Setting the DRA
choochoochoo
6 Aug 2013
Why does the DRA affect braking on some modern units ? Surely if it’s on/set you could just have the software prevent a request for power from being actioned and warning alert come on the DMI/HMI.
GordonT
26 May 2018
What are the implications for DRA procedure if a green signal unexpectedly changes to red as a train is approaching it or while a train is awaiting departure at a station?
43066
24 Nov 2019
It can affect dynamic braking as (AIUI) it prevents motors from taking power.
rmHawk765
8 Apr 2025
ECML South
Selecting Neutral also allows you to release the DSD without the setting the Vigilance alarm off and sending alerts to the Signaller. That was long before DRA and GSMR came into existence and some older hands I've worked with used to wrap the cab-to-cab phone cord around the brake handle if they were in a scenario that would today require the DRA to be set.
Looking at it that way I guess there is a point, fair play.
Remember the DRA doesn't prevent brake release, it prevents traction power being applied and it's specifically associated to signals for the purpose of bringing them back to the Drivers mind and check what they're looking at or what they last looked at in the case of a signal not being in view. The reverser/master switch/direction selector isn't intended to be a reminder for signalling as you would use it in situations that wouldn't fit the DRA purpose.
But in GTR's case as we're talking about it currently, you wouldn't set the DRA on the move and they're instructed to apply full service braking either way so it doesn't really matter. I honestly don't see many reasons to set it on the move in general, and on some trains it's not an option due to braking applications when doing so.
It's just adding more layers of protection, the DRA is just making sure if the driver had the train ina scenario where he/she was using DRA it would MAKE them recheck the signal aspect, ie if they forgot the starting signal was on danger in the middle of self dispatch, they closed doors (closing doors on red is a incident in itself) select foward and take power the DRA stops them taking power.
Don't you think if they've already set the reverser without checking the aspect, they will just reset the DRA too? The reverser having some sort of warning label could, as I said, work similarly as a reminder, or a voice announcement which the 700s and 717s make upon resetting the DRA. I do understand you can't have too much safety but I think its theoretical effectiveness as a separate unit is somewhat diminished nowadays.
Really this should never happen without the signaller first informing the driver (usually not at all). But I would assume you would just use it as normal.
choochoochoo
6 Aug 2013
Surely programmers are smart enough to write code that says if at a stand don’t allow traction power to be taken but if moving allow dynamic/regenerative braking.
Saj8
2 Jan 2018
You must have driven different HSTs to the ones I (and @Kneedown) drove! The DRA is not linked to the braking system in any way.
I guess I must have, although to be honest I only drove them for a couple of years before they went west in the form of castle class sets, and in that time I didn't actually attempt to set it on the move, so I was wrong to assert that the DRA applies the brake. The reason why I never attempted it was because of this in the professional driving policy regarding DRA usage:
"When driving a class 25x, the DRA cannot be applied on the move, a full service brake application will result if applied."
So I never tried! But having looked at other docs today, including the traction manual, there's no mention of this behaviour anywhere else.
scotraildriver
15 Jun 2009
We set the DRA on the move on our HSTs, all ex GWR. There's no link to the brake.
saismee
20 Oct 2023
It has to physically cut power somehow though, and you can't have regenerative braking without being connected to power lines! It isn't possible to have it one way but not the other (except with some overly complex electronics maybe). Rheostatic braking is different, as power would need to be disconnected before the resistors are connected (or you'd have a fire), and should be possible to keep active.
godfreycomplex
23 Jun 2016
Possibly, but
A - can they write it to be sufficiently robust to pass the requisite group standard? (I.E. that there is absolutely no chance of, and double or triple security against, motoring power of any kind being applied to the traction motors whilst the DRA is applied).
As saismee rightly says, it is physically possible, but requires complex code and electronic safeguards.
B - could they do all this in the late 90s/early 2000s when most of the trains with this affliction were designed and built?
C - (sadly) can they do all this in the time and for the money?
I’m not a software engineer but I’ve been involved in some of that work in the signalling side and the amount of codes and safeguards (rightly) required for something even as innocuous as mouse input into a signalling system is mind blowing
saismee
20 Oct 2023
To be honest, I think it's more of an electrical engineering problem than software here. The software would be relatively simple to do this (likely no more complex than how it currently disables traction), but you'd need to prevent current from flowing back into the motors. I'm not in electrical engineering and have little knowledge of how electric traction works, but as I understand it, it might require a whole second traction setup. It just isn't a justifiable cost when asking drivers to set it once stopped works just as well!
choochoochoo
6 Aug 2013
Why does it have to cut power ? It just has to cut the demand signal from the power controller.
Possibly, but
True. But given the robust coding used in aircraft autopilots and flight management computers for decades it’s difficult to believe the railway standards are going to be more demanding.
The cynic in me thinks it is the last reason. Train specifications provided the DfT/buyers were so poorly defined that the manufacturers took the quickest/cheapest route to satisfying them.
Kneedown
29 Dec 2007
Nottinghamshire
Weirdly I never set them on the move on a 360 but I do on a meridian. I have a love hate relationship with the DRA on a meridian being active. It was the one thing I occasionally forgot to do , was setting the DRA after a single yellow and stopping at a station and the red is out of view and so that really helped me. The flip side though is that on one or two occasions I tried to take power with it still set and of course the alarm starts screaming , made me jump :sThe other annoying thing is coming in on double yellows or a speed restriction and still having to set it at a yellow.
Tried it on a 360 once to see if it did knock the dynamic brake out. If it did I didn't notice much difference.
D3WY
2 Nov 2019
Horsham, West Sussex
Turning DRA off is just a physical reminder of red ahead, same as you would take a lower power notch out of the station as a reminder of danger ahead, physical actions as reminders.
rmHawk765
8 Apr 2025
ECML South
Yes I know that. But really, is setting the reverser to Forward from Neutral (again, a warning label or voice announcement could be used to instill its use as a reminder) any different in the sense that it's a physical reminder?
cool110
12 Dec 2014
Preston
is setting the reverser to Forward from Neutral ... any different in the sense that it's a physical reminder?
Yes, because that's something you do at every station, therefore can't be a reminder that's something's different this time.
D3WY
2 Nov 2019
No I guess but it's a 2nd physical reminder that won't physically let you take power until you disable it thus acknowledging the red. If you had no DRA and just the reverser and you forgot that's it your off with no idea your about to SPAD. Because Brake 3 and N is what you do at every stop not just ones with reds ahead. Brake 3 and N becomes the norm for regular stops, DRA becomes the norm only when there is red ahead, conditioning yourself to take care when disarming the DRA
