Halifaxlad
Inspired by the thread '
www.railforums.co.uk
and because HS2 train lengths are impacted by this plan to split and join services I thought it would make an interesting discussion whenever or not HS2 services should split and join!
So do you think HS2 services should split and join ?
Regardless as to the length of trains, just the principle behind splitting and joining!
Should some HS2 trains be 250m long?'
With the scaled back nature of HS2, there will be less of a need for portion working requiring two 200m units to make the most out of the 400m maximum length, thus more services running as single units, with fixed 400m long trains only likely to be used on services from London Euston to...
