Selective door opening (SDO), short platforms and accessibility
TheGrew
31 Jul 2012
Yesterday I made the trip from Newton-le-Willows to York with my toddler and buggy and treated myself to a first-class upgrade; partially as I know that's where the only wheelchair spaces (to keep the buggy up) are on the Nova 1 / Class 802 fleet and partially as I thought it was worth it for the fairly long journey across the Pennines.
Normally I have found first-class to be at the Newcastle end (appreciate the sets often end get turned at Newcastle!) but on the outward journey, it was at the rear. Fortunately, I was able to get on the rear of the 4th coach and make the way just about into the 5th first-class coach to continue on my way.
On the way back through first class was at the rear, this creates a little bit of a problem at Newton though which can only take 4 coaches. Not a problem as I knew this well in time and could manoeuvre to the rear door of the fourth coach however on departing Manchester the guard announced only the front 3 coaches (Google satellite imagery fairly clearly shows 4 can fit though: https://goo.gl/maps/XM56b6h9TXZ73eMq6 ).
Unfortunately, my buggy is too wide for the quite narrow aisle so I collapsed it and had to carry it over the heads of everyone in the fourth coach with my toddler following me down the aisle, not a great experience but I made it work.
What did get me thinking though is that a motorized wheelchair user boarded at Huddersfield and while they wanted to go right through to Liverpool there is no way they could have got off the train at either Newton or Lea Green without the driver deliberately overshooting, which certainly at Newton strikes me as somewhat ironic, considering the considerable work done to ensure the station is as accessible as possible (no idea why they don't extend the platform about 30m east which is well within signal sighting!).
Does this happen elsewhere on the network or is it just an unfortunate combination of short platforms and poor design choices in putting the wheelchair spaces at one end of the train than somewhere more in the middle?
Based on seat maps the Nova 2 would also potentially suffer this problem though I suspect it doesn't have to use SDO at any of the stations it is scheduled to call at. The Nova 3s (which traditionally have stopped at Lea Green) also look to have this potential problem if the 68 is at the Scarborough end.
Ken H
11 Nov 2018
N Yorks
SDO is an abomination and should not be used as an excuse not to lengthen platforms. OK there are hard structural issues at some places, but at others is a get out of jail card for getting the JCB's out.
Anyway, why cant trains move up when platforms are too short? They used to do it at Settle in the 80's with Cl47 + Mk1.
jopsuk
13 May 2008
General agreement here, but as ever investment in infrastructure and doing it right is something we're not so keen on in this country (even new road projects are often woeful for this)
now that of course has many site-specific reasons- be it signal sighting, junctions, ability to see dispatchers etc.
Cheshire Scot
24 Jul 2020
North East Cheshire
As you have noted both platforms at Newton can take 4 coaches - actually 4 and a bit (see below) but for some reason the TPE ASDO system is set for only three coaches (although you were able to join the 4th coach on the outward trip). A particularly strange one as I believe it was originally specified by TPE all platforms as a minimum needed to be able to accommodate the wheelchair door (which is adjacent to the 4th (or 2nd) coach) on all Novas with the set in turned in either configuration and that requirement dictated which platforms with regular Nova calls needed to be extended and which did not.
EDIT: Any feedback from TPE would be interesting!
SDO is supposed to overcome that but ..................... .
