Sheffield -> Hebden Bridge - Permitted route?
Mcr Warrior
8 Jan 2009
What various permitted routes might be possible on an Anytime Day Return (£20.50) or Off Peak Day Return (£17.30) between Sheffield and Hebden Bridge, routed "not via Doncaster"?
Obviously not via Doncaster!
P.S. Would travel via Edale/Manchester ever be allowed?
sonic2009
19 Jan 2010
Crewe
Obvious routes would be :
Sheffield - Barnsley - Penistone - Huddersfield - Brighouse - Hebden Bridge
Sheffield - Barnsley - Wakefield - Leeds - Bradford - Hebden Bridge
Sheffield - Wakefield via Swinton - Leeds - Bradford - Hebden Bridge
Sheffield - Wakefield via Barnsley or Swinton - Brighouse - Hebden Bridge
Travelling via Edale/Manchester wouldn't this fail a fares check?
Llandudno
25 Dec 2014
Matlock
Howabout a South Pennines Day Ranger £26.80
A bit more expensive but you can just about do what you like!
Mcr Warrior
8 Jan 2009
Apart from travel before 0900 during the week!
Or travel on the Yorkshire side other than via Barnsley.
Otherwise not a bad shout! ;)
Llandudno
25 Dec 2014
Matlock
It’s a great ticket for breaking your journey and visiting the many excellent real ale pubs en-route though!
Plus railcard discounts are available for the Ranger ticket!
mangyiscute
6 Mar 2021
Reading
Yeah just to confirm via Manchester is not permitted, but you could get a Sheffield to Walsden off peak day return for £18.20 (or anytime for £21.90) which is valid via both Manchester and Leeds, and then travel via Manchester in one direction and Leeds/Huddersfield/Wakefield in the other - the only thing is that your train would have to stop at Walsden on the via Manchester journey, but you would be able to spend time in Manchester if wanted
sonic2009
19 Jan 2010
Crewe
Are you sure it's valid via Manchester and doesn't fail a fares check?
Mcr Warrior
8 Jan 2009
As they are for the walk up Anytime/Off Peak tickets.
However, not a bad shout for an off peak circular itinerary.
...the only thing is that your train would have to stop at Walsden on the via Manchester journey, but you would be able to spend time in Manchester if wanted
Good suggestion if valid, albeit typically only a 1tph service each way, during the day, calling at Walsden.
mangyiscute
6 Mar 2021
Reading
Searching for this journey with a via Manchester clause gives the £18.20 fare, and I even saw a journey that went from Manchester Victoria to Todmorden and then double backed to Walsden still for £18.20
I'm surprised that itineraries are being offered via Manchester, as it pretty comprehensively seems to fail the fares check. Perhaps there's a Routeing Point or other easement I'm missing?
The reason why double back itineraries are offered is that Walsden isn't a mandatory timing point - so trains that don't stop there, don't have it in their schedule. So journey planners can't detect that the train to Todmorden passes through Walsden. For all they know, Walsden is to the east of Todmorden. They would need an internal copy of the rail network's geography to detect the double back, which would take a lot of work to create and keep up-to-date - and isn't required for accreditation.
lyndhurst25
26 Nov 2010
If you don’t want to go via Manchester then what about a South Yorkshire Connect+ (£9.20, no time restriction) and a West Yorkshire Train DaySaver (£8.60, barred in morning and evening peaks Monday to Friday)? TOTAL £17.80. Your trains will need to stop at Denby Dale/Darton/Moorthorpe/South Elmsall, but you can then go via Doncaster, and you get South Yorkshire buses and trams thrown in for free.
kieron
22 Mar 2012
Connah's Quay
It's because of the "shortest route" rule, I think.
Using the distances in the routeing guide data, Sheffield-Walsden is 57.05 miles via Barnsley and Wakefield, 61.78 miles via Marple and 61.85 miles via Stockport. You can save 2.99 miles from the latter two by not catching a train between Manchester Victoria and Manchester Piccadilly, but you may not need to.
TUC
11 Nov 2010
How are the distances between the Manchester Stations calculated for shortest route purposes? It would seem unlikely that one can disregard 2.99 miles by choosing to walk between the stations.
mangyiscute
6 Mar 2021
Reading
I always get confused about whether train tickets with a transfer between the Manchester stations are valid on the trams so I always walk
Walks can be made where there is an interchange in the data but are not included in the calculations.
If this thread is seen by certain people, there could be a change made to prevent travel via Manchester in future though.
Where a route is within 3 miles of the shortest, it can be affected by a negative easement; the shortest route cannot be, so would require the fare to be re-routed.
driverd
29 Mar 2021
Sorry, as someone who was in a customer facing, revenue protection role for a good 5+ years, I can safely say I've never heard of a "fares check". What is this?
It does amuse me reading these threads, as the level of knowledge on here is usually miles greater than that of your average member of staff, who would typically use the rule of "does this sound reasonable".
Since Metrolink aren't a Train Company and thus aren't inherently a party to the NRCoT, National Rail tickets aren't valid on Metrolink services unless specifically endorsed as such (i.e. "Metrolink Ctlz"). In practice, only tickets for journeys within Greater Manchester have Metrolink validity - and then, not all cross-Manchester journeys have this validity.
It's a check undertaken for longer journeys, in order to determine which Routeing Point(s) (i.e. nearby major/junction stations) you can use for your journey.
