Setting up a 2nd PC Monitor
If I get a third monitor it will hve to use the DisplayPort that I have remaining, which means it will be a more expensive monitor.
DisplayPort to DVI adaptors are available for under £10.
They are unfortunately merely electrical adapters, which means the computer has to support emulating a DVI port over DisplayPort connections.
And my card only supports three monitors if one uses DisplayPort (electrically).
AM9
13 May 2014
St Albans
My current rig utilises a HDMI port for one screen and a DVI-I port for the other, with the latter being connected to a VGA monitor usin the requisite adapter.
Which is somewhat annoying.
Or get a passive display port to HDMI adaptor for a few pounds. HDMI monitors are now effectively the basline spec., VGA monitors being on their way out.
The graphics card won't allow screen three to be anything but a logical DisplayPort unfortunately, so I will need a DP monitor or an MST hub
tony_mac
25 Feb 2009
an active adapter, or a displayport to VGA adapter, should operate logically as a displayport.
D365
29 Jun 2012
Eh? I've got an HP workstation that drives three NEC displays, two using passive DisplayPort to DVI adaptors.
Yes, but your Workstation is likely designed specifically to do this.
The graphics card I have is not.
I am allowed a HDMI screen, a DVI-I screen (including VGA) and up to 4 DisplayPort Screens (using MST)
Class172
Quizmaster
20 Mar 2011
West Country
What would you consider expensive for a monitor? I use an AOC i2369vm, which cost £115 when I purchased it two years ago - it sports 4 inputs (1 DP, 2 HDMI & 1 VGA) and a 1920x1080 display. I recently brought a second one which in future will allow me to use the two identical displays together.
We have one in the bar rig at my hall of residence but I opted for a 24" AOC HDMI monitor at the time I bought my own
The point still stands though that native DisplayPort monitors aren't nearly as expensive as they used to be, and it's worth spending extra on a decent monitor as it's the one PC peripheral that you use more than any other.
Just checked the model number - an I2476VWM - and the picture is incredible.
Especially compared to the old 19" Acer VGA Screen that is next to it [although I can't get the colour temperature settings on the screens to line up!]
Getting a similar sized DP monitor is significantly more expensive unfortunately.
At work we have Dell U2414H's on most desks. They are a bit on the expensive side at around £190 but I'd definitely get the same or similar if I was in the market for a monitor for my home setup.
Crossover
4 Jun 2009
Re the OP question directly, I think the USB adaptor may be one of the few options available - unfortunately that's kind of the trade off with a smaller form factor machine. I must say, I haven't come across a PC which looks like the Alienware one before!
It may be possible to get DP to HDMI or such like. DVI is an odd one as DVI-I isn't quite so common I have found, with a lot of what I can come across being DVI-D which rules out VGA conversion as an option.
At work we have a large number of P2214H monitors which have DisplayPort on them (I installed 4 monitors with DP just today) and they weren't particularly bad money. However I think the newer Dell monitors feature HDMI inputs now (can't remember if they still have DP)
