Sign help?
Spaceflower
13 Jul 2007
I apologise if this thread is in the wrong section or has been asked before, but what does a white 'x' on a blue background mean?
thanks.
nutter
13 Nov 2005
Albrighton, Nr. Wolves, Shrops
It means the AWS warning you will have just recieved does not apply to you. I only know of them on branches. As the magnets are always live when a signal is on, it can't be turned off, when you pass it in the wrong direction, such as on a branch, you still get an aws warning. It's just so drivers don't get too confused
Spaceflower
13 Jul 2007
Thanks nutter, That makes sense. I encountered one in a bi-di loop 'in' BVE.
O L Leigh
20 Jan 2006
In the cab with the paper
In most instances the AWS magnet would be suppressed for trains travelling in the opposite direction so that no indication sounds inside the cab. However there are locations where this is not the case, so an AWS Cancelling Board is put up 200 yards beyond the magnet so that the driver knows that the indication received does not apply to that train.
O L Leigh
TDK
19 Apr 2008
Crewe
O L Leigh
They have them on the heart of wales line between Craven Arms and Sugar loaf, the yellow and black ones (for TSR or ESR's) are more common than the blue ones and these have the same ruling.
