Should CrossCountry keep Turbostar fleets and Local services?
dk1
2 Oct 2009
East Anglia
If platform capacity is an issue then they could always send some to Birmingham Airport to reverse. TFW currently send their hourly Aberystwyth / Pwllheli / Holyhead / Shrewsbury to Birmingham service to Birmingham Airport to reverse. So i am sure the Birmingham to Cardiff service could be sent there too if it was split and TFW took over. Birmingham Airport could easily handle a second hourly service terminating there.
Even if capacity is available you are making the route less and less efficient.
Topological
20 Feb 2023
Swansea
TfW running to Birmingham has a lot to be said for it.
However, the current schedule has the Cardiff to Birmingham arriving at about xx:45, but the Birmingham to Cardiff is xx:30. There would need to be some form of recast to make a reversal termination work.
In all cases a different path would need to be found that still allows sufficient turn around time in Cardiff (or extends beyond Cardiff).
One option to avoid New Street termination is to run via the Camp Hill in one direction. That severs University stops in one direction.
Another option is to terminate at Moor Street. Moor Street termination would be convenient for onward HS2 connections (e.g. to Manchester/North West), but is likely to do little for other connections. Also cuts off University stops.
Without consulting the timetable, is a wildcard option that the stock from the Shrewsbury* train continues around Camp Hill to go to Cardiff, whilst the inward working from Cardiff goes to Shrewsbury*? That would cut off the Birmingham Airport direct service from places on the TfW route, but maybe WMT could extend their trains if that airport connection is so important. I would have thought Manchester Airport serves a lot of people in Shropshire (and does not have a direct train).
Worth saying this would need more 197s so is probably a complete non-starter no matter how much I would like to see more 197s.
CrossCountry having 170s interworking Nottingham and Leicester* services at New Street is straightforward enough and may allow for diagrams that do not have such a tight turnaround from the inward Leicester forming the outward Stansted (for example). The saved 170s could either strengthen services, or create an extension from Leicester to Nottingham and allow interworking of diagrams at Nottingham as well.
Failed Unit
26 Jan 2009
Central Belt
I am on the page they should never have got split up.
However you rejoin them regaining Nottingham- Birmingham via Leicester and Lincoln - Birmingham would be very positive.
Likewise more cross Birmingham trains would hour such as restoring Nottingham- Hereford and Nottingham- Liecester - Shrewsbury.
