CaptainHaddock
- Joined
- 10 Feb 2011
- Messages
- 2,716
Here’s a bit of a conundrum….
Next week I’m hoping to use a Coasts & Peaks Rover to travel from Sheffield to the Merseyside area; on weekdays the rover is only valid after 0845 and, annoyingly, there is a train that leaves Sheffield at exactly 0845 to Liverpool so if the restriction is applied strictly then the first train the rover would be valid on is the 0943, an hour later.
However I also have a Leeds-Dore season ticket for work purposes and I was wondering if that would enable me to travel on the 0845. This train doesn’t actually call at Dore but will pass through it around 0850, by which time technically the rover would be valid. As I understand it, if you’re using split ticketing then, so long as one of the tickets is a season ticket, then the train doesn’t have to stop at the point of your split. However, were I to try this, is there a chance the guard could refuse to accept this ticket combination because, if the rover’s only valid after 0845 then technically it wouldn’t be valid until its first calling point after 0845, which in this case would be Stockport?
Any advice would be very much appreciated!
