Showing The pdf Instead Of Printing Out Ticket?
wintonian
15 Jan 2010
Hampshire
The technology is there, both for a hand-held device which can read a barcode (or a magstripe) and also for a high speed data transfer to a server which (a) logs that the ticket has been used and (b) sends a message back saying yea or nay.
Unfortunately I don't think it works whilst going through tunnels, which on some routes may be a slight problem.
GadgetMan
9 Jan 2012
As Wintonian mentions above, mobile data relies on being able to access a reliable signal from whichever mobile phone network the equipment utilises. As anyone who travels on the railway knows, there are vast stretches of railway lines where there is no mobile signal coverage.
From a personal view point, I already have enough to carry going through narrow train aisles with the Avantix and a brick sized chip & pin pad. Don't want yet another scanner adding to it.
GNER 91128
13 Jan 2011
Peterborough
But that's what they do on east coast is get their scanner out scan the QR code while reading it and then hand the ticket back sometimes punching it sometimes not.
wintonian
15 Jan 2010
Hampshire
One assumes therefore that is it not connected to a 'live' database.
GNER 91128
13 Jan 2011
Peterborough
You would have to assume so and therefore I can't really see the problem with just showing the pdf file of the tickets on my tablet's screen instead of printing them out at home, it is after all the greener option. ;)
I'll give it a go when I go up to EDB next month.
TUC
11 Nov 2010
There does seem to be a cultural issue at work here quite apart from the technology. From some of the comments above there does seem to be a suspecion of technology in some quarters which looks increasingly at odds with a customer base that is using their tablets and mobiles to buy anything and everything. For them to be faced with attitudes that are reluctant to even touch acustomer's mobile is not helpful to rail being seen as a modern industry for thenext generation.
Pumbaa
19 Feb 2008
The airline industry and ferry terminals can check/scan the PDF against a live database, we do not yet have that facility on board trains. If a family show you 4 print at home tickets on 4 pieces of paper it is easy to compare them to ensure they refer to 4 different ticket numbers and 4 different seat numbers. We can also visually inspect the security background.
Heathrow Express can... ;)
GadgetMan
9 Jan 2012
You can't compare a TOC that runs through London where a good quality mobile signal can almost be guaranteed with others that run through miles of countryside with no mobile reception for 20+ minutes at a time.
As I mentioned earlier, m-tickets are available in place of e-tickets for people who prefer using their phone screen as a ticket.
Don't really see what the issue is as passengers have already got a choice between a paper version or electronic version.
Having a physical ticket also means its easier to endorse with a note permitting a passenger to 'break' the usual rules of their ticket. No need to hunt around for scraps of paper.
34D
9 Feb 2011
Surely with the advent of GSM-R drivers' radios (which I believe use a mixture of the cellnet/O2 network and dedicated transmitters) there will in fact be a suitable infrastructure available?
andykn
5 Feb 2012
Could the database not be downloaded prior to the departure of the train? A bit like printing out the seat reservations? Or loading them onto the trains with electronic seat reservation displays.
So I'm allowed to board the plane without a ticket/boarding pass?
No, you need to have an e-ticket, but you don't need it with you when you check in. Just give the check in desk your passport and they tap in your name and go from there. If you want to check in at the airport using the machine you might need your booking ref no
They give you the boarding card from there or if you check in at home you will need a physical boarding card - there are too many agencies who need to see your boarding card between arriving at the airport and boarding the plane.
Brucey
7 Jan 2010
With Ryanair you MUST check-in online and print a boarding pass. Failure to do so results in a £60 per person per sector "boarding pass re-issue" fee.
maniacmartin
Fares Advisor
15 May 2012
Croydon
Another problem with the PDF on a phone is that phones' screens can be quite reflective and some barcode scanners can't read pictures of barcodes from them.
455driver
10 May 2010
The guard will carry a sheet of glass paper to take the shine off the screen!;)
34D
9 Feb 2011
So one is expected to check in _before_ leaving home? What is the point of that?
richw
10 Jun 2010
Liskeard
All you need with the airlines is your passport usually.
I went by LD Lines to France, all I needed was to stop my car in front of the camera/ sensor, it took my registration and checked me in, gave me the print outs. I needed to show my passport to a man in a booth a bit further down the check in lane, which was a very quick process.
Perhaps when booking online, use my webcam to picture myself, and then rail staff scan my face to see if I come up on a face recognition app. :p :lol:
VauxhallandI
26 Dec 2012
Cheshunt
And you have to do it several hours before the flight or it won't work.
You would think it would lead to more trouble for the airline if something happened to you between checking in on-line and stepping on the airplane.
Looking for people that aren't even the airport etc but as stated its a revenue opportunity not a process efficiency.
island
30 Dec 2010
Not really. Your boarding card is scanned as you enter security so if you didn't show up at the airport they'll know not to expect you at the gate.
richw
10 Jun 2010
Liskeard
not whenever I've used home check in. I've never been scanned at security (Manchester and Gatwick)
sheff1
24 Dec 2009
Sheffield
Strange. My home printed boarding pass has always been scanned at the entrance to security at MAN & LGW (and every other UK airport I have flown from)
wintonian
15 Jan 2010
Hampshire
I was at Gatwick a year ago on a EZY flight to Edinburgh..
richw
10 Jun 2010
Liskeard
I've always had to present them, but never noticed them scanning them, is the scanning device quite discreet?
wintonian
15 Jan 2010
Hampshire
I can't quite remember myself but they don't half do a lot of typing on the keyboard - possibly explaining the half hour long queue. :-x
I'll stick to Southampton, I'm yet to see a queue there.
richw
10 Jun 2010
Liskeard
although from what I've read now Southampton has stolen most of bournemouths passengers but that's for an entire different discussion. All of my trips next year are from Exeter.
