Should a Station Manager be based at the station they manage?
21 Mar 2011
Sunny Scotland
As somebody from outside of the railwasy that was my reaction. I know that I have worked in companies where "manager" means that you are on a particular pay grade and others where it simply means that you have some supervisory responsibility. Nobody who has posted seems able to answer the underlying question, is there normally somebody on site at Hull, and at similar stations, who can take ownership of issues and direct other staff regardless of actual job title?
Yes..
tpjm
25 Jan 2019
The North
No there isnt.
There isn’t any at Scunthorpe, Grimsby, Cleethorpes, Brough or Selby, all TPE manned and Managed stations.
At smaller stations, i.e the ones you’ve mentioned, there are Customer Service Supervisors.
I must tell the single member of staff on duty at my local station of his (and it's invariably a him, although there are several of them) promotion.
I don’t know who operates your local station so couldn’t comment.
I’d like to think that my thorough, detailed and factually accurate answer did! (Given that my job involves liaising with all these people!!!) To repeat, YES, there is someone on site at Hull to direct staff (Duty Station Manager) and YES, they report to a Group Station Manager who is NOT based in Huddersfield.
tpjm
25 Jan 2019
The North
@tpjm backtracking on this already then.
And I thought Hull had Station Co-ordinators but what do I know...
Where did I say it was their job title...? The 'quotation' marks were to signify that. Hull has Station Team Leaders.
And if we're going to play that game, what about your post...
Also that Everything has to go through Manchester doesn't help when things go wrong as you've loads of people phoning the same 5-6 Numbers, they won't allow decision making by the Supervisors/Duty Managers in York, Liverpool, Hull etc. Other TOCs have moved on from that.
Indigo Soup
17 May 2018
It's a single-staffed Glasgow suburban station - obviously the one person who does all the duties that are needed isn't going to have the title of Station Manager. The stations in either direction get by just fine with no permanent staff at all, let alone an on-site Station Manager. Equally obviously, Scotrail will have a manager who covers that station along with a number of others. I can't say it's ever been an issue in the slightest.
2L70
18 Feb 2019
Barnetby
Hull has station co-ordinators, you may well call some of the station team leaders but some of them were employed as the former.
Enough bickering. You are welcome to disagree with each other and challenge the posting made by another member. However no-one is entitled to be rude or disrespectful to other members in the way that they do that. It is contrary to the Forum Rules in particular those under the heading 'Respectful'.
I strongly advise people to keep the above in mind.
Thanks!
