​
Woking ASC (1)NX(PP)[-]TEW SM48
24/02/1997​
Woking ASC (Farnham Panel)NX(PP)[+]TEW SM40
27/08/2013​
Woolley Coal Siding (2)NX(PP)[+]LB Foster (TEW) SM48
12/03/2018​
Wootton Broadmead LCPNX(KS)[+]GETS VHLC
06/09/2004​
WorksopNX(TP)[+]NRS (BR(ER))
29/11/1997​
Worstead LCPNX(KS)[+]GETS VHLC
26/06/2000​
Worthing LCPNX(PP)[+]Westinghouse
04/06/1988​
Wroxham LCPNX(KS)[+]GETS VHLC
26/06/2000​
5 Aug 2015
Norfolk
Is this somewhat inflated by the Local Control Panels though? I caught Cromer, North Walsham, Worsted and Whitlingham Jnc LCPs which I presume correspond to the Interlockings/ relay rooms under control of the single panel Trowse Swing Bridge box which definitely is not an NX panel.
And also, what is Three Bridges panel 5 doing commissioning new NX in 2014? Like for like renewal or is this list suggesting something different like the interlocking technology
Geeves
6 Jan 2009
Rochdale
From what I could work out rather than panel number it was showing an NX replaced by another NX? Carlisle for example just took over Kingmoor with a larger panel which I assume replaced version 1 which is why it shows twice. As for LCP I cannot say but they must be showing for a reason
5 Aug 2015
Norfolk
My understanding of an LCP is that it allows each individual interlocking area to be manually controlled on-site if something cataclysmic happens to the normal signal box. I wonder how often they're actually used.
MarkyT
20 May 2012
Torbay
Or a failure of the communications medium between them. Useful for comprehensive testing of a new remote interlocking prior to hooking it up to the panel, for maintaining control during major signalling work such as renewing a TDM or panel processor system, and transferring control of an interlocking to a larger operating centre. I assume included LCPs use the NX route setting method. Some local panels use a more basic method than the main signal box panel. Those using OCS (one control switch (per route)), for example, or SFS (single function switch) would be excluded. The Cromer line has US style remote electronic interlockings in equipment buildings distributed at junction complexes along the route. While the usual control uses VDUs at Trowse, the individual areas have small local panels at each site.
Here's a very typical N. American installation with a local panel. I recall the Cromer line being very similar.
rmHawk765
8 Apr 2025
ECML South
Yes, that is exactly what I mean.
Thanks so much - I will have a look. Will post soon about the project I'm planning, for which I asked about this.
MadMac
13 Jun 2008
Moorpark, CA
And Inverness.
I thought Inverness had gone all-VDU fairly recently, but I’ll check. (Edit) Panel decommissioned end of 2024.
To my eternal shame, I had completely forgotten about BPSR. That’s the work of retired Doncaster signalman Andy Overton, and unquestionably the most comprehensive listing of the various signalling systems/interfaces out there.
Annetts key
13 Feb 2021
West is best
Kilmarnock
Perth
Dundee
Aberdeen
Doncaster
Scunthorpe
Colchester?
Upminster?
Three Bridges
North Kent?
Eastleigh
Swindon?
Gloucester
Westbury
Exeter
Plymouth
Bristol
Salisbury
Port Talbot
Stoke?
Rugby?
Chester
Crewe?
All the NX panels between Bristol and London Paddington have been decommissioned and replaced by TVSC.
That includes Swindon.
Bristol has lost the B, C and D positions (Temple Meads area, Bath area and Stoke Gifford / Patchway / Filton / Westerleigh / Charfield / Chipping Sodbury area) leaving just the A position (Bridgwater / Weston-super-Mare / Yatton area).
Newport, Cardiff and Port Talbot have been replaced by the South Wales Signalling Centre.
21/06/1981​
29/04/2019​
11/08/2019​
06/01/2020​
03/10/2005​
11/12/1990​
20/09/1997​
22/11/1979​
06/06/2011​
06/09/2004​
12/10/1992​
01/06/1986​
25/05/1986​
10/11/2008​
14/04/1998​
12/11/1981​
16/04/2007​
19/05/2014​
27/02/2012​
02/05/2021​
08/08/2004​
06/09/2004​
20/06/1982​
16/01/1977​
12/03/1979​
18/12/1983​
06/09/2004​
29/11/1997​
31/10/2021​
17/03/1985​
27/12/2006​
08/03/1970​
14/03/2010​
19/10/1978​
15/12/2003​
18/02/1973​
07/01/2026​
01/02/1998​
31/10/2022​
16/04/1976​
07/12/1980​
30/01/1972​
04/05/1984​
11/11/2013​
09/12/1991​
28/05/1990​
28/05/1990​
17/08/1997​
05/12/2006​
09/11/1997​
20/12/1997​
05/12/1983​
31/08/1980​
04/01/2004​
23/08/2015​
19/10/2009​
26/06/2000​
15/10/1972​
28/12/2008​
13/05/1979​
20/04/1997​
22/07/1991​
09/09/1979​
29/11/1997​
07/07/1979​
11/02/2018​
21/11/1977​
11/12/1977​
17/03/1985​
02/07/1983​
07/04/1984​
14/09/1981​
27/11/1995​
21/06/1998​
14/04/1998​
27/09/1975​
29/07/1990​
22/08/2011​
20/06/1982​
06/09/2004​
18/04/2006​
27/05/2014​
09/09/2024​
13/04/1998​
Ford LCPNX(KS)[-]na
09/12/1979​
06/09/2004​
20/07/1975​
25/03/2024​
27/06/1982​
25/05/1968​
19/01/1975​
17/11/2025​
04/07/1976​
19/11/2023​
27/01/1980​
07/12/2015​
02/11/1998​
01/04/1973​
05/08/2007​
