Sheffield to Wolverhampton split request
syorksdeano
7 Jan 2011
Can anyone help with this.
Sheffield to Wolverhampton day return, with a possible trip to Walsall day return.
Tickets are to be bought on the day, but I was wondering if a rover would be any good
SickyNicky
Verified Rep - FastJP
8 Sep 2010
Ledbury
Using straight splits without any rovers or similar, it would be:
SHEFFIELD to DERBY
OFF-PEAK DAY R Return £11.10
(outbound: Valid on any train except those timed to depart Mondays-Fridays before 0900. No travel restrictions on other days. )
(return: BY ANY TRAIN )
Route: Valid via any permitted route. Restriction code B3
DERBY to WOLVERHAMPTON
OFF-PEAK R Return £18.70
(outbound: Valid on any train except those timed to depart before 0930 Mon - Fri. No travel restrictions on other days. )
(return: Valid on any train except those timed to depart before 0930 Mon - Fri. No travel restrictions on other days.)
Route: Valid via any permitted route. Restriction code 2V
Edit: Derby to Walsall is £16.70 (same as Birmingham) so you might prefer that, then get a return from Walsall to Wolverhampton (£2.90, not via Birmingham, £5.70 via Birmingham - still cheaper than a daytripper).
alex17595
15 Mar 2013
Burton on Trent
Derbyshire wayfarer £11.60 (valid after 9am weekdays)
Burton on Trent - Wolverhampton OFF peak return £15.90
Train must call at Burton
sonic2009
19 Jan 2010
Crewe
If needing to travel from Walsall to Wolverhampton use the bus much quicker!
A single is £2.10 on the 529 or £4.00 daysaver if bought on the bus.
But when buying your train ticket to Wolverhampton ask for a Plusbus which is £3, ticket is valid all over the West Midlands including the tram, and most bus operators accept it! :)
A Wolverhampton PLUSBUS ticket gives you unlimited bus & tram travel on participating operators’ services, around West Midlands region, including all of Wolverhampton town.
Participating bus operators:
all operators in the West Midlands, (that participate in the 'n' bus ticketing scheme), including:- national express West Midlands & Midland Metro (trams), Arriva, Blue Diamond, De Courcey Travel, First, Midland, Stagecoach.
transmanche
27 Feb 2011
crosscity
5 Dec 2011
Just a small point £16.70 is the Off-Peak Return price to Walsall. An Off-Peak Day Return is also available for £16.00. Oddly, a day return fare from Derby to Wolverhampton is not available.
A larger point: the £2.90 return from Walsall to Wolverhampton (not via Birmingham) cannot be used in full as the only scheduled passenger train on the line is the Saturdays Only 06:38 Wolverhampton-Walsall!
sonic2009
19 Jan 2010
Crewe
syorksdeano:1732455 said:
Sonic, would that include Walsall to Birmingham? That is if a bus exists
Yes. The bus takes about 45 mins, I believe its the X51
