Should Reading be renamed to "Reading Central"?
LUYMun
15 Jul 2018
Cancelled
With the opening of Reading Green Park, the total number of National Rail stations with "Reading" in its name has risen to 3. If stations encapsulating the Reading area should be included (Tilehurst, Earley, Winnersh Triangle, Winnersh) this takes the total number to 7. Surely by now, given the location of Reading is firmly in the town centre, it would be sensible to have the main station renamed to Reading Central?
telstarbox
23 Jul 2010
Wennington Crossovers
Leeds, Sheffield, Brighton, Oxford and Cambridge all seem to manage as single names. These all have a single "city centre" station like Reading. Birmingham, Manchester and Liverpool have multiple stations in their city centres.
Fawkes Cat
8 May 2017
The first question in response to this is surely whether there is any confusion between the various Reading area stations. If so, then maybe something should be done. But if not, then there’s no problem to be solved.
2192
16 Aug 2020
Derby UK
Reading Central was the name of the goods station down by the canal. It was on the end of a branch line that joined the Berks & Hants where the Basingstoke line split off. Presumably it was there to form easy exchange with canal traffic in the early days.
Tio Terry
2 May 2014
Spain
Just think of the thousands of design and construction drawings which all say "Reading" that would need to be changed, P.Way, S&T, M&EE, Buildings etc.. The station fire, safety and evacuation plan that would need to be updated for the emergency services, the list goes on and on.
I suppose you could argue that you wouldn't need to change them until it became necessary to update them but that would lead to a rather confusing situation where some are changed and some not.
Is it really necessary to change the name? There doesn't seem to be any confusion amongst the travelling public.
Northampton
you could add (Central/City/General/Great Western*/Middle/Hbf) to the platform boards and the journey planner name without needing to update all the safety critical info and records (which is what I would also like them to do at Cambridge) - like they added 'for Bankside and Southbank' to Blackfriars without changing the official documentation.
Leeds and Sheffield do sometimes get their old suffixes back (City and Midland respsectively), Oxford only has potential confusion with Oxford Parkway so is OK for now, and Brighton doesn't have any other stations starting with Brighton (They're all named after the individual settlements the suburbs developed around, rather than 'Brighton East' or whatever). Cambridge I've mentioned above - and is probably the closes comparison to the Reading situation.
I personally think it would be best if situations where there is a '<Place> station' and '<place> <Suffix> station' are avoided totally - if you open a new station in a town with a previously unclarified name, part of the project should be to add *something* to the old one to prevent confusion, even if it's just on the public-facing side and not a change of the name in the back office parts of the railway. Like the use of counties when there are stations in two towns with the same name (Ashford and Gillingham the most famous examples).
*I think Reading GW would be inadvisable, as it doesn't really help confusion with Reading West, but it's the kind of thing local councillors would prefer as it has 'Great' in it's name.
Fawkes Cat
8 May 2017
Since the station is also served by SWR, XC and TfL it would also be rather unhelpful.
Fawkes Cat
8 May 2017
Reading General would probably be the one to go for if you did do it as it's the historic name that some people still use.
And since 'General' is the traditional GW term for the main station in town*, I think it also adequately allows for GW imperialism over other companies.
*when there's no local alternative (Temple Meads, Spa, etc.)
LUYMun
15 Jul 2018
Cancelled
Although General doesn't really emphasise the importance of a centrally located station to most passengers than a "Central" suffix.
True. I suppose the argument for General to be used is "Hauptbahnhoefe" which *aren't* quite central, e.g. Wrexham, or where the name is already used, e.g. Liverpool (note: I'm not actually proposing renaming Lime St! :) )
Cambridge might be another one where General would be better than Central as it, er, isn't.
cactustwirly
10 Apr 2013
What part of Reading isn't central?
5 Sep 2020
Berkshire
Looking at the Reading Borough Council map:
The most central station is Reading West.
The most westerly station is Tilehurst.
If renaming was being considered:
Reading West would be more aptly named Reading (Oxford Road).
Tilehurst, being on the edge of Tilehurst, but close to the river, would perhaps be more aptly named Reading (Riverside).
While Reading, being in the Abbey ward, could perhaps be renamed Reading (Abbey). Or Reading (Abbey Ruins), since the Abbey closed in 1539.
Or perhaps it might be better just to leave things as they are.
Northampton
That borough map clearly excludes a sizeable portion of the built-up area, once again demonstrating that administrative and social boundaries can be very different.
Fundamentally, the number of people coming to Reading who don't want the main Town Centre station but instead want Reading West or Reading Green Park will be fairly small and Reading/Reading West has existed for long enough without causing total disaster.
cactustwirly
10 Apr 2013
That's ridiculous, the map is misleading as parts of Reading come under West Berks and Wokingham Council.
RobShipway
20 Sep 2009
I am pretty sure if a town like Newhaven until 2020 could cope with three stations all with the name Newhaven in the station title, which where a lot closer than the three Reading stations in distance. Then I am sure both the travellers too and local people can cope with travelling to their three Reading stations.
I really do not see the need to change Reading station from being Reading to be honest, as it would only give aggravation to the TOC's/Local council admins in getting the details changed as @Tio Terry has stated.
If Reading station name was to change, then the most appropriate would be Reading Mainline.
Northampton
All 3 had suffixes though - Town, Harbour and Marine. And Marine wasn't a functional station since 2008, just a spotter's oddity.
David Goddard
8 Aug 2011
Ely
No need for any change, is there evidence if this “confusion”?
Is it a solution looking for a problem?
“Greater Reading area” is an interesting discussion, but it stops short of Winnersh Triangle!
RobShipway
20 Sep 2009
Granted, but when people talk about travelling to Newhaven by train, it is generally thought that they are travelling to Newhaven Town not Harbour.
If you work on the basis of needing to rename Reading Station as Reading Central, then I would also suggest that you rename all the stations with the name London Road while you are at it, to be place name - London Road, rather than London Road - Place name (i.e. London Road - Brighton, would need to be changed to Brighton London Road).
Northampton
Yes but the stations are barely 200m apart, and Newhaven Harbour serves a very specific part of the town (it helps that Town is also the first station you stop at on the way in from anywhere else).
Potentially although the (Brighton) is exactly what I'd suggest with Reading - i.e. Reading (General).
David Goddard
8 Aug 2011
Ely
Does the OP also propose a change at nearby Worthing?
