matacaster
Yes, I believe they are far less friendly to the environment. When I hear the BBC have correspondents in countries yet fly an expert roving reporter out so he can say it's a fire etc which any Muppet could say.
Yes, they do tend to have a far greater CO2 footprint per pax. Average statistics from memory lie somewhere between 5-15 times more polluting than a commercial airliner, but this obviously varies depending on how many passengers it is carrying and the type of aircraft, as well as what you are comparing it against.Are private jets significantly worse than a full-size plane (in terms of CO2 per passenger)? Often they're relatively small, light and not bogged down with loads of baggage.
For example, if looking at the fuel burn and thus emissions for an aircraft whilst in cruise (not a perfect indicator by any means but a good indicator of the general gist) an A320 will burn around 2500kg/hr at cruise carrying 180+ pax, whilst a Cessna Citation private jet will get through around 800kg/hr whilst only seating 10.
Yes - permit every country in the world to levy an “overflight tax” on planes crossing their airspace. For once there would be little incentive not to tax!This is one of the more drastic changes. It would negatively affect high level business and culture. Just tax it, design a tax without loopholes for once.
Wouldn't some countries try to undercut their neighbours to encourage more flights through their own airspace, in the hope of raking in more revenue? That might actually increase emissions, if operators took a less direct route to avoid high-cost countries.Yes - permit every country in the world to levy an “overflight tax” on planes crossing their airspace. For once there would be little incentive not to tax!
Less friendly than what? Commercial airline flights? DB using 66s instead of AC traction? India building new coal-fired power stations? Surely there are more concerning issues than a few private jet flights. Personally, I couldn't care less.
In total, all of Europes private jet flights over the last 3 years have emitted somewhere close to as much CO2 as an airline the size of easyJet does in 1 year. Arguably then it is not a case of private jet flights being ridiculously polluting as a whole, but it is certainly a large contributor in the aviation industry itself.Although it's not really about what's worse, all those things need to be dealt with to reduce our carbon emissions.
The reason why private jets are seen as so bad is because even fairly limited use had a significant impact.
BBC journalists almost always use commercial flights, it's very rare that it's anything other than that or the RAF (if it's a war zone) on a pre-existing flight.Yes, I believe they are far less friendly to the environment. When I hear the BBC have correspondents in countries yet fly an expert roving reporter out so he can say it's a fire etc which any Muppet could say.
Because that's what the post I quoted mentioned specifically. Other journalists travel the same way.Also, why single out the BBC?
Flying reporters to where things are happening is something that a lot of news channels will do.
As such, why day the BBC and not also mention Channel 4 news, ITN, Sky News or any of the foreign news channels who would also send people.
It should also be noted that sometimes news organisations will share resources - for example sometimes in North America the BBC will use CBS:
As such the presence of a BBC news reporter could actually see content being created for at least two news networks.
Yes and they often deposit their emissions at a higher and more harmful altitude than regular airliners. A G650 can make it up to 51,000 feet and will typically cruise in the upper 40s.Are private jets significantly worse than a full-size plane (in terms of CO2 per passenger)? Often they're relatively small, light and not bogged down with loads of baggage.
That is already happening. All the time. For American carriers, for instance, its often preferred to avoid Canadian airspace which is relatively expensive. Algorithms exist to work out the cheapest routings for transatlantic flights, which particularly from the US West Coast might stay further south than the most direct route, even if that induces greater fuel burn.Wouldn't some countries try to undercut their neighbours to encourage more flights through their own airspace, in the hope of raking in more revenue? That might actually increase emissions, if operators took a less direct route to avoid high-cost countries.
Even more so than aircraft fuel taxes, this sort of tax would require an international agreement to charge the same rate (probably proportionate to distance rather than a flat fee) at least for everyone in a particular region.
Exactly, and by contributing to environmental pollution they are thus keeping themselves in a jobHow would people be able to attend global environmental conferences if they couldn't fly by private jets?
Slight difference between the environmental impact of a car vs the environmental impact of a private jetNo of course not - for the same reasons that private cars should not be banned.
You’re absolutely right - there are so few private jets around as to make little difference, while there are so many private cars around that banning them all could have a massive impact.Slight difference between the environmental impact of a car vs the environmental impact of a private jet
The two things are completely different.No of course not - for the same reasons that private cars should not be banned.
However, even I would acknowledge cars have a social benefit to a lot of people (and I am fairly anti-car) whereas private jets benefit very few.You’re absolutely right - there are so few private jets around as to make little difference, while there are so many private cars around that banning them all could have a massive impact.
It isn't?! Why not? Private jets are largely a vanity thing, a status symbol among the super-rich.Aviation fuel used in private jets should be fully taxed in the way fuel in private cars is.
Jet fuel is fully rebated. There are limited circumstances- pleasure flying entirely within the UK- where it will attract VAT, but there is no duty on jet fuel.It isn't?! Why not? Private jets are largely a vanity thing, a status symbol among the super-rich.
Jet fuel isn’t taxed as a result of long-standing international treaty. Its pointless trying to tax jet fuel here in the UK alone, unless there is a similar global agreement to do so (which thankfully some other countries will never go for). That’s because airlines - and private jet operators - will simply tanker in fuel in their aircraft from abroad. And carrying unnecessary excess fuel beyond that required for the next journey increases emissions through the extra weight being carried.It isn't?! Why not? Private jets are largely a vanity thing, a status symbol among the super-rich.
Why "thankfully"? Isn't it morally right that a damaging activity carried out by privileged people does at least reimburse society to some extent for its consequences?Jet fuel isn’t taxed as a result of long-standing international treaty. Its pointless trying to tax jet fuel here in the UK alone, unless there is a similar global agreement to do so (which thankfully some other countries will never go for). That’s because airlines - and private jet operators - will simply tanker in fuel in their aircraft from abroad. And carrying unnecessary excess fuel beyond that required for the next journey increases emissions through the extra weight being carried.