03/03/1974​
27/09/1975​
25/06/1983​
10/11/2014​
06/12/1981​
12/01/2026​
03/05/1998​
31/05/2016​
Hove LCPNX(KS)[-]na
17/03/1985​
09/11/1997​
02/03/2025​
09/11/1986​
12/03/1977​
22/05/2006​
08/05/2017​
18/09/1977​
29/07/1979​
06/09/2004​
29/03/2005​
12/04/1976​
03/08/1980​
05/04/1986​
17/02/1980​
08/06/1980​
12/10/1980​
14/05/1988​
05/08/1990​
28/04/1984​
05/02/1977​
06/09/2004​
10/02/1985​
01/01/2004​
06/04/2009​
18/12/1983​
08/10/2001​
07/09/2013​
06/09/2004​
29/07/1979​
22/09/1997​
23/11/1981​
08/09/2019​
06/09/2004​
01/08/1977​
01/06/1985​
23/02/1991​
21/07/1990​
27/09/1975​
08/07/1990​
02/02/1980​
01/05/1978​
26/06/2000​
26/10/1980​
15/03/1987​
27/04/1984​
11/07/1987​
11/12/1977​
02/12/1985​
06/02/1976​
14/04/1998​
02/06/2013​
28/11/1960​
12/11/1973​
26/04/1998​
25/11/2012​
02/06/2001​
17/03/1985​
05/11/1972​
11/09/1977​
14/01/1984​
29/03/2005​
07/09/1997​
06/05/1990​
11/05/1981​
10/05/1985​
13/01/1980​
24/02/1980​
06/09/2004​
29/03/2005​
29/08/2011​
17/10/1982​
05/02/1977​
08/07/2021​
28/06/1994​
15/10/2001​
17/08/1981​
10/12/1977​
01/04/1973​
10/04/2000​
29/04/1973​
09/11/1997​
07/10/2013​
17/04/1984​
18/05/2014​
29/03/2005​
06/12/1997​
13/02/1983​
07/04/2003​
25/12/2004​
17/08/1981​
01/04/1984​
02/11/2009​
29/06/1980​
06/09/2004​
06/09/2004​
17/05/1980​
25/03/2008​
14/01/1984​
06/07/1975​
28/07/2002​
29/03/2005​
19/06/1983​
23/11/1980​
27/08/2001​
12/08/1962​
29/06/1980​
16/06/1980​
13/07/2015​
25/06/1983​
30/08/2005​
12/12/2009​
17/03/2014​
23/03/1986​
25/10/2009​
30/03/1981​
03/10/1982​
22/10/2007​
10/11/1985​
17/05/1980​
27/12/2007​
26/06/2000​
02/09/1972​
02/04/1991​
20/12/1997​
10/07/2000​
26/06/2000​
15/09/1997​
11/10/2004​
12/04/1990​
30/12/1996​
12/04/1990​
14/09/1997​
06/09/2004​
24/02/1997​
27/08/2013​
12/03/2018​
06/09/2004​
29/11/1997​
26/06/2000​
04/06/1988​
26/06/2000​
Both Exeter PSB and Westbury PSB are 1980s designs. Both are push-push NX types. As per normal practice at the time, they opened in stages. I can't remember the actual dates, but both were at least partly opened by 1989
They are supposed to be operated by signallers on a schedule so that the signallers can maintain their competence and to check that they still actually work. However, it's not unknown for this not to happen.
Actually emergency use is rare.
Gloster
4 Sep 2020
Up the creek
Westbury was complete at the beginning of February 1985, except for the bit at Bradford Junction that was added in 1990. The end of 1987 for Exeter, except for Paignton North in March 1988 and South in August 1989 when it was moved into the station building.
John Webb
5 Jun 2010
St Albans
.....And also, what is Three Bridges panel 5 doing commissioning new NX in 2014? Like for like renewal or is this list suggesting something different like the interlocking technology
This is 3 Bridges Signalling Centre (SC), not the nearby ROC, to which eventually the SC coverage will be moved, I understand.
5 Aug 2015
Norfolk
I saw Whitlingham Jnc interlocking room out the side of the window today, on such a hot day I wouldn't want to be scheduled to work in that glorified shipping container.
Ipswich and Norwich panels are still NX.
Good to know, is that going to change anytime soon?
Annetts key
13 Feb 2021
West is best
Well, the more recent REBs (Relocatable Equipment Building) are supposed to be provided with air conditioning. But either it works well, so if dressed for summer you may feel too cold, but if it can't cope with the heat, or its failed, the room becomes an oven... On a day like today, you wouldn't be able to stay inside for any length of time...
Older installations on the area where I worked just had a single extractor fan or nothing at all...
The brick relay rooms were just as bad.
Sunset route
27 Oct 2015
If my dates are correct, that’s when panel 7 extended its control down the Arun Valley line to fringe with Arundel Signalbox. Although in recent history panel 5 has had it’s FDM equipment replaced between Keymer Junction and Preston Park and new Bi-directional signalling between Copyhold Junction and Balcombe tunnel junction, although I forget the exact dates now.
High Dyke
1 Jan 2013
Yellabelly Country
Based of locations I formerly worked the scope of the LCP was limited. Whilst in 'normal' operating mode they had control of signals protecting level crossings, the routes could be overridden by the respective controlling PSB.
However, when 'local control' was taken, it gave the signaller at that location control of loops and crossovers, without any intervention by the controlling PSB, though you then signalled trains at their direction. The usual instruction, when switched-in, was to work straight up and down unless advised. Each location was eexpected to take 'local control' for an hour or so each Saturday, for knowledge retention. You could be asked to switch-in at other times too.