You look at the fares from the origin station to each Routeing Point associated with the destination station, and allow RPs where the fare is the same or lower as the fare to the destination station. Essentially it's an attempt to avoid anomalous routes being permitted, although it's not foolproof.
To avoid you having to do the legwork, there's a Routeing Point Calculator here. Journey planners undertake this check when they determine whether a route is permitted.
In this particular example, Manchester Routeing Point Group fails the fares check, as the fare from Sheffield to Manchester is more than the fare from Sheffield to Walsden. But that doesn't affect the validity via Manchester, by virtue of it being the shortest route.
Indeed, and this is one of the fundamental flaws with the premise, upon privatisation, that the BR system of "reasonable routes" was too ambiguous and needed to be replaced with the Routeing Guide to precisely define what routes were permitted - because individual members of staff can't possibly have an encyclopedic knowledge of the Routeing Guide!
So now we have a system where people will sometimes be told that the fastest route, or another perfectly reasonable route, is not permitted and thus they can't buy a ticket for it - yet in practice their ticket would be accepted.
And vice versa, sometimes people will be offered itineraries via highly circuitous routes, which are unintentionally permitted, but their ticket will be rejected by staff on the ground because they don't have the training to know how to determine permitted routes.
TUC
11 Nov 2010
I agree that Metrolink are a separate company and not part of the NRCoT. I still think that if the will was there, there is much more that could be done as a commercial agreement for Metrolink to be valid on cross-Manchester tickets for journeys that extend out of Greater Manchester, in the same way as is the case for TfL and the tube.
Absolutely, and it's yet another example of the failure to ensure properly integrated public transport in this country.
driverd
29 Mar 2021
I see - so I presume this is automatically integrated into the likes of the National Rail journey planner? (Turns out yes, read before you reply, silly me!)
So, what do people mean when they say a journey may fail a "fares check"? Surely you just look if the journey planner populates a fare and that's your answer?
Right, okay - so is the fares check purely for TOCs to avoid fiddles? (I think there may have been one from Scarborough to York where it'd be cheaper to buy a ticket to Brough or somewhere, as the planners work on the assumption you're routing via the Yorkshire wolds).
Personally I'd say it's certainly a good idea to reduce ambiguity so I salute the sentiment, it's just a shame that the answer isn't too clear, and, the majority of journey planners arent clever enough to populate split tickets if the route is more important to the customer than journey time.
I suppose this is where staff discretion comes in handy - though of course its not ideal that it cannot be relied upon.
Well thank you very much for such an insightful answer - very much appreciated!
Yes, and they are required to comply with the results of the fares check, as a condition of their accreditation (i.e. right to sell tickets). Though not all retailers do comply - e.g. Pico4UK, which powers the Avanti and C2C sites.
It means that a particular associated Routeing Point can't be used when determining the mapped routes for the journey. In this example, Walsden is associated with Manchester Group, Accrington and Halifax Group. Sheffield is its own Routeing Point so there's no need to check anything on that end.
The fares check involves looking at the fares from Sheffield to each of Manchester, Accrington and Halifax - and seeing whether those fare is higher than the fare to Walsden. If the fare is higher (as is the case for Manchester and Accrington), then they are deemed not to be appropriate Routeing Points, hence you cannot use mapped routes from Sheffield to Manchester or Accrington for this journey. If the fare is the same (or less) then they are appropriate Routeing Points and so you can use mapped routes from Sheffield to Halifax for this journey.
The additional complexity here is that it's actually fares from September 1996 ("NFM64") which are used for the purposes of this check. This is to ensure that post-privatisation disparities in fare policies (which resulted in some TOCs' fares rising faster than others) don't change which Routeing Points can be used.
And as previously mentioned, the validity via the shortest route (or on a direct train) is not affected by the fares check, as this is something that is permitted under the NRCoT itself, without needing to refer to the Routeing Guide.
I think "fiddles" might be a strong word, but yes - it's a way to prevent the anomalous use of fares.
If that was the case, it's no longer an anomaly as Scarborough to Brough tickets are now explicitly routed 'via Hull' (plus the other associated Routeing Point, Gilberdyke, doesn't have any mapped routes to Scarborough via York). But you get the gist.
Whilst the sentiment may have been nice in theory, it's useless if staff aren't actually trained. If even you - as someone who worked in revenue protection for several years - didn't know this kind of thing existed until now, what chance does the average punter have?
And yes, journey planners should include split ticket functionality by default in my view, at the very least employing it when someone asks to travel via a non-permitted route. NRE is OK in this regard, as it does suggest splits in these cases; the problem is that it tries to hand people over to TOC retailers that generally can't handle several tickets arriving into a basket at once!
Whilst it's always welcome, people shouldn't have to rely on it. The fastest route should always be permitted in my view.
No problem!
61653 HTAFC
18 Dec 2012
Presumably Sheffield - Wakefield - Leeds - Dewsbury - Brighouse - Hebden Bridge would also be valid?
Also if going via Huddersfield, changing at Halifax (which has a more frequent service to Hebden Bridge) rather than Brighouse (which only has 1tph, with a 30min gap at best)?
Yes.
Yes - there's no double-back involved by changing at Halifax (though something involving a double back doesn't mean it can't be permitted!).
Mcr Warrior
8 Jan 2009
Thanks for everyone's input. So, basically for this particular flow, Doncaster has been 'twinned' with Manchester, and so a "not via Doncaster" ticket is effectively also "not via Manchester"! :rolleyes:
