SE 376 to be refurbished?
Neptune
29 May 2018
If there's a limited budget available then the one thing that doesn't need to be done is the livery, I simply fail to understand why so much money is wasted so often on nothing other than cosmetics
Paint warranties run out which I guess must be the case with the 376’s as they haven’t been touched since they were built.
fgwrich
15 Apr 2009
Hampshire
Air con and slightly brighter lighting is pretty much all that's needed on the insides
Being a member of the Electrostar family, I wonder if they have the ducting readily installed and it would be a case of inserting the air conditioning modules into the roof? They already have the standard *Star roof cut outs, currently occupied by a presumably a pressure vent system.
aleggatta
28 Sep 2015
The ventilation modules can be swapped out for Air con modules, however I'm not sure if there was something about under sized wiring to the modules not being able to support air con? in all other respects, they are the same shells and main electrical equipment as the other Electrostar variants.
Wolfie
17 Aug 2010
It is likely that use of standardised modules would have been cheaper than bespoke just for this class so you may well be right.
Doomotron
25 Jun 2018
Kent
That looks familiar! :D
I wonder why... :D
PS: You've made some really nice reskins by the way; I particularly like the SE stuff, like the 365, 321 (even if it's the DTG one!) and HST/47, as cursed as it may be!
atomicdanny
7 Mar 2010
Kent, UK
I wonder why... :D
I've seen the word "Cursed" mentioned a lot in regards to livery, is it just for trains that don't usually carry that livery?
Doomotron
25 Jun 2018
Kent
I'd say in this case it's a train that is wearing a livery that it really shouldn't have, in the same vein as an A4 in GNER livery (somebody photoshopped that).
gmaguire
29 Dec 2021
A refurbishment of the 376 would be very welcome. The paint lost its shine years ago and they’re horrible inside. Air conditioning would be fantastic, they’re quite uncomfortable during even warm weather. Currently they have fans which are very loud and seem to not do very much.
Also, if you look at the front of a 375, the yellow warning panel is arched at the top to flow over the gangway. I think they should implement the same arch on the 376 even though there is no front gangway to improve the appearance. If the front of the train is like a face, then the top of the warning panel is like its eyebrows. Currently the 376s look a bit like they’re pulling a silly “I’ll look very serious” face.
Conversely, the very similar 378s have arched windscreens.
SolomonSouth
25 Feb 2021
Gravesend
That’s good. I actually rather like the trains and certainly prefer them to Networkers. While I believe the Networkers are tattier, I’m relieved to see no mention of a refurbishment of those as I’d like for them to be replaced within the 2020s.
The 376s seem tattier to me, at least tattier than the 465/9s
Yeah, they really need it. Hopefully they get it very soon :)
Doomotron
25 Jun 2018
Kent
Its unlikely but i do hope they also get rid of that middle cab window and make it more similar to the 378, Its filth!
The only reason the 378s don't is because it is the emergency exit. It will not be removed on the 376s.
That's because the 376s have never been refurbished or refreshed - they have not been touched in any way since they were introduced in 2004.
Indeed, their paintjob is a Connex legacy of all things. I wonder what the record for longest duration a particular class has gone without either internal and/or external refurbishment is, I suspect the 376s are at least up among the longest.
FOH
17 Oct 2013
True testament to probably the single best thing Connex did. Air con (lack of) was probably, literally, the only miss
Doomotron
25 Jun 2018
Kent
Also the lack of toilets, unless the trade off for more capacity is genuinely better.
To be honest is the 1 hour journey cap wasn't in place because of the lack of toilets, we might have got them on Dover services... A terrifying thought.
Jturner98
2 Jan 2021
Kent
Any details about where and when it will take place.
Probably Ilford
Think the London Midland 321s with the Network Southeast interior beats the 376
Mikey C
11 Feb 2013
Debatable. Personally I would have much preferred them to have some higher density 375s for the medium length routes and just keep the Networkers for metro usage
Recessio
4 Aug 2019
Any idea how extensive this refurb will be? I'd love to see Air Conditioning added, and the seat configuration changed to add more capacity on the routes. Perhaps something like the 345 or S8 stock layouts, a mix of longitudinal and transverse seating.
Or even just make these units identical to their siblings, the very successful 378 Capitalstars, by adding fully longitudinal seating, to really max the capacity on the network. If the 710s get away with it on the Enfield/Cheshunt lines, don't see why it wouldn't also be suitable on SE Metro.
Chiltern006
3 Oct 2018
i’ve got a funny feeling that se will fit them with the same seats as the 707s (standardisation and all that)
Mikey C
11 Feb 2013
Why would they bother changing the seats though, when the existing ones - the original ironing boards! - are structurally very sound, and just need their rudimentary padding and covers replaced?
ScotGG
3 Apr 2013
Yep no seats will be changed I expect. They're fine really and just need new covers. The trains themselves are nowhere near as tatty overall inside as the 465/466 (excluding the /9s) which have gone 30 years with barely any changes.
TT-ONR-NRN
30 Dec 2016
Cambridge
Agreed. The Networkers are in a dreadful state, and I disagree with “excluding the /9s”, as they’re also far worse than the 376s. I don’t want to see a refurbished announced for those though as it would suggest there’ll be no orders for a replacement fleet anytime soon.
SolomonSouth
25 Feb 2021
Gravesend
I mean the 376s certainly need a refurb, and the BREL 465s at least did get the PRM refurbishments. 376s don't have toilets so I don't believe they got it
Nicholas Lewis
9 Aug 2019
Steve White (MD SE) told Modern Railways last month they are losing 1 million per day currently and thats before strikes skew things further so can you really see the DfT authorising anything more than a retrim.
